Ed Kennell
What have you done to your Wheel Horse today?
pfrederi
7 minutes ago, Pullstart said:
I needed to do some soil checks to see how dry the field has become.  This plow was set up for cruising behind a 953, but Putt Putt didn’t mind either!
It was dry enough to pull the camper out!  I have to drive about 1/8 mile or so to the field entrance to easily pull it to the road, then the driveway.
  Where are the rocks????
  • Haha 5
ebinmaine
And hills...
  • Haha 3
Pullstart
5 hours ago, ebinmaine said:
And hills...
I keep telling you I’m a flat lander!
There were a couple softball sized ones..
D_Mac
Blew the dust off of the 1075 and the 856. 1075 Is going to need looking into. Runs great for a while the starts cutting out. I added a license plate and rubbed some boiled linseed oil on them both.
Edited by D_Mac
  • Like 5
  • Excellent 2
TonyToro
24 minutes ago, kpinnc said:
Little man drove the 314-8 around today. I gotta get him some pedal extensions! :D
The new engine is so smooth and quiet! Upgrading the transmission next to a 8-pinion.
I have a couple sets of extensions I made for @TonyToro Jr. I can send them to you or send pictures.
SylvanLakeWH
I can send pictures.
Could you post a pic or two here? Would be interested in seeing what you did...
kpinnc
I'm definitely curious how you made them.
He does better with a hydro of course, until he speeds up... :rolleyes:
spitfire
Yesterday we drove the b125 for the first time. He jumps out 3rd and reverse 😕
We changed the engine with a 12hp power build, repaired starter and brakes and  all electrics.
Edited by spitfire
SylvanLakeWH
@TonyToro Jr. thx!
That is slick! :clap:
spitfire
Prepairing for our first ride sunday, we go to church on Saint Christoph day for benediction of vehicles.
  • Excellent 3
spitfire
Is this to close to the exhaustpipe for a fuel line?
Where is it on stock C-165 s?
WHX??
12 hours ago, Achto said:
have to look into why it starts hard when it's cold
Maybe I should just come get it...:ph34r::lol:
I think your fine with that clearance @spitfire
Edited by WHX??
  • Haha 1
c-series don
On 4/1/2023 at 8:55 PM, Monstrosity said:
c-series don
@spitfire
The fuel line should go under the flywheel shroud and up to the fuel pump, not up over the head.
spitfire
Inside you mean?
The way i did it is under on the exterior, it just look a bit bizar
Edited by spitfire
Monstrosity
5 hours ago, TonyToro Jr. said:
@kpinnc @SylvanLakeWH This is the foot extension. and it’s adjustable for height.
May have to steal this idea and design!!
Blasterdad
It goes under the shroud back further, there should be two hose clamps bolted on it at about 4 & 8 o'clock.
IMG_0524.JPG.687096fe3d18a3c2c10ceb0a7b86eda3.JPGIMG_0458.JPG.d0b29d994045c6a12ff0672a6f593638.JPGFSAE7177.JPG.2039f417f45d0feedde625b459ff462e.JPG
D_Mac
Worked on all 3 of my Horses. The 1075 got an oil change. The 875 was losing spark intermittently. Wound up being the wire that goes from the points to the coil. The terminal end was broken off. After that adjusted the carb a little, back to running great. The 856 got a boiled linseed oil rub down and I monkeyed with the seat a little. Seat cover is all tore up and the padding is gone so I added a little pad under the cover. Will do till I find a new seat. I also would like to rebuild this fuel pump off the 1075. Has the primer lever on it. Having trouble finding a kit for it. Anyone have a link for one? Hate to put a plastic pump on it. This one leaks a little.
  • Like 4
ebinmaine
Have you sent a PM to @buckrancher ?
I'm not sure if the diaphragms he sells will work here..... (?)
Monstrosity
Who doesn't love new rubber 😜 also did some lettering 20230415_191420.jpg.9f7e5115272bcf0bb3d8eec34ece2cce.jpg20230415_204540.jpg.57cc02a01176422beb625420979832e9.jpg
  • Like 5
  • Excellent 2
