Achto 27,565 #21101 Posted April 7 Pulled one of my 953's out of hibernation, or should I say pushed. The only way I could get it to run while it was in my fake garage was by spraying gas down it's throat. Pushed it into the work shop, pulled the bowl off from the carb & found it dry as bone. While the bowl was off I worked the primer handle on the fuel pump and got nothing up to the carb. Not going to bother rebuilding the fuel pump. Instead I started prepping to install an electric fuel pump. I did this on my other 953 and have not regretted the decision. 6 11 Share this post Link to post Share on other sites
Ed Kennell 38,134 #21102 Posted April 7 37 minutes ago, Achto said: I did this on my other 953 Same here on the 953 I had. 2 1 Share this post Link to post Share on other sites
ML3 1,197 #21103 Posted April 7 Thinking about changing over to electric fuel pump as well on my 953. Most the fuel line is copper & I'm not really happy with how it's routed- kinda janky. It rubs sometimes on the hydraulic lift arm. Surprised cause the restoration of the tractor is so nice. 2 11 Share this post Link to post Share on other sites
cafoose 3,354 #21104 Posted April 7 15 minutes ago, Ed Kennell said: Same here on the 953 I had. Are you referring to the 953 I got from you Ed? I haven't noticed if it has an electric pump on it or not. It's in the neighbor's barn until I can make room for it 2 Share this post Link to post Share on other sites
WHX?? 48,814 #21105 Posted April 7 53 minutes ago, Achto said: started prepping to install an electric fuel pump. Prolly the best thing to do. Borrow the one from the puller build. Don't know what it is about 953s and fuel pumps lately. That motor did sit outside for a long time tho. Gimme the old one I'd like to dissect it just for grins. 1 Share this post Link to post Share on other sites
Achto 27,565 #21106 Posted April 7 5 minutes ago, WHX?? said: Gimme the old one I'd like to dissect it just for grins. Let you work it over if you wish. Know you like the ones with a primer handle. 1 1 Share this post Link to post Share on other sites
Achto 27,565 #21107 Posted April 7 (edited) 22 minutes ago, ML3 said: Thinking about changing over to electric fuel pump as well on my 953. If you remove the center panel and the left hand side panel for access. There is a perfect place to install an electric pump in front of the shifter and just behind the hydraulic pump. In the area I have circled. No one will ever know it's there. Edited April 7 by Achto 3 Share this post Link to post Share on other sites
Ed Kennell 38,134 #21108 Posted April 7 (edited) 28 minutes ago, cafoose said: Are you referring to the 953 I got from you Ed? Yep, that one should have a lectric pump right behind Dans yellow circle. Edited April 7 by Ed Kennell 1 3 Share this post Link to post Share on other sites
ML3 1,197 #21109 Posted April 7 6 minutes ago, Achto said: If you remove the center panel and the left hand side panel for access. There is a perfect place to install an electric pump in front of the shifter and just behind the hydraulic pump. In the area I have circled. No one will ever know it's there. Thanks. 1 2 Share this post Link to post Share on other sites
WHX?? 48,814 #21110 Posted April 7 8 minutes ago, Achto said: If you remove the center panel and the left hand side panel for access. There is a perfect place to install an electric pump in front of the shifter and just behind the hydraulic pump. In the area I have circled. No one will ever know it's there. Wire it right to the coil hot. 2 2 Share this post Link to post Share on other sites
squonk 41,067 #21111 Posted April 7 (edited) I mounted mine right under the tool box nice and close to the tank. Easy access to the pump and filter. I don't care if it isn't hidden. I just want it to work. Edited April 7 by squonk 4 Share this post Link to post Share on other sites
953 nut 55,188 #21112 Posted April 7 1 hour ago, WHX?? said: Gimme the old one I'd like to dissect it just for grins. Most times it will be the little valve THINGIES that aren't sealing well. turn them upside down and they should work. 2 Share this post Link to post Share on other sites
Horse Newbie 7,069 #21113 Posted April 8 (edited) 4 hours ago, ML3 said: ground is soaked! I made a bit of a mess mowing. Been there… Edited April 8 by Horse Newbie 1 9 1 Share this post Link to post Share on other sites
