Ed Kennell
What have you done to your Wheel Horse today?
squonk
19 hours ago, Monstrosity said:
Made the PTO lever the other day and it needed a handle. 20220719_184643.jpg.bb86c1ce1746905b3c4039717dda7e06.jpg
Nice windshield wiper knob on the throttle too! :banana-wrench:
  • Haha 6
  • Confused 1
johnnymag3
Inflation that's good...…...not the other type !!!!!!!!
Nice    John
  • Haha 5
Blasterdad
18 minutes ago, Pullstart said:
Pays to shop around.  I needed 1.  4 for $6 or 100 for $24.  Now I have spares.
If I had your collection i would have bought 2. :ychain::bow-yellow:
  • Haha 6
peter lena
@kbowley good looking horse you have there , ever think about giving that paint an aerosol lubrication soak down ? its at a perfect stage to spray down the entire painted dull surface , just a soaking mist , let it sit a day , then clean cloth rub it down , till dry , NO SANDPAPER OR SCRATCH PADS . paint will look deeper red , do the spray over again , let sit a day , rub down till dry , should have a patina saving oiled finish on it . 2 choices at that stage , leave it alone , or  use a 6 " hand electric buffer . with a cleaner wax  to bring it out , try a test spot .like belt guard shield . if its the recovery you like , that buffer will make quick work of it , only a suggestion , that I  have used on my 3 horses . good luck , pete
peter lena
ebinmaine
15 minutes ago, Blasterdad said:
If I had your collection i would have bought 2......
Dozen
  • Haha 3
The Freightliner Guy
Look who I found snooping around my rj today
  • Haha 5
D_Mac
And one more tire that’s not flat on the bottom…
Funny how they always go flat on the bottom isn't it.
  • Haha 1
Also do you guys know why my rjs tires are leaking some sort of fluid
  • Confused 1
rjg854
They are probably filled with calcium in the rims are rotting out from the inside
  • Like 5
squonk
RJ's were so light in the front end they are often found with loaded tires
Handy Don
That wheel has already been affected by rust, how badly is not clear, and I would worry that it could collapse if driven.
Having that fluid sit on the spindle (the shaft through the hub of the wheel that attaches to the axle) could start it to rusting as well.
This will not get better with age,
Ok thanks for the info but I think they might last until I get it running it’s sat on those rims for 14 years but the front tires are the only bad ones the rears are fine I think at least
sjoemie himself
1 hour ago, The Freightliner Guy said:
IMHO those rims are beyond repair :blink:
Good chance that when you start chipping away at the rust one or several holes will appear.
Check out mystery rj and you’ll see what’s happened so far
Monstrosity
What should be on there????????
ebinmaine
Apparently a windshield wiper knob.
:lol:
squonk
D_Mac
A Special order option wipers and a windshield......hmmmmmmm
  • Haha 1
Monstrosity
5 minutes ago, squonk said:
Got an extra knob?????  I'll be happy to put it on.
SylvanLakeWH
Thats a drinking clock… it’s 5:00 pm… always… :orcs-cheers:
Edited by SylvanLakeWH
  • Haha 3
Andy N.
Did a bunch of work on the Suburban today. Tightened the steering. Shimmed nose wheels. Removed Predator tank and connected original. Added foot rests for a more comfortable ride. Took duellies off to service outer tire and put a more manageable length bolt on. Axle seals will need to be replaced as well as maybe find a muffler.68021930064__68D3321A-8205-4879-B8C1-1F2593C03465.JPG.7321d17b81711b0025b16cb58ee1bffe.JPG
68021944252__A6D8BFCA-FCB0-45DC-B6C5-C2B416448F3D.JPG.61c7ff5499ed6305c99fb02f29a5abfa.JPG
68021945862__57907B33-9EA0-49D6-9FD7-4EB919CDAF62.JPG.de9207495ef076e6b0bbc79578ff5533.JPG
  • Excellent 5
TonyToro
😂👍 that’s what I do. I need two of whatever, so I’ll buy a bag of 100. 😂
I have friends that are landscapers and use me as their after hours and weekend supply store.
