ebinmaine 75,744 #18576 Posted March 13, 2023 6 hours ago, Handy Don said: Mounted the 1-¼” riser onto the 854 NIIIIICE 👍👍 Share this post Link to post Share on other sites
SylvanLakeWH 29,817 #18577 Posted March 13, 2023 (edited) 1 hour ago, ebinmaine said: @SylvanLakeWH Resident black hood expert. 4411 bulbs? Yep - PAR3 You can get them in LED also... Edited March 13, 2023 by SylvanLakeWH 4 1 Share this post Link to post Share on other sites
Monstrosity 1,147 #18578 Posted March 13, 2023 A raider 10 seems to be following me home 3 5 Share this post Link to post Share on other sites
OutdoorEnvy 1,786 #18579 Posted March 13, 2023 2 minutes ago, Monstrosity said: A raider 10 seems to be following me home He's hot on your tail for sure! Post up some pics when you're back! 1 Share this post Link to post Share on other sites
Monstrosity 1,147 #18580 Posted March 13, 2023 Here she is I do have original engine too I picked it up for the trans, steering wheel, tires and possibly foot rests. Everything else will be posted in classifieds unless someone pms me 4 3 Share this post Link to post Share on other sites
GAJoe 852 #18581 Posted March 15, 2023 (edited) On 3/12/2023 at 5:38 PM, ebinmaine said: Should see it tomorrow or Tuesday Joe!! While you suthin' folks is mowing we'll be digging out another 12+" of white stuff. I was working out of town. It did arrive on Monday. Thanks again! I compared and the one that came on my C-160 was wore down to the snap ring groove like it was done in a lathe. The bearing must be "brown welded". Edited March 15, 2023 by GAJoe 1 Share this post Link to post Share on other sites
Thegearhead0324 1,353 #18582 Posted March 15, 2023 Rear tires came in today! Waiting on fronts still and tubes. 6 2 1 Share this post Link to post Share on other sites
WHGuy413 2,848 #18583 Posted March 15, 2023 (edited) Took my souped up Bronco 14 out with the Wheel Horse 2 stage blower on it. We received about 6” of heavy wet snow that compacted down to 4” or so. Did ok but still put more of a load on the 18HP V-twin than I would have thought. Still thinking the Ber-Vac was a better 2 stage. https://youtube.com/shorts/KPWKp9GiTTc?feature=share Edited March 15, 2023 by WHGuy413 2 Share this post Link to post Share on other sites
mrc 1,015 #18584 Posted March 16, 2023 WHGuy413, totally agree on the bervac being better. lighter, simpler and easier to hook up. regards mike 1 Share this post Link to post Share on other sites
GAJoe 852 #18585 Posted March 16, 2023 I cleaned up, replaced a couple parts, packed the bearing with a minimal amount of Lucas Green, and installed the PTO Cone from @ebinmaine . I should be ready to cut grass! 3 3 Share this post Link to post Share on other sites
WHGuy413 2,848 #18586 Posted March 16, 2023 32 minutes ago, mrc said: WHGuy413, totally agree on the bervac being better. lighter, simpler and easier to hook up. regards mike Way lighter, Doesn’t stick out as far, throws snow like there’s no tomorrow and way easier to attach. Will go back to it next year. 4 6 Share this post Link to post Share on other sites
ebinmaine 75,744 #18587 Posted March 16, 2023 7 hours ago, GAJoe said: I cleaned up, replaced a couple parts, packed the bearing with a minimal amount of Lucas Green, and installed the PTO Cone from @ebinmaine . I should be ready to cut grass! NIIIIICE 👍👍 1 Share this post Link to post Share on other sites
Pullstart 68,521 #18588 Posted March 17, 2023 Got it dirty… chores turned recovery! 2 5 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,786 #18589 Posted March 17, 2023 @Pullstart so what got it out? Or did it just need some ballast from a non phantom driver? Share this post Link to post Share on other sites
Pullstart 68,521 #18590 Posted March 17, 2023 9 hours ago, OutdoorEnvy said: @Pullstart so what got it out? Or did it just need some ballast from a non phantom driver? I picked the trailer up and was pushing it. Without my weight, it was able to dig out of the hole easier… and me pushing it towards higher ground. Towards the end, I tied the steering wheel in place so it couldn’t drag toward the mud. 3 Share this post Link to post Share on other sites
Skwerl58 770 #18591 Posted March 17, 2023 Today I replaced the front wheel bearings on my 414-8. Changed the grease in them with Lucas Red & Tacky and greased the tractor. I lubed all joints and lube points and adjusted the pto brake. Then I changed to the ag tires for plowing. Plowed two garden plots and hopefully will start planting by April 1. 4 8 Share this post Link to post Share on other sites
ineedanother 1,808 #18592 Posted March 17, 2023 I put the shaker on solid mounts before I start tilling. Interestingly, the shaker mounts were fine but the rear motor mount was loose on the frame. That explains the excess shaking 7 4 Share this post Link to post Share on other sites
ineedanother 1,808 #18593 Posted March 17, 2023 The drive belt idler on the 310-8 was sounding pretty bad so I pulled it off to see if I could save it. Not likely, so I ordered a couple Stens HD replacements since that looks like a step up from OEM and I'm sure one of the others will be asking for one when they get out this spring. They'll be here tomorrow 6 1 Share this post Link to post Share on other sites
spitfire 176 #18594 Posted March 18, 2023 (edited) On 3/13/2023 at 11:04 PM, Monstrosity said: A raider 10 seems to be following me home Must be the weather, i had a commando 8 following me home just 2hours ago 😁 Edited March 18, 2023 by spitfire 2 1 1 Share this post Link to post Share on other sites
spitfire 176 #18595 Posted March 18, 2023 (edited) My first real barnfind! Straw and dust incuded. Edited March 18, 2023 by spitfire 2 1 2 Share this post Link to post Share on other sites
Monstrosity 1,147 #18596 Posted March 18, 2023 1 hour ago, spitfire said: My first real barnfind! Straw and dust incuded. WELLLLLL where's the pictures?!?!? 1 Share this post Link to post Share on other sites
rjg854 12,624 #18597 Posted March 18, 2023 11 hours ago, spitfire said: My first real barnfind! Straw and dust incuded. 1 Share this post Link to post Share on other sites
Lee1977 7,456 #18598 Posted March 18, 2023 (edited) Show us some pictures of that hay stack so we can guess what's in there. Edited March 18, 2023 by Lee1977 Share this post Link to post Share on other sites
Rob R 977 #18599 Posted March 18, 2023 23 hours ago, Skwerl58 said: Today I replaced the front wheel bearings on my 414-8. Changed the grease in them with Lucas Red & Tacky and greased the tractor. I lubed all joints and lube points and adjusted the pto brake. Then I changed to the ag tires for plowing. Plowed two garden plots and hopefully will start planting by April 1. How do you do the finale smoothing of the soil prior to planting, do you disc/harrow or roto-till it? 3 Share this post Link to post Share on other sites
spitfire 176 #18600 Posted March 18, 2023 18 hours ago, Monstrosity said: WELLLLLL where's the pictures?!?!? Ok ok, its dark out here now, i wil get you all a picture 😁 2 Share this post Link to post Share on other sites
