ebinmaine 66,576 #19601 Posted July 22, 2023 31 minutes ago, nyquil junkie said: By roll pins I could mean nails...depends on how the search goes. I'd absolutely do the same thing... Temporarily. Just keep in mind a nail is MUCH softer than a proper roll pin. Share this post Link to post Share on other sites
davem1111 1,983 #19602 Posted July 22, 2023 On 7/21/2023 at 1:15 AM, ohiofarmer said: The tall thing you see is up the hill on Eaton-Lewisburg road close to the gravel plant. I am not sure what it is. The duramax plant is located on the Arlington road exit at Brookville back where the shoe warehouse was. That land used to be a turf grass farm and that is probably why it converted to commercial property..I live between 5 and ten miles from every place you mentioned in the southeast corner of Darke County. I would say that both Phillipsburg and Arcanum are each five miles away as is Lewisburg.and t Of course route 40 is also the National Road that makes Lewisburg have some of the older homes in the immediate area. There are two covered bridges a few miles from Lewisburg and a third that rests in the city park moved from somewhere. I love that area and have fond memories of being there - it has a slow, relaxed vibe to it, but don't think I'll ever live there again. My next move will be most likely to somewhere with some mountains - I was just in the Smokey Mountains and really love it there. I've been to family reunion picnics I believe in the park where that covered bridge is, and the one with the old train car or caboose (unless they are the same park). But I think they're kind of across the road from each other. One fond memory I have is of the Lewisburg Sesquicentennial when I was younger. I think my grandpa drove a tractor in the parade. Also, there used to be steam tractor shows, or steam tractors at a "general" tractor show, or maybe in some parades, but I doubt they took them down the street in town. That was a long time ago.... Share this post Link to post Share on other sites
Wheelhorse#1 1,601 #19603 Posted July 23, 2023 On 7/21/2023 at 9:23 PM, 8ntruck said: Rye. The stuff can work as a carb cleaner as well I hear. 1 Shot to gallon of gas ! lol 3 Share this post Link to post Share on other sites
Colby G 230 #19605 Posted July 24, 2023 Where can I buy parts for a 1973 No Name 8 HP 4 Speed? Share this post Link to post Share on other sites
TJ5208 1,824 #19606 Posted July 24, 2023 Got a deck put on the 520-8 3 3 Share this post Link to post Share on other sites
ebinmaine 66,576 #19607 Posted July 24, 2023 7 hours ago, Colby G said: Where can I buy parts for a 1973 No Name 8 HP 4 Speed? What're you looking for? Share this post Link to post Share on other sites
rjg854 11,241 #19608 Posted July 24, 2023 11 hours ago, Colby G said: Where can I buy parts for a 1973 No Name 8 HP 4 Speed? You could call A-Z Tractor and see what he might have. 1 Share this post Link to post Share on other sites
JPWH 5,983 #19609 Posted July 24, 2023 What parts are you looking for. I have a few parts from a73 no name. Share this post Link to post Share on other sites
Colby G 230 #19610 Posted July 24, 2023 (edited) 29 minutes ago, JPWH said: What parts are you looking for. I have a few parts from a73 no name. I am looking for an original headlight cover, and id also like a hood ornament. Edited July 24, 2023 by Colby G Share this post Link to post Share on other sites
JPWH 5,983 #19611 Posted July 24, 2023 I have both but neither are in great shape. Share this post Link to post Share on other sites
Colby G 230 #19612 Posted July 24, 2023 27 minutes ago, JPWH said: I have both but neither are in great shape. Could you show me a picture? Share this post Link to post Share on other sites
JPWH 5,983 #19613 Posted July 25, 2023 I can when I get home from work tomorrow evening. I usually get home around 5:30. Share this post Link to post Share on other sites
Colby G 230 #19614 Posted July 25, 2023 2 minutes ago, JPWH said: I can when I get home from work tomorrow evening. I usually get home around 5:30. Ok, thanks! Share this post Link to post Share on other sites
