ebinmaine 67,565 #17851 Posted November 27, 2022 8 minutes ago, Panther416-8 said: Looks nice Randy's. What did you do, just cut and drill a piece of angle steel? Do the J rods hook into the stock hold down holes in the tray? I've been waiting since August for a stock battery hold down set from WH &More but they are having trouble getting them in from their supplier. I might go this route. Matt I like how this one holds the battery down and IN towards the steering wheel. If you don't go this route maybe call Lincoln at A to Z. He's likely got a good used one. 2 Share this post Link to post Share on other sites
D_Mac 8,619 #17852 Posted November 27, 2022 9 hours ago, Blasterdad said: Put the new solid engine mounts on the C-161 tonight, ( the tuykey & pie wore off & coffee kicked in, lol ). These have been hanging on my workbench for 3 years, too many other 's wanting my attention. These are the Bee's Knees. I replaced them on my C-161 when I had it few years ago. One of the best mods I ever did to it and wished I did it sooner. 2 4 Share this post Link to post Share on other sites
Blasterdad 2,692 #17853 Posted November 27, 2022 6 minutes ago, D_Mac said: I replaced them on my C-161 when I had it few years ago. One of the best mods I ever did to it and wished I did it sooner. She is a beauty! I'm sure the new ownner is very happy! 1 Share this post Link to post Share on other sites
RandyLittrell 3,884 #17854 Posted November 27, 2022 1 hour ago, Panther416-8 said: Looks nice Randy's. What did you do, just cut and drill a piece of angle steel? Do the J rods hook into the stock hold down holes in the tray? I've been waiting since August for a stock battery hold down set from WH &More but they are having trouble getting them in from their supplier. I might go this route. Matt I did just grab a piece of scrap angle from the pile, cut it off and drill two holes. Bent the J hooks into L hooks then tried them in what I think was the original holes and I didn't like it. I saw there were holes on both sides half way back, so just used those and tightened them down. I really only had about 15 min in it, don't know why I have waiited this long! Randy 1 Share this post Link to post Share on other sites
ebinmaine 67,565 #17855 Posted November 27, 2022 58 minutes ago, RandyLittrell said: I really only had about 15 min in it, don't know why I have waiited this long! Don't be rushing things Randy. Sometimes you have to think about stuff for a few days, months, years before you really tackle it. 4 Share this post Link to post Share on other sites
ebinmaine 67,565 #17856 Posted November 27, 2022 Got the seat put on Wally Digger the backhoe tractor. Messed around with it a little in the yard and then put it in its new home under the left shed overhang of the new barn. Seems to be pretty happy there. 8 4 Share this post Link to post Share on other sites
Achto 27,597 #17857 Posted November 27, 2022 (edited) Spent a little time with my 953 today. I acquired this tractor from @PeacemakerJack roughly about 3yrs ago, parked it in storage and hadn't done any thing with it until last weekend when I drug it out of storage. I found out that there was some issues with the starter/gen when I tried to start it but couldn't let a little thing like that stop me from seeing if I could make it run. 1 - Check to see that there was oil in it. 2 - rebuild the carb. Every thing cleaned to hospital sterilization. New kit, throttle shaft bushings, and reassembled. 3 - Make sure that I have power to the coil. 4 - Clean points and verify spark. 5 - Strap on an IV bottle. 6 - Wrap a rope around the S/G pulley & give 'er a pull. Second pull it fired up & runs well. Smokes a bit, stearing kind of works but that's OK for now. Transmission works well in all gears. Hydraulic pump also works well. Next step, tear it all apart to prep it for a resto. Edited November 27, 2022 by Achto 3 13 Share this post Link to post Share on other sites
Panther416-8 341 #17858 Posted November 27, 2022 2 hours ago, RandyLittrell said: I did just grab a piece of scrap angle from the pile, cut it off and drill two holes. Bent the J hooks into L hooks then tried them in what I think was the original holes and I didn't like it. I saw there were holes on both sides half way back, so just used those and tightened them down. I really only had about 15 min in it, don't know why I have waiited this long! Randy Thanks Randy. I think I have a piece of inch or 1.5" angle laying around. A December project after I finish hooking up the snowblower and adding a linear actuator for the chute deflector. 2 Share this post Link to post Share on other sites
Panther416-8 341 #17859 Posted November 27, 2022 Cut some 1/2" SBR, drilled my impeller blades and attached with some stainless steel straps, bolts and nuts. Snug against the inside of the chamber but I can rotate by hand easy enough. 4 7 Share this post Link to post Share on other sites
WHGuy413 2,693 #17860 Posted November 27, 2022 Spent a decent amount of time cleaning and moving tractors around today in my big shed. Still a few things to move around but should give the boys ample room for their new tractors we pick up next weekend. If all goes well these 2 wheeler and made a deal for 5 wheel horses and attachments/ accessories. I’m sure Alex will fill you all in when it happens. 7 2 Share this post Link to post Share on other sites
Blasterdad 2,692 #17861 Posted November 28, 2022 Got the C-161 back together, new ammeter, new mounts work greatI Started to put the snow cab on. 8 4 Share this post Link to post Share on other sites
Panther416-8 341 #17862 Posted November 28, 2022 Finally finished the re-assembly and attachment of the two stage blower. Everything seems to run as it should. I wish this tractor had power steering, that blower is darn heavy. Linear actuator for the chute deflector shipped today so I guess that's next weekend's project. 7 5 Share this post Link to post Share on other sites
WHGuy413 2,693 #17863 Posted November 29, 2022 2 hours ago, Panther416-8 said: Finally finished the re-assembly and attachment of the two stage blower. Everything seems to run as it should. I wish this tractor had power steering, that blower is darn heavy. Linear actuator for the chute deflector shipped today so I guess that's next weekend's project. Even harder to steer when one front tire goes flat on you. Not speaking from experience or anything lol. Good looking set up. 2 Share this post Link to post Share on other sites
