rjg854 11,871 #18602 Posted March 18, 2023 On 3/18/2023 at 9:29 PM, spitfire said: Ok ok, its dark out here now, i wil get you all a picture 😁 1 Share this post Link to post Share on other sites
spitfire 176 #18604 Posted March 18, 2023 (edited) Happy? 9 months ago i didnt know what a wheel horse was...now i can't even get my bike out of the barn, im stocking 5 of these things. What to keep and what to get going somewhere else??? Edited March 18, 2023 by spitfire 1 4 1 Share this post Link to post Share on other sites
Skwerl58 743 #18605 Posted March 18, 2023 I will disc, can be seen under my shed in the tractor picture , then I will till if needed. I have a Wheel Horse tiller for the tractor and a 1976 Troy Bilt Horse if I need it. It took me a few years to gather the implements at good prices. The disc is an older Sears that has 10 disc and they are larger than others I have seen and I got it a few years ago. I love the older equipment because it is heavier and it just holds up better. I also have a Brinly spring harrow that I picked up like new . 2 1 Share this post Link to post Share on other sites
Blasterdad 3,023 #18606 Posted March 18, 2023 On 3/18/2023 at 9:31 PM, spitfire said: Looks like a commando 8, great NICE find !!! 3 1 Share this post Link to post Share on other sites
Monstrosity 1,146 #18607 Posted March 19, 2023 So today was productive repaired the backyard gate got the c1054 6 speed going then the steering linkage decided to pop out. MAX FINALLY DRIVE HIS 1277!! Drug the sears out of the front yard and started to put the Techumseh back together. received_909210250400591.mp4Fetching info... received_909210250400591.mp4Fetching info... 5 6 8 Share this post Link to post Share on other sites
GAJoe 850 #18608 Posted March 19, 2023 (edited) I cut the grass one day last week and all went well; the new belts appear fine so I put the guards back on today. I also put some traction tape on the foot rest as I have to unmount similar to a Horse "of course". Edited March 19, 2023 by GAJoe 12 2 Share this post Link to post Share on other sites
ebinmaine 70,472 #18609 Posted March 20, 2023 On 3/19/2023 at 10:53 PM, GAJoe said: traction tape on the foot rest Good idea. I've been covering the steps on mine as well. Gription is your friend. 4 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #18610 Posted March 20, 2023 For my 1000th post i am happy to say the last shroud bolt on my briggs and stratton came right out i learned that all ratchet dont all rotate the same so i guess i was tightening when i thought i was loosening i got confused because on my dad ratchet the switch flipped to the left is loosen but on my ratchet to the right is loosen so my dad taught me to check before trying to loosen a bolt and the bolts aren't that long and if the bolt is the right material we can weld the tops back on to get them out also i remembered while i was loosening it to spray it with wd 4d to help it come out but one thing is is that the shroud seems stuck on somewhere but hopefully i can get it off today but thanks for all of you for helping me as my dad is away alot for work and cant always help me but i will try and get the shroud off today. Kollin 5 5 Share this post Link to post Share on other sites
953 nut 57,683 #18611 Posted March 20, 2023 On 3/20/2023 at 3:41 PM, The Freightliner Guy said: guess i was tightening when i thought i was loosening 4 Share this post Link to post Share on other sites
spitfire 176 #18612 Posted March 21, 2023 On 3/20/2023 at 3:41 PM, The Freightliner Guy said: For my 1000th post i am happy to say the last shroud bolt on my briggs and stratton came right out i learned that all ratchet dont all rotate the same so i guess i was tightening when i thought i was loosening i got confused because on my dad ratchet the switch flipped to the left is loosen but on my ratchet to the right is loosen so my dad taught me to check before trying to loosen a bolt and the bolts aren't that long and if the bolt is the right material we can weld the tops back on to get them out also i remembered while i was loosening it to spray it with wd 4d to help it come out but one thing is is that the shroud seems stuck on somewhere but hopefully i can get it off today but thanks for all of you for helping me as my dad is away alot for work and cant always help me but i will try and get the shroud off today. Kollin You sure did your 1000th post well! Milestones can be realy satisfying! 1 1 1 Share this post Link to post Share on other sites
