Ed Kennell 38,175 #21526 Posted June 10 My son made part of his deck into a sun room, so I repurposed the deck boards into a trailer floor for my horse and bucket hauler. Then gave it a coat of a kerosene/used motor oil mixture. 5 14 Share this post Link to post Share on other sites
BavariaPJ 11 #21527 Posted June 11 On 6/7/2024 at 3:30 PM, lynnmor said: There are no "injectors" so avoid that "mechanic." Drain the fuel tank and fuel lines, replace the grommet in the bottom of the fuel tank and clean or replace the shutoff valve, replace the 1/4" rubber hoses with ethanol resistant hose. Replace the fuel filter. Use fresh gasoline when ready to start. Spraying the butterfly will do exactly nothing, spraying carburetor cleaner down the five holes around the the air filter mounting can help. Keep in mind that anything sprayed in the carburetor might find its way into the oil, you may have already contaminated the oil necessitating an immediate oil change. Fresh oil goes into the crankcase and fresh gasoline goes in the fuel tank, no snake oil should be used other than a bit of cleaner mentioned above. After running it for some time and the surging continues calls for more work. The most likely issue is gum, dirt or corrosion inside the carburetor and the only way to clean it right is to remove it and that entails some work since the exhaust and intake needs to come off. Before pulling the carburetor, spray WD40 around the split in the intake manifold while the engine is running to see if there is any effect. Also look for a missing welch plug just above the idle mixture screw. Download the Onan Service Manual for all the information you need. The welch plug can be seen in figure 2 on page 7-2 just above the idle fuel limiter cap. While the intake is off would be a good time to adjust the valves, I would bet that it was never done. As you go along, report back here for more information. Yes, there is some normal maintenance to be performed and once done should give years of life to the tractor. Thank you for all the suggestions. Going download the Onan Manual to get some info, including changing transmission fluid and how they suggest removing blades 1 Share this post Link to post Share on other sites
lynnmor 7,306 #21528 Posted June 11 3 hours ago, BavariaPJ said: Thank you for all the suggestions. Going download the Onan Manual to get some info, including changing transmission fluid and how they suggest removing blades In addition to the Onan Service Manual, you will need to download the tractor owners manual and the mower installation manual. You can get these for free at the manuals section of Red Square. If you add implements be sure to add those manuals as well. To remove mower blades you can use a wooden block to prevent the blade from turning. Wheel Horse made a special wrench to hold the spindle behind the blade but those wrenches are low quality. If you want to go with the wench method, buy one of reasonable quality at a yard sale and if it is too thick grind it down till it fits. 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #21529 Posted June 11 (edited) I change mowerblades with welding gloves and a Electric impact wrench. Set it to max. Open power, so i be able to loose it quickly without bruises. Edited June 11 by Tractorhead 2 Share this post Link to post Share on other sites
mrc 812 #21530 Posted June 12 the wrench size is 1 1/8 inch. needs to be about .300 +/- thick. 5/16 inches = .3125 thick pick up a cheapo at harbor freight and give to a machinist who can surface grind it Share this post Link to post Share on other sites
Racinbob 11,081 #21531 Posted June 12 10 hours ago, mrc said: the wrench size is 1 1/8 inch. needs to be about .300 +/- thick. 5/16 inches = .3125 thick pick up a cheapo at harbor freight and give to a machinist who can surface grind it Works great. Share this post Link to post Share on other sites
pfrederi 17,739 #21532 Posted June 12 Or grab an old blade and your hacksaw Share this post Link to post Share on other sites
BavariaPJ 11 #21533 Posted June 12 I bought a Craftsman 1/2" torque wrench. Have a lot of tools but never owned a torque wrench. Bought this one on Amazon for $65 and it is really substantial. I will use it while changing blades. Thanks for the suggestions on stabilizing the blades while removing. I also need to download manual. I need to locate the transmission drain plug located on my '92 520H and change out fluid, will do same with oil and change plugs. Thanks again for the assistance. Still planning on bringing it in because it still surges at lower RPM's after running Seafoam through it. 2 Share this post Link to post Share on other sites
Pullstart 62,881 #21534 Posted June 12 @BavariaPJ I’m a little late to this party, but we’ll make you a mechanic in no time! 1 1 Share this post Link to post Share on other sites
Handy Don 12,232 #21535 Posted June 12 1 minute ago, BavariaPJ said: I need to locate the transmission drain plug located on my '92 520H and change out fluid, will do same with oil and change plugs. Thanks again for the assistance. Still planning on bringing it in because it still surges at lower RPM's after running Seafoam through it. ¼” Allen wrench to remove the plug on the bottom towards the rear. Socket often gets filled with crud and is hard to see. Search on the documents/files on this site using your tractor’s model number to get the owner manual--it shows all the regular maintenance points. Onan surge causes are: likely fuel, less likely air, and rarely a loose governor linkage. Carb is unlikely to clean up with any magic elixir--you have to go in there to do it. Service manual is the guide to follow. Air is when the seam of the intake manifold is letting in air that hasn’t come through the carb. Test by spraying a little bit of brake cleaner along the seam while the engine is running but NOT hot. If the engine changes speed noticeably, then the seam is likely leaking. 2 Share this post Link to post Share on other sites
