ebinmaine 80,600 #19351 Posted June 27, 2023 2 hours ago, spitfire said: This is a 73 model, on my 69 its in 3 colors and it doesnt say unidrive.. That decal looks like the one on Trina's 867. I'm not positive but I don't think there was a Commando in '73. 1968 to 72. Have you verified the tractor model number on the tag? Also, do you have the air deflector for the top of the engine? It's a necessary piece for keeping that engine cool while running. Share this post Link to post Share on other sites
squonk 48,059 #19352 Posted June 27, 2023 1 hour ago, ebinmaine said: That decal looks like the one on Trina's 867. I'm not positive but I don't think there was a Commando in '73. 1968 to 72. Have you verified the tractor model number on the tag? Also, do you have the air deflector for the top of the engine? It's a necessary piece for keeping that engine cool while running. 73 had the Commando 800. Remember Eric, he's on the other side of the Pond so any model decal combo is possible over there. Share this post Link to post Share on other sites
ebinmaine 80,600 #19353 Posted June 27, 2023 15 minutes ago, squonk said: 73 had the Commando 800. Remember Eric, he's on the other side of the Pond so any model decal combo is possible over there. Oh oh oh oh oh. I didn't catch that part. Thanks Mike. Share this post Link to post Share on other sites
Lee1977 7,764 #19354 Posted June 27, 2023 (edited) Try 1-0130 1973 Commando 800 4 speed Kohler K1810-30451D 8HP transmission WH 5085 There one on the list I got some where, The number on Toro parts has the number as a 8 HP 4 speed There is a 1-0120 8 HP 4 speed listed right above it same Kohler and transmission. Two 8 HP 4 speeds below with Tecumseh engines 1-0276 and 1-0277 Edited June 27, 2023 by Lee1977 Share this post Link to post Share on other sites
Sparky-(Admin) 26,297 #19355 Posted June 27, 2023 Idler pulley swap on the B-80 happened tonight… much quieter. Why didn’t I snap a pic with the new pulley on Thanks Brian (K&B Horse Parts) @76c12091520h 6 2 Share this post Link to post Share on other sites
TonyToro 1,190 #19356 Posted June 28, 2023 Things were happening this afternoon with the B-60 and @TonyToro Jr. 4 3 Share this post Link to post Share on other sites
ineedanother 2,861 #19357 Posted June 28, 2023 18 minutes ago, TonyToro said: Things were happening this afternoon with the B-60 and @TonyToro Jr. That looks like a tap and die set. Did someone snap a bolt by chance??? 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,535 #19358 Posted June 28, 2023 12 hours ago, ineedanother said: That looks like a tap and die set. Did someone snap a bolt by chance??? No the carb got replaced and the bolts wouldn’t go in for the air filter assembly. So we just re tapped them. 3 Share this post Link to post Share on other sites
Handy Don 17,458 #19359 Posted June 28, 2023 2 hours ago, TonyToro Jr. said: No the carb got replaced and the bolts wouldn’t go in for the air filter assembly. So we just re tapped them. Likely the new carb’s holes were metric threaded 3 Share this post Link to post Share on other sites
ebinmaine 80,600 #19360 Posted June 28, 2023 17 hours ago, TonyToro said: Things were happening this afternoon with the B-60 and @TonyToro Jr. 4 hours ago, TonyToro Jr. said: No the carb got replaced and the bolts wouldn’t go in for the air filter assembly. So we just re tapped them. Send me that carb and I'll rebuild it for you. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,535 #19361 Posted June 28, 2023 4 hours ago, Handy Don said: Likely the new carb’s holes were metric threaded Yeah that’s what we were thinking. 1 Share this post Link to post Share on other sites
TonyToro 1,190 #19362 Posted June 29, 2023 7 hours ago, ebinmaine said: Send me that carb and I'll rebuild it for you. Funny thing is the original owner gave us 2 or might be 3 carburetors. I just went with what was on the tractor to get it running. I haven’t opened any of the carburetors yet. We were talking last night about original equipment on this tractor. I agree that a factory original needs to be back on it. 1 Share this post Link to post Share on other sites
Ed Kennell 47,254 #19363 Posted June 29, 2023 Had to move a few horses to get the crabbing boat out. So, I hosed everything off. 3 6 Share this post Link to post Share on other sites
ranger 1,862 #19364 Posted June 30, 2023 Sorry no pics🫣, did a bit of backlash/play removing on the PTO linkage on the C161. The “Hoop” has a small amount of wear at the pivot points, but the triangular arm has more. The trunnion will be replaced by a “Rose”/Heim” joint, as per @peter lena suggestion. The shaft running in the bell thrust bearing requires shimming to remove excessive endfloat. The 3/8” screw for the fixed pivot for the operating arm is being replaced by an M10 bolt with an unthreaded portion under the head. This takes up the wear in the holes, and ensures the arm pivots on a non threaded section. The well worn hole in the arm was repaired by heating around the hole, and then “Forging” the hot metal around the hoop, until the fit was tight. A quick touch up with a flat and a round file and the fit was restored, (no welding/drilling/bushing required). The fit of the hole on the “unworn” end of the hoop was very tight, but after “persuading” the arm down to it’s usual position, it turns freely with minimal play! 4 Share this post Link to post Share on other sites
