ebinmaine 70,407 #22576 Posted December 24, 2024 8 minutes ago, bassJAM said: got my C-125 running today Niiiiice 3 Share this post Link to post Share on other sites
adsm08 2,575 #22577 Posted December 24, 2024 Prepped for snow. Got the deck off and put away for the winter, chains on, snow blower installed and plow on deck. All I need now is some gas to put the battery on a charge for a bit. 3 Share this post Link to post Share on other sites
ebinmaine 70,407 #22578 Posted December 25, 2024 Been working on the organization and movement of the basement workshop to the new workshop space. Today I completely undid and redid my selection of paper manuals. I've had the BBT print a few here and had several Redsquare members send me older paper copies. I now have everything neatly divided into several general binders. As in the picture: 1. A Yost Vise manual. 2. General Wheelhorse info we've printed or had mailed here. 3. Original Wheelhorse tractor manuals or sales pieces. 4. Twin cylinder Kohler manuals. 5. Single cylinder Kohler manuals. 10 Share this post Link to post Share on other sites
cleat 6,940 #22579 Posted December 25, 2024 42 minutes ago, ebinmaine said: Been working on the organization and movement of the basement workshop to the new workshop space. Today I completely undid and redid my selection of paper manuals. I've had the BBT print a few here and had several Redsquare members send me older paper copies. I now have everything neatly divided into several general binders. As in the picture: 1. A Yost Vise manual. 2. General Wheelhorse info we've printed or had mailed here. 3. Original Wheelhorse tractor manuals or sales pieces. 4. Twin cylinder Kohler manuals. 5. Single cylinder Kohler manuals. Being organized is a great thing. If you need something, you can find it. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #22580 Posted December 25, 2024 Did some experimenting on a choke shaft using the Dremel tool in a vise. The brass screws were broken off. I used a wee bitty drill bit (3/32"?) to get a few holes in the 3-48 screws. Went 2 sizes up in drill bit. Then used a tap to poke the remaining brass outta the steel shaft. I'd say it was a mild mostly success with a good amount of learning. One thread came out ok. The other is good one side only which isn't enough. I could still use the shaft if I pick up some 3-48 nuts and use Loctite for holding power. 3 Share this post Link to post Share on other sites
8ntruck 7,344 #22581 Posted December 25, 2024 (edited) try some left handed drill bits. Applied to the peened end of the screw, they might encourage the screw to thread itself through the shaft - assuming that the head is gone.. Edited December 25, 2024 by 8ntruck 1 1 1 Share this post Link to post Share on other sites
Bar Nuthin 911 #22582 Posted December 25, 2024 Finally got my wig-wag lights setup the way I wanted. The LED bulbs respond a lot better to the flashers and are brighter. I had orange film in the front light to try and tint the white bulbs, but they were just too bright to get the look I wanted using the film. The ones in this video are actual amber LEDs (no film) and look better than I expected. 1 9 Share this post Link to post Share on other sites
Wayne0 869 #22583 Posted December 26, 2024 2 hours ago, ebinmaine said: Did some experimenting on a choke shaft using the Dremel tool in a vise. The brass screws were broken off. I used a wee bitty drill bit (3/32"?) to get a few holes in the 3-48 screws. Went 2 sizes up in drill bit. Then used a tap to poke the remaining brass outta the steel shaft. I'd say it was a mild mostly success with a good amount of learning. One thread came out ok. The other is good one side only which isn't enough. I could still use the shaft if I pick up some 3-48 nuts and use Loctite for holding power. Eric, talk about wee bitty, if you need small, I have .05 and .065 bits if you need them. Got a few of both so I'll send one of each if needed. 2 Share this post Link to post Share on other sites
Bar Nuthin 911 #22584 Posted December 26, 2024 Would it be safer to go ahead tap threads to #4 - 48 UNF? Share this post Link to post Share on other sites
ebinmaine 70,407 #22585 Posted December 26, 2024 23 minutes ago, Wayne0 said: Eric, talk about wee bitty, if you need small, I have .05 and .065 bits if you need them. Got a few of both so I'll send one of each if needed. Appreciate that but I've got some smaller stuff here too. 3 minutes ago, Bar Nuthin said: Would it be safer to go ahead tap threads to #4 - 48 UNF? Might have to go bigger than that. I'd have to drill the holes to round, then tap to that size. Share this post Link to post Share on other sites