cleat 5,977 #21536 Posted June 12 16 hours ago, mrc said: the wrench size is 1 1/8 inch. needs to be about .300 +/- thick. 5/16 inches = .3125 thick pick up a cheapo at harbor freight and give to a machinist who can surface grind it I ground down a cheap wrench and also cut the box end off so it fits in a little better. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,657 #21537 Posted June 12 On 6/10/2024 at 8:42 AM, Goldnboy said: Did some painting yesterday! I used the new high flow setting on cans that have choice of 5 settings. The new style nozzle are great and work very well. I think it’s a great idea by rustoleum . Nice work ! 1 Share this post Link to post Share on other sites
8ntruck 7,004 #21538 Posted June 12 (edited) Got Morgan, the 14-8 out today and mowed the yards. It is really dry, so I was constantly in a dust cloud - I probably looked like Pigpen from the Peanuts comic strip while I was mowing. Unless we get some rain, I doubt I'll need to mow for 3 or 4 weeks. Edited June 12 by 8ntruck 3 Share this post Link to post Share on other sites
balconio 606 #21539 Posted June 13 got a 100' roll of 4" corrugated tubing so i can finish my pond inflow project. here's my 14yo son using the 312-8 and Harbor Freight trailer to run it back into the woods until i can do the work. i really enjoy the ball-hitch on the wheelhorse as opposed to driving my truck thru the yard. 5 1 Share this post Link to post Share on other sites
ebinmaine 67,500 #21540 Posted June 13 4 hours ago, balconio said: got a 100' roll of 4" corrugated tubing so i can finish my pond inflow project. here's my 14yo son using the 312-8 and Harbor Freight trailer to run it back into the woods until i can do the work. i really enjoy the ball-hitch on the wheelhorse as opposed to driving my truck thru the yard. Way to go giving the young one something to do. Definitely agree on having the ball hitch on the Wheel horse. We don't have vehicular access anywhere in the acreage once you're out of the driveway so it's a necessity here. Share this post Link to post Share on other sites
Handy Don 12,232 #21541 Posted June 13 1 hour ago, ebinmaine said: We don't have vehicular access anywhere in the acreage Don’t let them horses hear that they aren’t veehickels. 5 Share this post Link to post Share on other sites
WHGuy413 2,683 #21542 Posted June 15 We are way behind but thanks to @WheelHorse_Kid and his 7 dollar Rototiller we have the garden ready to go. Next year we will be on it earlier in the year. our first time using the tiller and it has worked great so far. 1 8 Share this post Link to post Share on other sites
OoPEZoO 524 #21543 Posted June 15 A $7 tiller?! Oh man, that’s a score. Looks like an excellent start to a garden 3 Share this post Link to post Share on other sites
WHGuy413 2,683 #21544 Posted June 16 15 hours ago, OoPEZoO said: A $7 tiller?! Oh man, that’s a score. Looks like an excellent start to a garden Yup you read that right. A guy listed it locally as make an offer. I messaged him and told him my son was interested and tried to gauge what he was thinking. He texted me the next morning and said “if it’s really for your son we will work out a price by the evening” later in the day he messaged me a picture from a drive through coffee place with a total of 6 bucks and change. He said “your son can have it for my afternoon coffee, I splurged today” I didn’t think he was serious but he was 100% serious. Super nice guy. Said he used to have a ton of wheel horse stuff laying around but his kid tossed it. Was happy to see a kiddo into small engines and sold it to him for 7 bucks. 3 7 Share this post Link to post Share on other sites
8ntruck 7,004 #21545 Posted June 16 Morgan, the 14-8 got a workout today. The 48' plow was installed, and we got some dirt work done on the lake house deck project. Morgan does not have any additional weights or chains, I got the Troy Built Pony out to 'tenderize' the dirt that needed moving. Was surprised that the tiller started on the first pull today - especially since it hasn't been run in about 3 years. it has developed a gas leak, though. Going to have to run that down. Anyhow, picture of the site after the Pony had pranced through: After about 20 minutes of Horse & blade work, things looked like this: Looks like a yard or yard and a half of sand was moved. 3/4 throttle in 2nd gear low range. Not surprisingly, I ran out of traction before I ran out of horsepower. 8 1 Share this post Link to post Share on other sites
ebinmaine 67,500 #21546 Posted June 16 7 hours ago, WHGuy413 said: Was happy to see a kiddo into small engines and sold it to him for 7 bucks. That's just fantastic! 2 Share this post Link to post Share on other sites
Goldnboy 920 #21547 Posted June 16 Put the last coat of paint on the tins...and finished painting the small parts. Looks like assembly starts next weekend! 4 5 Share this post Link to post Share on other sites
TonyToro 1,049 #21548 Posted June 16 19 hours ago, WHGuy413 said: Yup you read that right. A guy listed it locally as make an offer. I messaged him and told him my son was interested and tried to gauge what he was thinking. He texted me the next morning and said “if it’s really for your son we will work out a price by the evening” later in the day he messaged me a picture from a drive through coffee place with a total of 6 bucks and change. He said “your son can have it for my afternoon coffee, I splurged today” I didn’t think he was serious but he was 100% serious. Super nice guy. Said he used to have a ton of wheel horse stuff laying around but his kid tossed it. Was happy to see a kiddo into small engines and sold it to him for 7 bucks. So awesome to see kids into tractors and small engines. My son is the reason I’m on this page. While his friends are enjoying the latest video game or battery powered scooter, he’s happy getting something running or restoring an old WheelHorse. These kids are far few between. There are a few on here and it’s great to see them carrying along a skill that may soon be in the past. Way to go DAD! 3 5 Share this post Link to post Share on other sites
Goldnboy 920 #21549 Posted June 17 I asked my daughter who likes to paint if she would paint the white letters on my dash panel.. She surprised me with it on father's day! 7 10 Share this post Link to post Share on other sites
19richie66 17,508 #21550 Posted June 17 10 minutes ago, Goldnboy said: I asked my daughter who likes to paint if she would paint the white letters on my dash panel.. She surprised me with it on father's day! She did a great job! 2 4 Share this post Link to post Share on other sites
