Ed Kennell 40,318 #19201 Posted June 8, 2023 (edited) On 6/8/2023 at 2:50 PM, BrianKoch said: It appears I have lost my mower deck lift rod … What is the length Brian ? Edited June 8, 2023 by Ed Kennell Share this post Link to post Share on other sites
johnnymag3 2,559 #19202 Posted June 8, 2023 On 6/8/2023 at 3:58 PM, Ed Kennell said: What is the length Brian ? Same question...I have a few sizes Share this post Link to post Share on other sites
OutdoorEnvy 1,732 #19203 Posted June 8, 2023 Well got in the first mow in the woods with the C100. It did good and made the work so much easier than a push mower I would use. It doesn't look steep and hilly but it is when you're pushing a mower. This should be the go to rig for this job from now on. 42" SD deck. Also did a bit of root clearing with the Barco FSS Pulaski axe. Those are just handy if you've never used one. I use this one all the time. Needed to take out a few bulging roots to not ruin the deck or blades. All in all went well and came out looking like a courtyard! A couple before pics and after! 8 5 Share this post Link to post Share on other sites
ranger 1,773 #19204 Posted June 9, 2023 A few more pics of the “Repaired” mower deck pulley. Machining almost finished. I’m now waiting for some M4- 10.9 grade csk hd screws then I can clean it up and fit it. 6 10 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #19205 Posted June 9, 2023 All I can say is WOW. Great job. 1 Share this post Link to post Share on other sites
ranger 1,773 #19206 Posted June 9, 2023 On 6/9/2023 at 4:00 PM, elcamino/wheelhorse said: All I can say is WOW. Great job. On 6/9/2023 at 4:00 PM, elcamino/wheelhorse said: All I can say is WOW. Great job. Thanks for the compliment 👍It was a case of, I had to do something, I haven’t been able to find a replacement over here🇬🇧 (Lathes and Mills are such useful tools at times). Doug. 2 Share this post Link to post Share on other sites
Bluerubicon08 32 #19207 Posted June 10, 2023 Well................I have officially been bitten by the Red Horsefly. Just won this at an auction! Starts, runs, has a "weak" battery, and comes with plow, chains and mowing deck! This makes # 2 3 5 Share this post Link to post Share on other sites
D_Mac 9,052 #19208 Posted June 10, 2023 (edited) Pulled the 875 out today. Turned the gas on at the petcock on the sediment bowl and guess what happened ??? Yup.... started leaking like crazy. I heard they are known to leak but I never had an issue with it. Anyone know exactly what I need to replace it with a simple shut off valve. Seem to remember trying to swap it out once but had wrong fitting for the tank. Think I remember I had a fitting that was suppose to screw into the tank but I needed one to screw onto the tank. Edited June 10, 2023 by D_Mac 1 Share this post Link to post Share on other sites
rjg854 11,867 #19209 Posted June 10, 2023 Try to tighten the nut on the shut-off valve a bit. Another idea is they like to be either all the way in or all the way out. 3 Share this post Link to post Share on other sites
ebinmaine 70,408 #19210 Posted June 10, 2023 On 6/10/2023 at 2:05 PM, D_Mac said: Pulled the 875 out today. Turned the gas on at the petcock on the sediment bowl and guess what happened ??? Yup.... started leaking like crazy. I heard they are known to leak but I never had an issue with it. Anyone know exactly what I need to replace it with a simple shut off valve. Seem to remember trying to swap it out once but had wrong fitting for the tank. Think I remember I had a fitting that was suppose to screw into the tank but I needed one to SCREW ONTO THE TANK. The ones we have here are 1/8 NPT with the tank having the FEMALE thread. Double check to see if yours has a PO installed adapter. On 6/10/2023 at 2:09 PM, rjg854 said: Try to tighten the nut on the shut-off valve a bit. Another idea is they like to be either all the way in or all the way out. Also could disassemble and remove the valve. Take the oring to your local hardware store and get a new one. Share this post Link to post Share on other sites
ebinmaine 70,408 #19211 Posted June 10, 2023 On 6/10/2023 at 1:54 PM, Bluerubicon08 said: This makes # 2 Welcome to the addiction. We are here to support you.... Buying more tractors. How's your storage space? 2 Share this post Link to post Share on other sites
squonk 42,370 #19212 Posted June 11, 2023 Painted the wheels on 953 and packed the wheel bearings with new seals. 3 6 Share this post Link to post Share on other sites
