elcamino/wheelhorse 9,315 #16476 Posted August 5, 2022 At once again it is the bi annual @Pullstartclean up to find the missing 10 mm socket or sockets. The building probably lost a least one ton of weight just cleaning of the floor. LOL 1 1 5 Share this post Link to post Share on other sites
Pullstart 62,905 #16477 Posted August 5, 2022 5 minutes ago, elcamino/wheelhorse said: At once again it is the bi annual @Pullstartclean up to find the missing 10 mm socket or sockets. The building probably lost a least one ton of weight just cleaning of the floor. LOL good thing it’s trash day tomorrow! I’m tired of sweeping, changing my stinky shirts and getting my flip flops dirty! 6 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #16478 Posted August 5, 2022 (edited) Guess what guys I’m going to my grandparents house Saturday to work on the rj look for the Easter egg in every pic from now on Edited August 5, 2022 by The Freightliner Guy 1 1 Share this post Link to post Share on other sites
Pullstart 62,905 #16479 Posted August 5, 2022 Great news Kollin! Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #16480 Posted August 5, 2022 Hopefully we end up taking Reese the rj home Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #16481 Posted August 5, 2022 (edited) And nope he’s not for sale and never will be sorry for any of y’all interested in buying it Edited August 5, 2022 by The Freightliner Guy Share this post Link to post Share on other sites
Evguy 556 #16482 Posted August 5, 2022 I spent a good part of the day changing oils and lubricating chains and linkages on the 718-z. Apparently chain adjustments and draining the drives was not a thought designing this machine, there was profanity aplenty. I shortened the primary chains to lessen slack, replaced worn woodruff keys on drive motors, and adjusted the inoperative parking brakes. I took it out and gave it a cutting test, it cuts well but drifted to the right, mismatched tires causing issues. I haven’t decided to leave paint as is or freshen it up a bit, decals don’t seem to be available. 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #16483 Posted August 5, 2022 Nothings available nowadays 1 Share this post Link to post Share on other sites
Cee245 818 #16484 Posted August 5, 2022 Put on the bagger attachment I picked up at the show and cleaned it up a bit. 3 3 Share this post Link to post Share on other sites
ebinmaine 67,569 #16485 Posted August 5, 2022 7 hours ago, Evguy said: decals don’t seem to be available Check with Terry the vinyl guy. @Vinylguy 7 hours ago, The Freightliner Guy said: Nothings available nowadays Every thing is available if you know where to look and who to ask. You just need patience and connections. 5 Share this post Link to post Share on other sites
TJ5208 1,824 #16486 Posted August 5, 2022 All i can do is just stand here and stare. I wish i could find a cheaper ignition trigger. 1 Share this post Link to post Share on other sites
Monstrosity 1,128 #16487 Posted August 5, 2022 1 minute ago, ebinmaine said: Every thing is available if you know where to look and who to ask. You just need patience and connections. Ain't that the truth! 2 Share this post Link to post Share on other sites
TonyToro 1,049 #16488 Posted August 5, 2022 20 hours ago, 19richie66 said: All that clutter would frustrate me. Oh wait a minute It’s not clutter! It’s valuable merchandise not categorized.😂 I’m in the same situation.👍 3 Share this post Link to post Share on other sites
TonyToro 1,049 #16489 Posted August 5, 2022 1 hour ago, TJ Salyers said: All i can do is just stand here and stare. I wish i could find a cheaper ignition trigger. There is a guy on a forum somewhere I saw replaced parts with off the shelf automotive parts. He even had parts item numbers… maybe that could be a help? 1 1 1 Share this post Link to post Share on other sites
ebinmaine 67,569 #16490 Posted August 5, 2022 2 minutes ago, TonyToro said: There is a guy on a forum somewhere I saw replaced parts with off the shelf automotive parts. He even had parts item numbers… maybe that could be a help? @Ed Stoller has been doing that on Tecumseh engines for years. Not sure about the Onan stuff though. 2 Share this post Link to post Share on other sites