spitfire 176 #18613 Posted March 21, 2023 Today we worked on the B-125, checking electrics and redoing fuel system, to find out the choke leaver on the carburetor is broken en the intake manifold cracked... back to zero. Thats why he only coughed on start pilot ones. 3 1 Share this post Link to post Share on other sites
spitfire 176 #18614 Posted March 21, 2023 On 3/21/2023 at 12:14 AM, spitfire said: Today we worked on the B-125, checking electrics and redoing fuel system, to find out the choke leaver on the carburetor is broken en the intake manifold cracked... back to zero. Thats why he only coughed on start pilot ones. I found some parts for the B&s in france, i hope its what we need. Morale can use some engine spinning.... 3 Share this post Link to post Share on other sites
JCM 10,008 #18615 Posted March 21, 2023 Back in the early 90's when I had a large garden I used my Farmall Super A with a moldboard plow followed by a disc harrow and finished it up using a long railroad tie as a drag to smooth it all out, worked great. @Rob R 8 Share this post Link to post Share on other sites
Lane Ranger 11,118 #18616 Posted March 21, 2023 On 2/2/2022 at 11:25 PM, Jeff-C175 said: Mine did very well with the dump we got... One thing I noticed though was that I had to take it a bit slower than expected, but I believe it is because there is a WRONG and WIMPY spring on the idler! Augers kept stalling out when I pushed a little too hard. New spring on order... The correct spring is a 6651 part number and is 7/8" OD, 0.10 wire, hook to hook 5-3/4" If you can find a "Century Spring 5532" that's an exact match for the WH part. And this one is VERY close, Century C-263 https://www.amazon.com/dp/B000BQWVLY/ What's on yours Bill? https://www.mwcomponents.com/shop/5532cs?microsite=century-spring 1 1 Share this post Link to post Share on other sites
Evguy 556 #18617 Posted March 21, 2023 I was fortunate to score carlisle turf tires for 7.99 each at TSC today, normally 79.99. I’m wishing I would have gone sooner to get tires for more tractors. 7 2 1 1 Share this post Link to post Share on other sites
peter lena 9,072 #18618 Posted March 21, 2023 @Lane Ranger like your spring reference , when I was detailing in my snowblower , for any drag spots , the idler pulley frame , zeroed me into the empty holes that supported it , added thin teflon sleeve and green grease , also added a firmer spring for belt drive assurance , made a world of easier spin up difference , just went after every function ,of course , bearing re grease . emphasised that to the guy I sold it to , probably never get serviced again , pete 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #18619 Posted March 21, 2023 Getting some work done today with the help of my wheel horse B80 Twaakta ! Had to use some pieces of concrete to get traction but After that she pulled this concrete foundation right on out ! Of course I didn’t have to do it this way,but what’s the fun in not using your WH 2 12 Share this post Link to post Share on other sites
ebinmaine 70,472 #18620 Posted March 21, 2023 On 3/21/2023 at 5:26 PM, Wheelhorse#1 said: Of course I didn’t have to do it this way..... I... Well I have to respectfully disagree. There's NO other way that 'crete tuggin' could have been done. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,733 #18621 Posted March 21, 2023 On 3/21/2023 at 8:39 PM, ebinmaine said: I... Well I have to respectfully disagree. There's NO other way that 'crete tuggin' could have been done. Yup...I refer to our WH rigs as "back savers" for this kind of stuff. 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,320 #18622 Posted March 21, 2023 Got two new drive belts for the E-141's from Free Range Electric - The Electric Tractor Store. Good company to deal with... Bonus - Made in the USA!!! 6 4 Share this post Link to post Share on other sites
Blasterdad 3,023 #18623 Posted March 21, 2023 @Wheelhorse#1 Is that dirt I see on that nice original highback seat? That seat should be in a Museum, not under your dirty cement draggin" butt. P.S. I've got one I'll trade ya for it. 4 3 2 Share this post Link to post Share on other sites
WHX?? 50,603 #18624 Posted March 21, 2023 On 3/21/2023 at 10:12 PM, Blasterdad said: that dirt I see on that nice original He's got a point @Wheelhorse#1... Share this post Link to post Share on other sites
c-series don 9,400 #18625 Posted March 22, 2023 There’s no denying that is a really nice seat! 2 Share this post Link to post Share on other sites