kpinnc 12,005 #21114 Posted April 8 1 hour ago, Horse Newbie said: Been there Oh no! You got the Work Horse dirty!!!! Just kidding Tim. Man your yard is a bit moist! 1 4 Share this post Link to post Share on other sites
ML3 1,197 #21115 Posted April 8 5 hours ago, Achto said: If you remove the center panel and the left hand side panel for access. There is a perfect place to install an electric pump in front of the shifter and just behind the hydraulic pump. In the area I have circled. No one will ever know it's there. What brand/type of fuel pump should I purchase? Share this post Link to post Share on other sites
Achto 27,565 #21116 Posted April 8 (edited) 7 hours ago, ML3 said: What brand/type of fuel pump should I purchase? This is the one that I use. https://www.amazon.com/Solid-State-Fuel-Pump-FPF-60304N/dp/B08WHXTKH4/ref=sr_1_3?crid=31UEMKWJZGORJ&dib=eyJ2IjoiMSJ9.h2n14b5HW3EZ1PZzNFusjRXEbE6__yF-S-RK6W4JCIQtRyXx505-spqE_FuBjV4zS-tEQX5yyXRb-H2AGHBu3TS4B37tS_4RpCI4gD5PukHUv84qrlznvq73EXqNdEWjZpCV3FmMOraCN1tLzFlqrLQdDEBIFqbNdbjtcQkBc7M5v572GoLKbTtqIgd9K9W_Z_hW6cgHeikSozWpPFaBHBJJLAC58hKJU_t25-uU2T0.eQhw9KqWvsn8MO5tqNsBPn5OSsk7Wf6K4CtQExf-Now&dib_tag=se&keywords=facet+electric+fuel+pump+12v+for+low+pressure+for+carburetor&qid=1712571260&sprefix=facet+low+pressure+%2Caps%2C176&sr=8-3 If you chose another brand, make sure that it is less than 4psi max. Edited April 8 by Achto 2 Share this post Link to post Share on other sites
ML3 1,197 #21117 Posted April 8 1 hour ago, Achto said: This is the one that I use. https://www.amazon.com/Solid-State-Fuel-Pump-FPF-60304N/dp/B08WHXTKH4/ref=sr_1_3?crid=31UEMKWJZGORJ&dib=eyJ2IjoiMSJ9.h2n14b5HW3EZ1PZzNFusjRXEbE6__yF-S-RK6W4JCIQtRyXx505-spqE_FuBjV4zS-tEQX5yyXRb-H2AGHBu3TS4B37tS_4RpCI4gD5PukHUv84qrlznvq73EXqNdEWjZpCV3FmMOraCN1tLzFlqrLQdDEBIFqbNdbjtcQkBc7M5v572GoLKbTtqIgd9K9W_Z_hW6cgHeikSozWpPFaBHBJJLAC58hKJU_t25-uU2T0.eQhw9KqWvsn8MO5tqNsBPn5OSsk7Wf6K4CtQExf-Now&dib_tag=se&keywords=facet+electric+fuel+pump+12v+for+low+pressure+for+carburetor&qid=1712571260&sprefix=facet+low+pressure+%2Caps%2C176&sr=8-3 If you chose another brand, make sure that it is less than 4psi max. Thanks! I'll look it up. Just another project to add to my "to do" list 🙄 By chance any pics of your fuel pump installation? Share this post Link to post Share on other sites
Achto 27,565 #21118 Posted April 8 8 minutes ago, ML3 said: By chance any pics of your fuel pump installation? Unfortunately no. My pump bolted to the left side inside this area. Share this post Link to post Share on other sites
ML3 1,197 #21119 Posted April 8 8 minutes ago, Achto said: Unfortunately no. My pump bolted to the left side inside this area. I'll figure it out. Just want to keep fuel line away from moving parts. Thanks! 1 Share this post Link to post Share on other sites
ACman 7,618 #21120 Posted April 8 (edited) On 4/6/2024 at 4:17 AM, ebinmaine said: What is that glorious front weight?? That’s a rear weight for an early Simplicity Broadmoor . On 4/6/2024 at 7:25 AM, Ed Kennell said: Hey Jeff, Is that notched weight bracket designed to limit the axle movement for plowing? Good to hear from you, Is the big show on your schedule? It’s notched to work with the factory stops welded on the front of the RJ frame . The show is still up in t air with my daughter being pregnant . Edited April 8 by ACman 2 1 1 Share this post Link to post Share on other sites
squonk 41,067 #21121 Posted April 8 3 hours ago, ML3 said: Thanks! I'll look it up. Just another project to add to my "to do" list 🙄 By chance any pics of your fuel pump installation? Here's where I mounted my pump 4 1 1 Share this post Link to post Share on other sites
D_Mac 8,607 #21122 Posted April 8 So I emptied the garage out today. Figured I would take a family photo. Guess which one isn't related. Still love it, but just not family. 9 2 Share this post Link to post Share on other sites
SylvanLakeWH 25,535 #21123 Posted April 8 Right color though...! 3 Share this post Link to post Share on other sites
D_Mac 8,607 #21124 Posted April 8 1 hour ago, SylvanLakeWH said: Right color though...! And a black hood ! 1 1 1 Share this post Link to post Share on other sites
Sodaking27 777 #21125 Posted April 9 A much needed bath for the new addition. Discovered it’s missing a bolt and washers from the control on the trans. Hopefully someone will have a junk trans that they would be willing to sell me the missing parts. 3 2 Share this post Link to post Share on other sites