nyquil junkie 225 #19615 Posted July 25, 2023 I found a new roll pin. It works for now. I de greased the disk and it catches better. Then it was carb time. The engine had to be run at half choke all the time and didn't want to start and... sometimes was puking gas out of the overflow. So I just bought a new $25 chinesium special on Amz. What can go wrong with that Idea? I've bought other cheapniese carbs and they mostly worked, some needing a little adjustment. Not this one... Huffed black smoke on startup, would huff black smoke under a load if it was more than half throttle. I tweaked it a little, stil wasnt right. I put the new set of coils on it, because the old ones were msmatched and really old crusty beat up things that I thought would help the problem. After a couple take aparts and put togethers, I gave up and stripped the old carb down and cleaned it. it had a fair amount of crud and clogs... I flushed and cleaned it all out. Stuck it back on the engine and there ya go.... runs like a new one. No more misses, smoke chokes or hard starts. As far as I can tell the china carbs main jet was way too big and the idle jet screw didnt feel right. Something in that new carb wasn't right at all. The old carb back in place. The Old Nikki carb trumps General Tso's POS carb. Next up.. a new hydro filter and maybe some new fluid. The hydrostat has an annoying whine, louder than the normal not so annoying whine it had. When my skid steer does that it time to change the filter. We'll see how it goes. 6 Share this post Link to post Share on other sites
kpinnc 11,499 #19616 Posted July 25, 2023 43 minutes ago, nyquil junkie said: We'll see how it goes. I see you're running a Vanguard. I have several, and they are very good engines. Far superior to any of the "current" engines out there. Not as bulletproof as a Kohler K -series or Magnum, but as close as you can get... One issue with the Vanguards: the gaskets are the weak spot, and depending on which one goes can create issues that appear to be carb problems. When a gasket fails (typically a head gasket), the case gets overpressure and makes the pulse pump flood the carb. Point being, if you have a carb problem that makes no sense, check both the head haskets as well as the oil pan gasket on the PTO side. I've had two where that was all that was wrong, and it took a long time to figure it out. 5 Share this post Link to post Share on other sites
ebinmaine 66,576 #19617 Posted July 25, 2023 21 minutes ago, kpinnc said: gaskets You feel like I should change mine as a preemptive? 1 Share this post Link to post Share on other sites
kpinnc 11,499 #19618 Posted July 25, 2023 3 hours ago, ebinmaine said: You feel like I should change mine as a preemptive? No. Most are good, just sometimes a gasket failure shows up with strange symptoms. I wouldn't expect a leaky gasket to make the carb drown out, but it does. Later Vanguards had improved head gaskets with a ring around the cylinder. 2 Share this post Link to post Share on other sites
nyquil junkie 225 #19619 Posted July 25, 2023 This one has an electric fuel pump... and the repairs seem to have cured all its ills. So far. But I will keep the gasket thing in mind. Thanks! The new hydro filter took all the whine away and now it even has more power than before. The filter was dated 6-30-1 I cant read the last number..so at best this thing has had the same filter in it since 2019. I think its ready to go to the barn and dig some manure sand pack. I'd give it a bath but considering where its headed... I don't see the point. 1 2 Share this post Link to post Share on other sites
WHX?? 48,037 #19620 Posted July 25, 2023 Painted a air cleaner... and polished my nails ... 9 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,234 #19621 Posted July 25, 2023 @WHX?? Hope the air cleaner has a better color of red. Your nail looks like red oak stain. 5 Share this post Link to post Share on other sites
WHX?? 48,037 #19622 Posted July 25, 2023 Wow ... and I was always wondering who did the farmer fixes on horses come thru my ranch... my neck is sore from shakin my head... 1 1 1 1 Share this post Link to post Share on other sites
WHX?? 48,037 #19623 Posted July 25, 2023 (edited) 20 minutes ago, elcamino/wheelhorse said: @WHX?? Hope the air cleaner has a better color of red. Your nail looks like red oak stain. Air cleaner looks much better Waldo... BTW what kind of junk did you sell me @Pullstart...I want my money back...... what's wrong with this pic... round hood mind you! OK a better view... I shoulda knew this wasn't gonna work so I'll blame it on @Achto Kev... Edited July 26, 2023 by WHX?? 1 2 1 Share this post Link to post Share on other sites
Pullstart 62,188 #19624 Posted July 26, 2023 854 air cleaner on a 701? My apologies I’ll have to take the engine back with it! 1 3 Share this post Link to post Share on other sites
kpinnc 11,499 #19625 Posted July 26, 2023 2 hours ago, WHX?? said: Painted a air cleaner... and polished my nails Happiness is red in your handkerchief! 2 5 Share this post Link to post Share on other sites