Handy Don 13,272 #19213 Posted June 11, 2023 (edited) On 6/10/2023 at 4:31 PM, ebinmaine said: Also could disassemble and remove the valve. Take the oring to your local hardware store and get a new one. @D_Mac On my K181 the gasket between the glass bowl and the housing had dried out and was no longer flexible. From a gasket material assortment I’d bought earlier on the jungle site, and using leather-working tools, I cut myself a new one from fuel-rated rubberized cork. Edited June 11, 2023 by Handy Don 3 Share this post Link to post Share on other sites
Stormin 9,983 #19214 Posted June 11, 2023 Mower deck blade drive belt on the 48" deck, decided to call it a day after the first cut round the green. Fortunately I'd got a couple in stock a while ago as I knew it wasn't going to last much longer. Finished the green, then did the lane verges and mowed SWMBOs dog walk down the bridleway. Later mowed the widows back field. 6 Share this post Link to post Share on other sites
ebinmaine 70,408 #19215 Posted June 11, 2023 Been a busy weekend as usual 'round these parts. Yesterday in between the electrician being here we started moving some rocks out of the space that need fixing and filling. All hand work so we could burn a calorie or 2. Today the Trina person and her Momma worked hard at cutting and splitting some firewood. I ran the chainsaw for a bit as well then switched over to hauling the wood out from by the garden up to the edge of the driveway where the woodshed is. Pulled 2 loads with the C160 Cinnamon Horse and Agri fab 17 cube trailer. Trina found some friends while out clearing the tall grass so we could work by the garden. 10 1 Share this post Link to post Share on other sites
Bluerubicon08 32 #19216 Posted June 11, 2023 On 6/10/2023 at 4:33 PM, ebinmaine said: Welcome to the addiction. We are here to support you.... Buying more tractors. How's your storage space? I am using covers for the time being. 2 Share this post Link to post Share on other sites
JPWH 6,250 #19217 Posted June 12, 2023 Installed the repaired gas tanks on the 2 854's. Built a hitch for Hank and tested the bifold trailer ramp gate. 4 7 Share this post Link to post Share on other sites
Handy Don 13,272 #19218 Posted June 12, 2023 I’d love to have a seat back like this (when I built the “seat riser” I made a provision for adding a back). However, I realize that it’d get in my way for my most frequent use--wnen I have the 36” mower on, there is no way to get close so I sit on the seat sideways and then swing my leg over (making sure to have the lift lever positioned FORWARD first. 5 Share this post Link to post Share on other sites
Tractorhead 9,087 #19219 Posted June 12, 2023 On 6/12/2023 at 12:48 AM, Handy Don said: I sit on the seat sideways and then swing my leg over (making sure to have the lift lever positioned FORWARD first. Is that the thing called Wheelhorse Yoga? 😄 6 Share this post Link to post Share on other sites
Handy Don 13,272 #19220 Posted June 12, 2023 On 6/12/2023 at 4:01 AM, Tractorhead said: Is that the thing called Wheelhorse Yoga? 😄 I've seen folks step on the mower deck when getting onto the Horses without footrests, but I put too much time into refurbishing that deck to take a chance on breaking it with my weight! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,929 #19221 Posted June 12, 2023 Hauled home a non-running 1992 416-8 (Onan) this weekend. Started messing with it today, pretty sure the tank was mostly water. Drained the tank, removed it, cleaned it and everything around it. Yanked the original grommet and fuel valve, if I find fuel line tomorrow it’ll all get replaced and hopefully I’ll finally hear it run. 5 7 Share this post Link to post Share on other sites
ebinmaine 70,408 #19222 Posted June 12, 2023 @Sparky You're doing some good justice to that rig! 1 Share this post Link to post Share on other sites
kpinnc 13,515 #19223 Posted June 13, 2023 On 6/12/2023 at 11:39 PM, Sparky said: Hauled home a non-running 1992 416-8 I see an intact shifter boot. Always a good sign! 4 Share this post Link to post Share on other sites
OutdoorEnvy 1,732 #19224 Posted June 13, 2023 @Sparky nice grab! And good start on bringing it back to life. Guess we’ll miss out on the thread titled something like “hard to start and only runs on starter fluid”. Looking forward to how it turns out! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,929 #19225 Posted June 13, 2023 On 6/13/2023 at 1:29 AM, kpinnc said: I see an intact shifter boot. Always a good sign! Yea…except when I pulled the trans dipstick it had a water/gear oil mix. Once I know it’s a good running rig I’ll be tackling the fluids for sure. 1 1 Share this post Link to post Share on other sites
