Rob J. 1,942 #17201 Posted September 28, 2022 1 hour ago, ebinmaine said: I puttered around here and there in the yard today. Messed with the wheels and brakes on Cinnamon Horse C160. Took apart the top of a K341. @gwest_ca can you please tell me what year and usage this might be? Trina took her momma shopping and then commenced to her own puttering around here. Did you get that brake pad glued in yet? 2 Share this post Link to post Share on other sites
Lagersolut 661 #17202 Posted September 28, 2022 Nice to have help hauling cornstalks 4 2 2 Share this post Link to post Share on other sites
ebinmaine 67,566 #17203 Posted September 28, 2022 1 hour ago, Rob J. said: Did you get that brake pad glued in yet? Yessir. It's glued in the pics. 1 Share this post Link to post Share on other sites
Pullstart 62,905 #17204 Posted September 28, 2022 @ohiofarmer your lift makes me wonder if a guy could make an engine hoist adapted to be a tractor lift… Thanks to Kollin @The Freightliner Guy’s inquiry, Putt Putt (Kollin dubbed Pull Pull because if t wouldn’t start) fired up tonight for the first time since about this time in 2020 when the @PeacemakerJack clan was here visiting! It just needed a good spark plug. I sure do miss that mohawk… 4 Share this post Link to post Share on other sites
Handy Don 12,233 #17205 Posted September 28, 2022 (edited) This afternoon I was able to button up the RM-366 deck for the third (charmed) time. I'd already replaced the bent cross-shaft and re-re-balanced the blades, but found I had too much face-to-spur gear lash when the face gears were fully seated on the cross shaft. A bunch of fiddling and feeler-gauging showed I needed to move the face gears apart (i.e. toward the spurs) by about .06" to fully remove the gear lash. @ri702bill suggested leaving about .01" or so for grease and thermal expansion. (Note: the cross shaft not being locked in place, the .06" could be added to one end of the shaft.) I was about to buy a ⅝" ID shim washer set from McMaster but thought "heck, give the Ace Hardware Hillman drawers a try", right? Bingo. 50¢ and only needed a notch filed to clear the woodruff key. It's now between the back of one face gear and the step on the shaft that seats the gear. Vastly reduced noise and vibration. Also added a 4" cove base flap to the rear discharge using the four pre-existing holes on the rear skirt of the deck. Get ready, grass, we're coming for you! Edited September 28, 2022 by Handy Don 2 2 Share this post Link to post Share on other sites
TJ5208 1,824 #17206 Posted September 28, 2022 19 minutes ago, Pullstart said: @ohiofarmer your lift makes me wonder if a guy could make an engine hoist adapted to be a tractor lift… Thanks to Kollin @The Freightliner Guy’s inquiry, Putt Putt (Kollin dubbed Pull Pull because if t wouldn’t start) fired up tonight for the first time since about this time in 2020 when the @PeacemakerJack clan was here visiting! It just needed a good spark plug. I sure do miss that mohawk… Is that Leroy? Share this post Link to post Share on other sites
Heatingman 971 #17207 Posted September 28, 2022 Think Im finally done painting the parts. 6 Share this post Link to post Share on other sites
Pullstart 62,905 #17208 Posted September 28, 2022 7 hours ago, TJ Salyers said: Is that Leroy? was 1 Share this post Link to post Share on other sites
Handy Don 12,233 #17209 Posted September 28, 2022 (edited) Hood is on and finally was able to mow the whole lawn for the first time with the 854 and RM-366. It does a good job and with the plastic flap on the back of the deck, the rear of the tractor is staying pretty clean. Some cuttings fly out the front on the sparser sections. Last week I realized the throttle pull wasn't holding at full operating revs. The black plastic handle was spinning on the shaft preventing the twist lock from full engaging. Drilled two small holes through the stem of the knob and the shaft and then super-glued cut-off finishing nails in the holes. Problem solved. Edited September 28, 2022 by Handy Don 3 4 Share this post Link to post Share on other sites
Handy Don 12,233 #17210 Posted September 28, 2022 (edited) (double post deleted) Edited September 28, 2022 by Handy Don 1 Share this post Link to post Share on other sites
Horse Newbie 7,071 #17211 Posted September 28, 2022 I received my Clevis hitch from @19richie66 today… Over the winter I will restore/ paint my plow so I’ll be ready for spring planting season. Thanks Richie ! 4 4 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #17212 Posted September 28, 2022 Welded up a caution light / rear LED light tower for my 314-8. Just need to paint it and finish connecting the wires tomorrow and be good to go. Should definitely help snowblowing / plowing. 3 4 Share this post Link to post Share on other sites
