Colby G 233 #19976 Posted September 19, 2023 The 211-4 steered a bit hard, so I put a suicide knob on it and I think it looks really good! 4 Share this post Link to post Share on other sites
TonyToro 1,049 #19977 Posted September 19, 2023 On 9/17/2023 at 4:38 PM, Handy Don said: I've been scanning for weights similar to that one. Astonishing what cast iron is going for these days. I have a set of 75 lb. concrete-in-plastic rear wheel weights in pristine condition but it doesn’t make sense to put one of those on the front. 🙃 If you are ever my way I have a mess load of weight for the pulling tractors. All sorts that I’ve gathered over the years. I have some heavy cast pieces that I’ll probably never you that you are welcome to. They have bolting holes already in them. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 67,445 #19978 Posted September 19, 2023 8 minutes ago, TonyToro said: If you are ever my way I have a mess load of weight for the pulling tractors. All sorts that I’ve gathered over the years. I have some heavy cast pieces that I’ll probably never you that you are welcome to. They have bolting holes already in them. Keep me in mind for those as well if we ever cross paths. 1 Share this post Link to post Share on other sites
WHGuy413 2,683 #19979 Posted September 19, 2023 Knowing winter is going to sneak up on us sooner rather than later I spent a little time in the garage moving things around. Alex and I are going to make a push to get all the show tractors put away and the garage cleaned up this weekend. It would be nice to have a garage that’s organized chaos instead of just chaos that it’s in now. We both have a tractor project we want to work on in the near future. I’d like to get mine done before snow flies so I can use the 12 auto around the yard and then I will probably use it as my snow plow tractor or designate it as my fire wood hauler for the winter. For those who have garages and still work on stuff in the cold months what are you using for a heat source? 2 Share this post Link to post Share on other sites
ebinmaine 67,445 #19980 Posted September 19, 2023 7 hours ago, WHGuy413 said: For those who have garages and still work on stuff in the cold months what are you using for a heat source? Two things: 1. CHECK WITH YOUR INSURANCE COMPANY. Ours will NOT cover a fire caused by an open flame heater in a garage. 2. Ask the local fire inspector what your own State and local codes are. There are legalities behind certain types of heaters in certain areas. That said, We've used propane small area heaters, electric oil filled radiators electric blowers. Biggest thing is not the heater. Insulation and airflow. Stop air movement through the walls. 4 Share this post Link to post Share on other sites
SylvanLakeWH 25,547 #19981 Posted September 19, 2023 I have an electric radiant heater mounted above work area. Uninsulated so it helps but not very warm except right under it... 4 Share this post Link to post Share on other sites
Colby G 233 #19982 Posted September 19, 2023 We have a little workshop, so we just use a wood stove. 1 Share this post Link to post Share on other sites
Evguy 556 #19983 Posted September 19, 2023 I’m using a 1954 oil furnace that has a blower, it will burn kerosene or diesel. It will run me out of a 2 car garage with very little insulation. 2 Share this post Link to post Share on other sites
peter lena 8,617 #19984 Posted September 19, 2023 @Handy Don think I would enhance / verify the front wheel bearing / lubrication se up , would add needed washers to eliminate , wheel , side to side shucking , also ensure the grease will stand up . when wheel bearings and initial set up have any horizontal play , the bearing mount point can quickly , wash out / distort . seen that on many w/h tractors. most of the used stuff I see is like a train wreck, only good for parts . pete Share this post Link to post Share on other sites
rjg854 11,361 #19985 Posted September 19, 2023 12 hours ago, WHGuy413 said: For those who have garages and still work on stuff in the cold months what are you using for a heat source? I have a radiant oil-filled electric heater that I use . My horse barn is well insulated, it's 14X18 and the ceiling isn't very high, it's a shed roof so it's 6' high in the back and 8' high in the front. Most of the time I don't have to use it, but should it down-right chilly, I'll plug it in about an hour before I want to work out there. It works good enough to take the chill off. And after a while depending how long I'm out there, I have to shut it off. I don't remember using last year, it was so mild of a winter. 2 Share this post Link to post Share on other sites
Handy Don 12,215 #19986 Posted September 19, 2023 2 hours ago, peter lena said: I would enhance / verify the front wheel bearing / lubrication se up New bearings and all snugged up when I rebuilt/refurbed this machine in 2022. Will be adding a shim washer or two to the axle pivot pin next time I have it on the stand--just a bit too much play there. 1 Share this post Link to post Share on other sites
peter lena 8,617 #19987 Posted September 19, 2023 @Handy Don glad you are on that , its a slight firming up , but makes a big difference on hub wear . last horse I went thru , was so neglected / worn , it was a wonder anything functioned , back of dash , was packed with grass , corrosion , shorted wiring , belt drive set up was worn/ wobbly , frozen in rust . deck rotted thru. rear bagger , spent 3 weeks on it , started instantly , lights worked , sold bagger unit separately for parts , trans fluid flush / change , partial paint touch up . also did a RISLONE ZINK , run time on that , was a smoker when I got it , hours on the engine , 2 oil changes , zink , no smoke at all, engine said THANK YOU ! also went thru fuel swamp . gave the new owner a service sheet , recommendations , probably sitting in tall grass , out of gas / oil . what we do , pete 1 Share this post Link to post Share on other sites