Tractorhead 9,064 #16491 Posted August 5, 2022 (edited) Btw, what you means as the „Trigger“? Is it the Ignition system „Blackbox“ or the Pickupcoils themself what you mean? if you mean the Pickups themself, it can maybe built from cheap chinese scooter ignitions they work on dc ignitions. They be mostly available with all needed Parts like pickup, Trigger electronic, Coils and ignitioncables together here for 20-30$ completely. That is a way i would try if originalparts are too expensive or too hard to get. Measure the Pickupcoils in Ohms and compare the values that they be ok and in nearly same range. Get a cheapo dc ignition for a chinese twin cylindre - like honda twin replica and use them instead. It is worth a try. I know it‘s not 100% original, but it can maybe keep the Engine running until you will find an original Trigger for a reasonable price or you have the money to buy it. Sent you a PM with a suggestion.. Edited August 5, 2022 by Tractorhead Sent suggestion 2 3 Share this post Link to post Share on other sites
TonyToro 1,049 #16492 Posted August 5, 2022 46 minutes ago, Tractorhead said: Btw, what you means as the „Trigger“? Is it the Ignition system „Blackbox“ or the Pickupcoils themself what you mean? if you mean the Pickups themself, it can maybe built from cheap chinese scooter ignitions they work on dc ignitions. They be mostly available with all needed Parts like pickup, Trigger electronic, Coils and ignitioncables together here for 20-30$ completely. That is a way i would try if originalparts are too expensive or too hard to get. Measure the Pickupcoils in Ohms and compare the values that they be ok and in nearly same range. Get a cheapo dc ignition for a chinese twin cylindre - like honda twin replica and use them instead. It is worth a try. I know it‘s not 100% original, but it can maybe keep the Engine running until you will find an original Trigger for a reasonable price or you have the money to buy it. Sent you a PM with a suggestion.. @TJ Salyers 1 1 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #16493 Posted August 5, 2022 @TonyToro - sorry for confusion.. 🤪 @TJ Salyers Maybe that helps or maybe ya kew it allready an tested it that Way https://woodmizer.com/us/portals/0/docs/612942f6-a481-43b2-9675-f85f0c63b17d.pdf 2 1 Share this post Link to post Share on other sites
lynnmor 7,307 #16494 Posted August 5, 2022 The ignition module, that some call a trigger, is simply a hall effect transistor that switches on or off as a magnet passes by it. It works the same way as a points type of ignition but there are no moving parts to wear. Onan uses a trigger ring on the crankshaft that contains two magnets that have opposite poles that cause the module to switch on and off. 4 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #16495 Posted August 5, 2022 Hall sensors will be also available for most motocycles. @lynnmor Do you know, is the doublecoil separately triggered for each cylindre or ist it a single shot trigger and both coils fire the same time? 2 Share this post Link to post Share on other sites
Cee245 818 #16496 Posted August 5, 2022 (edited) Onan twins on these fire at the same time if that helps Edited August 5, 2022 by Cee245 2 Share this post Link to post Share on other sites
lynnmor 7,307 #16497 Posted August 5, 2022 26 minutes ago, Cee245 said: Onan twins on these fire at the same time if that helps @Tractorhead, this is correct. 2 Share this post Link to post Share on other sites
squonk 41,145 #16498 Posted August 5, 2022 (edited) 15 hours ago, Pullstart said: getting my flip flops dirty! Don't want to get those dusty cowboy boots dirty! Might have to go dancin on the weekend! Actually surprised you're wearing anything! Edited August 5, 2022 by squonk 4 Share this post Link to post Share on other sites
Pullstart 62,905 #16499 Posted August 5, 2022 1 minute ago, squonk said: Don't want to get those dusty cowboy boots dirty! Might have to go dancin on the weekend! Actually surprised you're wearing anything! No boots right now, gots the poison Ivy all over my arms, legs and feet! I’m surprised I’m wearing anything too! 1 Share this post Link to post Share on other sites
squonk 41,145 #16500 Posted August 5, 2022 25 minutes ago, Pullstart said: No boots right now, gots the poison Ivy all over my arms, legs and feet! I’m surprised I’m wearing anything too! 2 Share this post Link to post Share on other sites