Bar Nuthin 911 #22586 Posted December 26, 2024 1 minute ago, ebinmaine said: Might have to go bigger than that. I'd have to drill the holes to round, then tap to that size. Just thinking that might be better than nuts possibly finding their way into the cylinder. 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #22587 Posted December 26, 2024 3 minutes ago, Bar Nuthin said: Just thinking that might be better than nuts possibly finding their way into the cylinder. That's what the Loctite is for. I've seen several carbs with nuts and bolts holding the plate to shafts. 1 Share this post Link to post Share on other sites
Bar Nuthin 911 #22588 Posted December 26, 2024 1 minute ago, ebinmaine said: That's what the Loctite is for. I've seen several carbs with nuts and bolts holding the plate to shafts. Good to know. Carburetors are an area where I have little to no experience. Engineering voodoo! 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #22589 Posted December 26, 2024 5 minutes ago, Bar Nuthin said: Good to know. Carburetors are an area where I have little to no experience. Engineering voodoo! Cleanliness and patience is your friend. 1 Share this post Link to post Share on other sites
Bar Nuthin 911 #22590 Posted December 26, 2024 3 minutes ago, ebinmaine said: Cleanliness and patience is your friend. 7 Share this post Link to post Share on other sites
MainelyWheelhorse 958 #22591 Posted December 26, 2024 Yesterday, we got at least four inches of snow. So, Yesterday morning until my family Christmas party, and this morning I plowed. It's still running like a top. 4 3 Share this post Link to post Share on other sites
kpinnc 13,514 #22592 Posted December 26, 2024 10 hours ago, ebinmaine said: I now have everything neatly divided into several general binders. I always thought I was the only one who does this... I have binders for everything that I have to work on. Greasy smudge fingerprint marked pages and all! 1 1 Share this post Link to post Share on other sites
Racinbob 11,684 #22593 Posted December 26, 2024 16 hours ago, ebinmaine said: Been working on the organization and movement of the basement workshop to the new workshop space. Today I completely undid and redid my selection of paper manuals. I've had the BBT print a few here and had several Redsquare members send me older paper copies. I now have everything neatly divided into several general binders. As in the picture: 1. A Yost Vise manual. 2. General Wheelhorse info we've printed or had mailed here. 3. Original Wheelhorse tractor manuals or sales pieces. 4. Twin cylinder Kohler manuals. 5. Single cylinder Kohler manuals. Wife keeps saying I should just save it to the computer. 4 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #22594 Posted December 26, 2024 1 minute ago, Racinbob said: Wife keeps saying I should just save it to the computer. I do most of my searching on the electronic devices but every once in awhile you just need to have a piece of paper in your hand so you can flip a page back and forth instead of trying to manage the smart dumb smart phone.. 2 Share this post Link to post Share on other sites
Lee1977 7,000 #22595 Posted December 26, 2024 5 hours ago, ebinmaine said: I do most of my searching on the electronic devices but every once in awhile you just need to have a piece of paper in your hand so you can flip a page back and forth instead of trying to manage the smart dumb smart phone.. I didn't think that phone ever left your hand. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,407 #22596 Posted December 26, 2024 1 minute ago, Lee1977 said: I didn't think that phone ever left your hand. Occasionally 1 Share this post Link to post Share on other sites
pfrederi 18,293 #22597 Posted December 26, 2024 When I am working on a machine I much prefer being able to look at teal paper manual rather than trying to operate a not so smart phone with greasy hands... 3 2 Share this post Link to post Share on other sites
cleat 6,940 #22598 Posted December 26, 2024 I have most of the owners and parts manuals for all of my tractors and implements printed out. However, I rarely use these as I have a computer in the garage and have all the manuals saved on it as well. This manual contains some of the drawings for parts that I have fabricated. 1 5 Share this post Link to post Share on other sites
rjg854 11,867 #22599 Posted December 26, 2024 3 hours ago, Lee1977 said: I didn't think that phone ever left your hand. Everybody has to sleep some time 2 Share this post Link to post Share on other sites
ML3 1,435 #22600 Posted December 26, 2024 10 hours ago, Racinbob said: Wife keeps saying I should just save it to the computer. I'm the last person that embraces technology. However, all my radio control cars, planes, drones, boats, etc I put the repair info on a flash drive. I must admit its convenient cause I keep a flash drive in my field tool box so if I have an issue when I'm out playing I can access the information. I still have my books/binders as well! 😜 3 Share this post Link to post Share on other sites