Blasterdad 2,692 #17864 Posted November 29, 2022 12 hours ago, Panther416-8 said: I wish this tractor had power steering, that blower is darn heavy. You'll get used to turning when your moving only, much easier... Glad you got it together, looks great! 2 Share this post Link to post Share on other sites
cleat 6,020 #17865 Posted November 30, 2022 I don't normally like green things but... 2 5 2 Share this post Link to post Share on other sites
8ntruck 7,014 #17866 Posted November 30, 2022 (edited) Tis the season for changing the Jeep's summer tires for snow tires. Clyde got tapped for a little cart hauling time to get the winter tires from the shed out to the driveway and return the summer tires to the shed for storage. Note the fresh painted front wheels and new 5 ribs. I was really surprised at how well Clyde fired up. He hasn't been run for about 2 months and his battery was down. The starter would spin, but not engage the flywheel. I put a charger on the battery for maybe 15 minutes. Was enough. He fired right up in maybe two crankshaft revolutions. Interesting story on the Jeep. Before we left for Kentucky a week ago, we had noticed a "clunk" noise in the drivetrain when backing out of a parking spot with the front wheels turned to full lock. Dropped it off at the local dealer. Turns out that it was something in the rear driveshaft - it was replaced. Now the good news - it was covered by warranty! My bill was only $130. Inspecting the tread on the summer tires tells me they are done. Will replace them with new summer tires next spring. Edited November 30, 2022 by 8ntruck 6 Share this post Link to post Share on other sites
Panther416-8 341 #17867 Posted November 30, 2022 Put air in the tires. Fronts were at about 10-12 psi. Put 20 in each. Amazing how much better it steers with the 2 stage mounted. Found the tie rods to be very worn and loose so ordered new adjustable ones. 3 1 Share this post Link to post Share on other sites
sparkys toy 76 #17868 Posted November 30, 2022 On 11/28/2022 at 8:22 PM, WHGuy413 said: Even harder to steer when one front tire goes flat on you. Not speaking from experience or anything lol. Good looking set up. Just a novis question about the weight’s on the front,with a150 lb blower on the front do you really need the extra weight making it harder to steer,i can see it with a plow when angled it can push you left or right but didn’t think that would happen with the blower.and as Panther mentioned more air less friction,great looking rig by the way 1 Share this post Link to post Share on other sites
lynnmor 7,307 #17869 Posted November 30, 2022 8 hours ago, Panther416-8 said: Put air in the tires. Fronts were at about 10-12 psi. Put 20 in each. Amazing how much better it steers with the 2 stage mounted. Found the tie rods to be very worn and loose so ordered new adjustable ones. You might have tires that have a maximum rating of 10 or 12 psi, look at the sidewall. Four ply tires are rated for the pressures you want. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,565 #17870 Posted November 30, 2022 9 hours ago, Panther416-8 said: Put air in the tires. Fronts were at about 10-12 psi. Put 20 in each. Amazing how much better it steers with the 2 stage mounted. Found the tie rods to be very worn and loose so ordered new adjustable ones. 1 hour ago, lynnmor said: You might have tires that have a maximum rating of 10 or 12 psi, look at the sidewall. Four ply tires are rated for the pressures you want. There's oodles of tires available with much higher air pressure ratings. Carefully check your own for a rating... And any weather cracking. 2 Share this post Link to post Share on other sites
WHGuy413 2,693 #17871 Posted November 30, 2022 2 hours ago, ebinmaine said: There's oodles of tires available with much higher air pressure ratings. Carefully check your own for a rating... And any weather cracking. I think I’m gonna have to get new front tires for the bronco 14 if I plan to use the 2 stage this winter. One holds air but the other leaks out and both are pretty dry rotted. Planning on trying to find close to the same style tire. 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,666 #17872 Posted November 30, 2022 17 hours ago, 8ntruck said: Note the fresh painted front wheels and new 5 ribs. @8ntruck Good looking front tires there.What size and brand are you running ? 2 Share this post Link to post Share on other sites
8ntruck 7,014 #17873 Posted November 30, 2022 1 hour ago, Wheelhorse#1 said: @8ntruck Good looking front tires there.What size and brand are you running ? Those are Vredestein V61 tires. The size is 18x8.50-8. Got them from Miller Tire. 1 2 Share this post Link to post Share on other sites
Panther416-8 341 #17874 Posted December 1, 2022 9 hours ago, lynnmor said: You might have tires that have a maximum rating of 10 or 12 psi, look at the sidewall. Four ply tires are rated for the pressures you want. They're rated for 28 psi. I would have added a little more but the gauge I was using at the time was a low pressure 20 psi max gauge. 1 Share this post Link to post Share on other sites
8ntruck 7,014 #17875 Posted December 4, 2022 Got Clyde out again today for some more cart work. Hauled some tools to the lake house to blow down the water lines and winterize the drains. Hauled the tools back and some items that we want to keep in a heated house over the winter. While I had a tractor and cart out, I moved some wood I cut up the other day to the wood pile, then moved some rocks to the lake adding to a small breakwater I am making to prevent the shore from washing out under the concrete dock pad. Got to work on Clyde's choke linkage. The original carb had a vertical choke shaft. The carb currently in use has a horizontal choke shaft. Direct connection to the current choke lever is not possible with the choke Boden cable. I'll have to figure something else out. I'm tried of opening the hood to work the choke directly. 4 Share this post Link to post Share on other sites