Horse Newbie 7,071 #17213 Posted September 28, 2022 4 minutes ago, OldWorkHorse said: Welded up a caution light / rear LED light tower for my 314-8. Just need to paint it and finish connecting the wires tomorrow and be good to go. Should definitely help snowblowing / plowing. Good gracious man !… are you planning to plow through a blizzard ? 4 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #17214 Posted September 28, 2022 23 minutes ago, Horse Newbie said: Good gracious man !… are you planning to plow through a blizzard ? I mean in maine we get 1 snow storm and before can finish moving that snow another one is already dumping more on us. So yes pretty good odds I'll be in a blizzard and just want to be found and not lost 1 3 Share this post Link to post Share on other sites
Horse Newbie 7,071 #17215 Posted September 28, 2022 I’m just @OldWorkHorse. I know you fellows need all you can get up nawth… Down these parts we are lucky to get 1-2 inches every couple of years. I have a dozer blade and a mid mount scraper blade. They may never touch snow… 4 2 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #17216 Posted September 28, 2022 6 minutes ago, Horse Newbie said: I’m just @OldWorkHorse. Down these parts we are lucky to get 1-2 inches every couple of years. I have a dozer blade and a mid mount scraper blade. They may never touch snow… Lucky, 1 to 2 inches up here people are still out riding their motorcycles haha . Seriously tho there is a guy in my town who rides his year round snow storm or downpour . 5 1 Share this post Link to post Share on other sites
KrazeyOlDave 860 #17217 Posted September 28, 2022 Any vendors here that sell quality fuel pumps? Not interested in the China stuff,lol. 2 Share this post Link to post Share on other sites
rjg854 11,378 #17218 Posted September 28, 2022 Not a vendor here, but try I save tractors 3 Share this post Link to post Share on other sites
Handy Don 12,233 #17219 Posted September 28, 2022 2 minutes ago, KrazeyOlDave said: Any vendors here that sell quality fuel pumps? Not interested in the China stuff,lol. Consider calling A-to-Z for a solid used one along with the kit to rebuild it. 5 1 Share this post Link to post Share on other sites
ebinmaine 67,566 #17220 Posted September 28, 2022 22 minutes ago, KrazeyOlDave said: Any vendors here that sell quality fuel pumps? Not interested in the China stuff,lol. 20 minutes ago, Handy Don said: Consider calling A-to-Z for a solid used one along with the kit to rebuild it. Seconded. If your tractor is of the rear tank variety it would be worth a thought to change over to electric. 5 Share this post Link to post Share on other sites
KrazeyOlDave 860 #17221 Posted September 28, 2022 1 minute ago, ebinmaine said: Seconded. If your tractor is of the rear tank variety it would be worth a thought to change over to electric. If I can’t get genuine Kohler, that’s exactly what I’ll do. I just wanted to support the vendors on here first. 1 1 Share this post Link to post Share on other sites
KrazeyOlDave 860 #17222 Posted September 28, 2022 25 minutes ago, Handy Don said: Consider calling A-to-Z for a solid used one along with the kit to rebuild it. I didn’t call them but I browsed their site, no luck Share this post Link to post Share on other sites
ebinmaine 67,566 #17223 Posted September 29, 2022 1 minute ago, KrazeyOlDave said: I didn’t call them but I browsed their site, no luck I don't buy much from Lincoln because I have most of the parts I need already... But... I don't ever use his website. I use the old fashioned phone with voice method. It's a bit odd, I know... Lincoln is a good fella and VERY busy. Been times I've gotten things from him that weren't catalogued online yet. 6 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #17224 Posted September 29, 2022 4 minutes ago, KrazeyOlDave said: I didn’t call them but I browsed their site, no luck I used A to Z a few times called them and they had what I needed for a good price shipped that day. 4 Share this post Link to post Share on other sites
Handy Don 12,233 #17225 Posted September 29, 2022 7 minutes ago, KrazeyOlDave said: I didn’t call them but I browsed their site, no luck Lincoln is so busy during spring/summer/fall that he cannot keep the website current--inventory goes in and out quickly. I second the suggestion of calling, that's what I've done. It speeds things knowing exactly what you want, and following up with an email. For example, on the fuel pump: engine size? lever or vacuum? fuel inlet on flywheel side or PTO side? Any fittings needed? 4 Share this post Link to post Share on other sites
