pfrederi 17,729 #22326 Posted Tuesday at 04:21 PM or this for leaves and compost 3 5 1 Share this post Link to post Share on other sites
Ed Kennell 38,143 #22327 Posted Tuesday at 10:51 PM I took the last deck off and prepped for hibernation. 3 9 Share this post Link to post Share on other sites
Handy Don 12,214 #22328 Posted Wednesday at 12:20 AM 1 hour ago, Ed Kennell said: hibernation I like that little tool/parts tray on your shop stool. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 433 #22329 Posted Wednesday at 12:28 AM Today I attempted to fix a spot that the paint underneath was peeling on the 308. I also tested the throttle after I tightened the pivot. So far so good on that it stays at full throttle instead of creeping down. 3 Share this post Link to post Share on other sites
Handy Don 12,214 #22330 Posted Wednesday at 01:03 AM (edited) I made some good progress on rehabbing a pretty tired and worn 1963 dozer blade and getting it set to go on the 854. I’m going to experiment with plowing this winter instead of using the walk-behind blower. The last couple of years the blower was needed only a couple of times while I had to push-shovel a lot of 3-4” snowfalls that were quite wet. This frame/blade came to me through @ebinmaine. The angle lever and rod as well as mounting brackets were already gone before he got it. The ’63 42" dozer was a unicorn. Last frame with a foot release for the angle lock, first frame with cast iron ends on the trip springs. It mounted via two separate angle iron brackets with ¾” shoulder bolts for the frame pivots. Here’s the OM and IPL, if you are curious! Since I don’t know if this is a long term relationship, I prepped and painted only the face of the blade. At some point in its life, the lower blade must have worn past the wear edge because a PO layered in a new 4” band of sheet steel to rebuild the lower edge and then attached a new wear strip. Not a bad piece of work, but s/he never painted it! You can see the new band extending above the bolted on wear edge in the picture. I’m too lazy to want to have to bolt/unbolt the frame to mount the blade so from @wallfish I got one of the newer “inside” brackets. I’ve adapted the frame by adding a ¾” rod through the frame end holes and used a 1.5" spacer bushing on each side to keep the frame centered on the bracket. I drilled and cottered the spacers to the rod so it’s a reversible adaptation. I’d previously added a front attach-a-matic to the 854. It usually holds a front weight that helps me feel secure on the uphill parts of my property. But I was concerned about possible interference with the old-style “triangle” frame. Whew, it just misses! BTW, as many of you know, the nuts on the bracket bolts are a close clearance. The perfect use case for my recent birthday present--a set of Craftsman Pro ratchet/open end combo wrenches! The solid lift link (I’ll add a picture after it’s painted) is 10.5” on center for the ⅜” holes and it’s bent to have an offset of about 1” outboard at the plow frame. It attaches in the second from the end hole on the rock shaft arm. I’m waiting on a rod and Heim ends to build the angle actuator rod and finish the angle control lever. More pics and measurement progress then! Edited Wednesday at 05:28 PM by Handy Don 4 6 Share this post Link to post Share on other sites
wallfish 16,994 #22331 Posted Wednesday at 02:10 AM 1 hour ago, Handy Don said: I had to push-shovel a lot of 3-4” snowfalls that were quite wet. You should enjoy the quick clean ups with a blade for those pesky type storms that don't leave huge piles of snow from plowing it. Share this post Link to post Share on other sites
Greg Cullison 40 #22332 Posted Wednesday at 12:09 PM 13 hours ago, Ed Kennell said: I took the last deck off and prepped for hibernation. What did you spray on the underneath of the deck? Looks nice 1 Share this post Link to post Share on other sites
Ed Kennell 38,143 #22333 Posted Wednesday at 12:31 PM 20 minutes ago, Greg Cullison said: What did you spray on the underneath of the deck? Looks nice That is old used motor oil. I'll let is soak and dry in the sun for a few days before storage. 5 1 Share this post Link to post Share on other sites
Greg Cullison 40 #22334 Posted Wednesday at 12:35 PM Nice. I would've never thought of that. Thanks Share this post Link to post Share on other sites
Wheelhorse#1 1,657 #22335 Posted Thursday at 02:03 PM On 11/20/2024 at 7:31 AM, Ed Kennell said: That is old used motor oil. I'll let is soak and dry in the sun for a few days before storage. Bar and chain lube works well too and doesn't run but it has gotten pricey . 1 Share this post Link to post Share on other sites
