Ed Kennell
What have you done to your Wheel Horse today?
953 nut
38 minutes ago, Ed Kennell said:
use black tape to cover all the useless  tire pressure  warning lights on my truck.
About a week after I had new tires installed on my truck one of those high dollar valve stems that monitor tire pressure bit the dust. Every time my wife drives my truck she complains about it but I'm to cheep (thrifty) to spend over $ 150 to turn that silly light off. Guess i could buy some black tape for $ 5,   Thanks ED.
  • Haha 2
  • Heart 1
Ed Kennell
The batteries in those stems have a 10-15 year life if the aluminum housing doesn't crumble first.     I always remove mine when I install the first set of new tires.
kpinnc
1 hour ago, 8ntruck said:
I'll leave ya'all with a pleasant image.  Shot it off the deck tonight just after sunset:
Absolutely beautiful!
  • Like 4
MainelyWheelhorse
More work on the old 308-8 today after work. A bit of greasing, lubing and removing and replacing three stuck screws, and the three other screws I got out, with bolts.Then replacing four heavily rusted clips with threaded inserts. It was a bit of a PITA but It’s coming along.
  • Like 7
Bar Nuthin
  1. Found parts for my headlight
  2. Installed said headlights
  3. Replaced filament bulbs with bright LEDS
Question: Where should the wire for the headlights be routed?  The old wire was missing, so I'm not sure the best way to route the new one.
  • Excellent 2
rjg854
On my tractors the wire runs through the frame and then up to the headlights.
peter lena
 @ rig854   personally like CABLE WRAP  on wiring , also use peel / stick ty wrap mount in place  , like contractors  , bolt on  electrical lugs , very secure solid , eliminate tight / binding / chafing  anything  , only a suggestion , love repetitive problems , improve and eliminate them . pete
Damien Walker
On 10/3/2024 at 11:25 PM, Ed Kennell said:
I use black tape to cover all the useless  tire pressure  warning lights on my truck.   I adjust my tire pressure (20-70 PSI) for the load and driving condition.
Don't need a light to tell me when I have a flat tire.
Clearly you are a kindred spirit good sir! I have a friend who finds it impossible to drive her car when the TPMS bleats at her....another friend present on one occasion, hopped out of the car, eyeballed the tyre and said 'looks ok to me' but said friend still couldn't drive. Amazing really.
Not sure our black tape is that reliable over here (almost certainly poor quality far eastern import!) so I think I'll still have a go at my 'dimming' idea.....it's an interesting technical challenge if nothing else.
Pip, pip!
8ntruck
The company I hired I to right out of college in 1978 was working on a tire pressure monitoring system.  They had prototypes running in some of the company cars.
Didn't go much further until the combination of practical on board automotive computers, cell phones, and SUVs becoming popular replacements for the family sedan happened.
Part of the SUV revolution was getting them to feel like the family sedan in terms of noise, vibration, and harshness - on a truck based vehicle.  Think Ford Explorer here.
Remember the Ford Explorer rollover issue?  Usually happened at highway speeds brought on by a sudden large steering input - maybe like dropping wheels off of the road while talking on a phone or in reaction to a tire blowout.
Turns out that Ford specified a tire pressure to make an acceptable ride that was lower than the tire maker's recommendations based on the operating load of the vehicle.  In essence, the lower pressure took away the safety factor built into the pressure based on load.
In real life, folks would let tire pressures fall, which caused vehicle handling to change, and tires to run hotter - some to the point of failure.  The National Traffic Safety Board ended up getting involved, investigating, and finally requiring tire pressure monitoring systems on all vehicles.
Tire pressure needs to be maintained.  The current TPMS give you a warning long before the tire pressure is critically low.  Consider it a reminder to fill the tire at your earliest convenience rather than a do not operate the vehicle alarm.
The Corvair might have had a better reputation had TPMS been available at the time.  Letting the tire pressure get low in the rear tires of the Corvair aggravated it's tendency for tailing throttle oversteer to the point that the average driver lost control.
OK.  I'll step down off of my soap box now.
Edited by 8ntruck
  • Excellent 2
adsm08
OK.  I'll step down off of my soap now.
It also didn't help that they were installing load-range C tires on them to get softer sidewalls for better ride. The Rangers in the same years weighed less, had a lower payload and towing capacity and were still factory equipped with Ds.
In reality what Ford should have done was to issue a statement basically saying "Yes, your truck-chassis vehicle rides like a truck. Congratulations on describing the proper operation of the vehicle. Now if you are unhappy with that please feel free to consider one of our nice sedans like the Crown Vic with air ride, or the Taurus/Sable that comes in a wagon if you need that extra space. Otherwise, go pound sand."
  • Like 8
WHX??
Removed a broken hoobie doo... the weld on nut works every time :)
  • Like 5
Colby G
Installed a cb radio on the 1969 charger 12
  • Confused 2
MainelyWheelhorse
I helped my brother by mowing the last piece of his lawn with my 42”RD deck that I moved to the 312. The 42” came with the 308. The bigger deck definitely worked better in the tall grass than the 37” SD that came with the 312.
  • Like 5
kpinnc
I urge you to be careful. As you begin to enjoy different attachments on your tractors, your subconscious will begin to want more and more of the cool stuff to hang on your tractor. It is a dreadful addiction.
Wheelhorseitis (among many other names) is a terrible condition. Only awareness can stop it. :rolleyes:
This is how it starts. Next you’ll find yourself enjoying the smell of new tires and fresh paint. In the last stages, you’ll begin fabricating and modifying. That’s when you realize that the damage is done.
Edited by kpinnc
  • Haha 6
ebinmaine
I believe awareness ADDS to the volume of tractors.....
:lol:
  • Excellent 3
MainelyWheelhorse
@kpinnc @ebinmaine
I feel the intervention has come too late…
Edited by MainelyWheelhorse
  • Excellent 4
mrc
hi MainelyWheelhorse,
you might want to make a back flap for that RD deck.  i use old inner tube,  stops the grass clippings from getting all over the rearend of the tractor.   this is especially important with a hydro.  i do see you are running an 8 speed.  just a suggestion
regards
mike
Lee1977
I have heard that some used a vinyl base board as a deflector on rear discharge decks.  But then I didn't spend last night at a 4 star motel, and I don't have a rear discharge deck so this might be disinformation.
So I suggest you check it out your self first. I don't want to upset anyone.
  • Like 5
MainelyWheelhorse
regards
mike
@mrc ok, I’ll check it out. Thanks for the suggestion.
MainelyWheelhorse
@Lee1977 Ok, ill look into it.
ebinmaine
@kpinnc @ebinmaine
:lol:
Wait till you come down to me n Trina's place. You'll see what can happen if you're not careful. You can also check out the different vintages and sizes and shapes.
:handgestures-thumbupright:
Handy Don
@ebinmaine prompted me to put this up here. This is on a 36” geared RD deck but the principle is the same for the 42” belt RD.
I used ordinary stainless hardware--round headed hex socket screws with flanged nylock nuts
Edited by Handy Don
  • Excellent 2