squonk 41,076 #19988 Posted September 19, 2023 My C160 has a seat raised on springs and my 250 L Bees make for a bit of a teeter totter ride. Add some of the normal cracks a 46 yr old fender pan you get some creaks and groans. Add a couple 3/16 thick strips to spread the load. Made a huge difference on the ride. 5 1 Share this post Link to post Share on other sites
WheelHorse_Kid 355 #19989 Posted September 21, 2023 (edited) I got 5 of my tractors and took pictures of all of them before we put some of them away for the winter. Edited September 21, 2023 by WheelHorse_Kid 2 10 1 3 Share this post Link to post Share on other sites
314-8 wheel horse 7 #19990 Posted September 22, 2023 Rebuilding kholer k321 short block and building adapter for long block oil pan. So it fits on 314-8. 6 1 Share this post Link to post Share on other sites
ebinmaine 67,445 #19991 Posted September 22, 2023 6 hours ago, 314-8 wheel horse said: Rebuilding kholer k321 short block and building adapter for long block oil pan. So it fits on 314-8. This is something you're creating? Machine shop ? Share this post Link to post Share on other sites
8ntruck 6,998 #19992 Posted September 23, 2023 Got Morgan, the 14-8 out to move the sailboat & trailer down to the lake. Launched the sail boat, and took the trailer back up to the road. No wind to speak of today, so I ended up mowing the lane with Morgan. Got a raw gas smell just after shutdown. Gas smell goes away shortly after closing the gas petcock. Kind of indicates a leak somewhere between the petcock and carb to me. Have to chase that down pretty soon. 3 Share this post Link to post Share on other sites
Tuneup 1,433 #19993 Posted September 25, 2023 800 pages so I had to post. Hit the shed yesterday and moved the wreck 520H (to be restored this winter if I get to it - bought it for its 48SD) to the back and the 76 C120 to the front. Added air and the battery charger and then the day got away from me. That old beast hasn't run this year so I wanted to give it an exercise. Tonight, it'll happen. That 520 is longing for TLC. The 120 will sit in the mechanically sound but Alabama backyard condition until it goes to child #3. 4 Share this post Link to post Share on other sites
Ed Kennell 38,155 #19994 Posted September 25, 2023 On 1/15/2018 at 10:28 AM, Ed Kennell said: Ok, maybe this will get us back on topic. Today I made a safety light and pole for the 312 plow tractor . 800 pages and creeping up on that 20,000 post mark since 01/15/2018. Thanks Karl for allowing us to share What We Did To Our Horse Today 1 3 2 Share this post Link to post Share on other sites
Tuneup 1,433 #19995 Posted September 25, 2023 12 hours ago, Tuneup said: 800 pages so I had to post. Hit the shed yesterday and moved the wreck 520H (to be restored this winter if I get to it - bought it for its 48SD) to the back and the 76 C120 to the front. Added air and the battery charger and then the day got away from me. That old beast hasn't run this year so I wanted to give it an exercise. Tonight, it'll happen. That 520 is longing for TLC. The 120 will sit in the mechanically sound but Alabama backyard condition until it goes to child #3. 120 fired right up thanks to that marine bulb. Ran out into the yard and mowed for 3 minutes before 'whack-whack-whack! Time for an RD belt. Must be something in there that killed it. Weekend inspection in the plans. 2 Share this post Link to post Share on other sites
WHGuy413 2,683 #19996 Posted September 26, 2023 Believe it or not I found my garage. I finally got my friends C-105 that I’ve had here for way to long, to drive out of the garage under its own power. I had to do so much to it from wiring, starter, key switch, carb, fuel lines, fuel pump. Might as well as rebuilt it from the ground up. Unfortunately the tractor drove 50 feet and the drive belt exploded. Never seen one come apart like this one did. Tracking down another one tomorrow hopefully and giving that tractor the old heave ho out the door. Alex and I then put our sights figuring out his c-121 clutch/drive belt issue. I determined someone welded the tab on the end of the rod that goes through the frame to the idler pulley and it was in the wrong spot. The angle was all wrong allowing the idler to come in contact with the drive pulley when the clutch was out with the old belt on. When he installed the correct belt (7473) it wouldn’t stop spinning and was super tight. Once we cut the welded rod and replaced it with one off my shelf everything went back together with the brand new belt and he drove it around the yard and said it’s better than ever. now time to clean up the chaos sweep it out. Organize some parts and move some more projects in. 6 3 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #19997 Posted September 26, 2023 This afternoon my newly assembled “308” got a trans fluid swap. Nasty stuff came out (I’ve seen worse). This gear oil only has like 15-20 minutes of use! Luckily NAPA has this on sale for $5.99 8 2 Share this post Link to post Share on other sites
Handy Don 12,215 #19998 Posted September 26, 2023 Wheel chocks! (I don’t trust parking brakes and I want to be able to shift the gears while draining.) 1 Share this post Link to post Share on other sites
ebinmaine 67,445 #19999 Posted September 26, 2023 16 minutes ago, Handy Don said: Wheel chocks! (I don’t trust parking brakes and I want to be able to shift the gears while draining.) As long as that wooden block is secured to the tractor I'd prefer NOT to use wheel chocks. The large rubber tires will be able to roll as the front is raised easier than the steel wheels of the jack. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #20000 Posted September 26, 2023 19 minutes ago, Handy Don said: I want to be able to shift the gears while draining.) Shift gears while draining? Never heard about doing that before 1 Share this post Link to post Share on other sites