Ed Kennell 38,143 #22336 Posted Thursday at 02:12 PM 4 minutes ago, Wheelhorse#1 said: Bar and chain lube works well too and doesn't run but it has gotten pricey . Old drained lower unit outboard oil also works well. I use that to coat all the ungalvanized parts on my salt water boat trailers... springs, shackles, etc. 5 Share this post Link to post Share on other sites
Horsin'round 74 #22337 Posted Thursday at 03:24 PM 1 hour ago, Wheelhorse#1 said: and chain lube works well too Impressive, How are you collecting it from the bar? 2 1 Share this post Link to post Share on other sites
pfrederi 17,729 #22338 Posted Thursday at 05:33 PM 2 hours ago, Horsin'round said: Impressive, How are you collecting it from the bar? I think he was referring to chain lube used on roller chain like a motorcycle or I use it on my WH snowblower Share this post Link to post Share on other sites
squonk 41,070 #22339 Posted yesterday at 01:14 PM Fired up the Fireball 8 on the Wheel a Matic for the first time after rewire and carb rebuild. B-80 engine has new valves and rings. Used the flywheel and shroud of the original engine. 12 Share this post Link to post Share on other sites
Ed Kennell 38,143 #22340 Posted yesterday at 03:08 PM Put the last deck on the storage dolly for the winter storage. Got our first snow this AM....better go warm up the 520H and the Ber Vac dually. 4 4 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,657 #22341 Posted 23 hours ago (edited) On 11/21/2024 at 10:24 AM, Horsin'round said: Impressive, How are you collecting it from the bar? Accually Chain and Bar oil is made for chain saws. Goes by that name...look it up Edited 23 hours ago by Wheelhorse#1 Share this post Link to post Share on other sites
pfrederi 17,729 #22342 Posted 23 hours ago (edited) Been snowing all night plowed about 6:30 but has added more... lost half a tree up against the house. Been using the Charger 16 with the big plow (56in) from a D series..This heavy wet stuff is about all she can deal with actually drags the engine down before I spin out. Sorry no actionvpics my photographer avoid the out side when it snows Power off since 3:15 am Edited 23 hours ago by pfrederi 10 Share this post Link to post Share on other sites
Wayne0 457 #22343 Posted 23 hours ago Holy crap! it's 50 degrees and cloudy here in NH. No sign of white. 2 Share this post Link to post Share on other sites
kpinnc 12,007 #22344 Posted 22 hours ago 35 minutes ago, pfrederi said: Been snowing all night plowed about 6:30 but has added more... Beautiful… And you folks can keep that stuff! 15 minutes ago, Wayne0 said: Holy crap! it's 50 degrees and cloudy here in NH. No sign of white. Yep! It’s in the 50s here in NC, dips down barely to freezing at night. That’s plenty cold enough for me! Of course we will see colder temps, but nothing like you folks up north. …And I am NOT complaining! 1 Share this post Link to post Share on other sites
ebinmaine 67,432 #22345 Posted 22 hours ago 20 minutes ago, Wayne0 said: Holy crap! it's 50 degrees and cloudy here in NH. No sign of white. Same here in Maine unless you get up to the northern part of New Hampshire or Western Maine mountains. Share this post Link to post Share on other sites
adsm08 2,047 #22346 Posted 22 hours ago Yup, been snowing or raining here al morning. I took off for hunting today, went out, got my two birds, and was back in the car by 9 and glad for it. Started coming down hard right as I was getting back to the vehicle. Share this post Link to post Share on other sites
pfrederi 17,729 #22347 Posted 21 hours ago Went out again to clear area in front of shop and driveway...It is a magnum 16 and thus has the walbro fixed main jet. May swap in a Kohler #30 seems to be a bit too lean when she really hits the big piles.. Still no action shots 2 4 Share this post Link to post Share on other sites
cleat 5,926 #22348 Posted 21 hours ago Wow, it's 45 degrees F and sunny here. No snow yet or even in the 7 day forecast. Funny how we are further north and the weather is warmer. Must be an altitude difference. Share this post Link to post Share on other sites
Ed Kennell 38,143 #22349 Posted 20 hours ago 2 hours ago, pfrederi said: Been using the Charger 16 with the big plow (56in) How is the front end control with that big blade angled? Share this post Link to post Share on other sites
adsm08 2,047 #22350 Posted 20 hours ago 1 hour ago, cleat said: Wow, it's 45 degrees F and sunny here. No snow yet or even in the 7 day forecast. Funny how we are further north and the weather is warmer. Must be an altitude difference. Where I am its low 40s. It's coming down as snow, but not laying. There is one of those atmospheric river things heading south to the west of Ontario, but hitting a lot of New England down into PA. Also, if @pfrederiis in Northeast the town, and not Northeast the region he's right on lake Erie, and they are getting lake effect with system. My aunt who lives in Erie had a few inches on the ground last night. Share this post Link to post Share on other sites