dotcomdz 49 #19365 Posted June 30, 2023 I finally got my B-80 back from a sour deal, this how it was returned, then something in my head said drain the gas and oil because both smelled like paint thinner and I knew when it left both were fine. Now does that look like Grey primer floating around or what🤷🤬 anyways cleaned it all up flushed everything real well and running like a dream, probably one of the best running old kohlers I've ever found in the wild. So anyways this gonna be my keeper 😁 1 3 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,297 #19366 Posted June 30, 2023 @dotcomdz Are you saying you think it was sabotaged? Done intentionally? 1 1 Share this post Link to post Share on other sites
peter lena 10,046 #19367 Posted June 30, 2023 @dotcomdz seen so many neglected , thrashed horses , just don,t know how anyone could do that . guy,s got issues . rotella 30 wt , glad you got it back . pete 1 Share this post Link to post Share on other sites
peter lena 10,046 #19368 Posted June 30, 2023 @ranger norm note the type of pin attatchment on my pto swing point , that horizontal pin is held in place , with that spring curve , found that type at a hardware store , once I used it , added it to the other horses , easy on off , eliminates a bolt / nut for quick access , also added a lower spring pull to that , cross pin , to eliminate realted noise , smooth/ quiet . pete Share this post Link to post Share on other sites
Ed Kennell 47,254 #19369 Posted June 30, 2023 Got started on the Ber Vac redo. 3 11 Share this post Link to post Share on other sites
dotcomdz 49 #19370 Posted June 30, 2023 5 hours ago, Sparky said: @dotcomdz Are you saying you think it was sabotaged? Done intentionally? How else dirty paint thinner get in the gas and oil, when before it left my house I had been over it well removed the gas tank and cleaned it and changed the oil to make sure it was a solid machine first 🤷 1 Share this post Link to post Share on other sites
squonk 48,059 #19371 Posted July 1, 2023 I had put a smaller transmission pulley on the 1467 Special for the show cruise. Of course as it always happens the throttle decided to stop locking as I drove it off the trailer. I knew it would be a PITA in the cruise to hold the throttle open. And a clothes pin vice grip idea was out because it would be too fast for conditions (traffic/kids). Bought a new cable at the show but I really didn't want to spend time there working instead of visiting/ buying. So today I removed the cable and took it apart and recrimped the ferrule thingy and got it locking again.I'll save the new cable for another time when it's needed. 3 5 Share this post Link to post Share on other sites
Ed Kennell 47,254 #19372 Posted July 1, 2023 (edited) 3 hours ago, squonk said: clothes pin vice grip idea was out because it would be too fast for conditions 1pin= 1200 rpm 2pin=2400rpm 3pin=wot You could use a clothespin container like the one in Mrs Ks laundry room. Tie the Old Bag to the back of your seat. Edited July 1, 2023 by Ed Kennell 1 9 Share this post Link to post Share on other sites
Sparky-(Admin) 26,297 #19373 Posted July 2, 2023 Good rainy day project while I look at my fishing boat sitting in the rain . My 36RD needed some attention. New idler pulley from K and B Wheel Horse Parts @76c12091520h as well as a good overall greasing. Just an FYI…I sent K and B a PM a month before the show with a list of parts I wanted. Wanted new and not used. I got back an email saying all were available and the pricing. Said great, I’ll pick it all up at the show. When I show up at the K and B vender spot at the WHS there were all my parts in a bag ready to go! Great service! Highly recommend Ken and Brian! 4 7 Share this post Link to post Share on other sites
squonk 48,059 #19374 Posted July 2, 2023 (edited) 1 hour ago, Sparky said: When I show up at the K and B vender spot at the WHS there were all my parts in a bag ready to go! Great service! Highly recommend Ken and Brian! Looks like you forgot to order deck wheels! Yes K & B are top notch! Chase TheBeagle on FB! Edited July 2, 2023 by squonk 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,297 #19375 Posted July 2, 2023 4 minutes ago, squonk said: Looks like you forgot to order deck wheels! These deck wheels look rough but spin just fine. Pulled em off today and greased them up. No zerks on these .. I swear my others have zerks. I have a few new ones on the shelf but I just can’t bring myself to install em yet. 1 3 Share this post Link to post Share on other sites
