Ed Kennell
What have you done to your Wheel Horse today?
johnnymag3
Spent the afternoon replacing the wiring on the B-80 AkA FlowahPowah. She was having bad connection issues and rather then case what wire was doing it I figured I'd update all of them. Starts and runs great now.
Get those wires off the steering shaft ol' boy.....   Looks nice and purty now !!!
Edited by johnnymag3
  • Like 5
ebinmaine
9 hours ago, OldWorkHorse said:
@johnnymag3
Good eye
ebinmaine
2 minutes ago, Lane Ranger said:
I like those vendors stickers on the belt guard there. Or magnets?
You find that those go down the road okay?
I've been thinking of doing something along a line with the dash plaques from Owls Head and I was concerned they would fly off...
  • Heart 1
OldWorkHorse
Hah yes they were tucked behind it before. When I re connected them I tucked them all in front. However I zip tied them and crammed them in there for the photo shoot as my parents were coming over. It's been since corrected but photo wasn't updated. Thanks for the keen eye! I somehow almost didn't even notice your comment not sure how :laughing-rolling:
  • Haha 3
OldWorkHorse
7 minutes ago, ebinmaine said:
@johnnymag3
Good eye
No one was supposed to notice :scared-shocked:
  • Haha 4
squonk
Take em off whilst travelling. Stick em on when you get there!
( I should have copyrighted the Wheel Horse Makes it Kohler Shakes It years ago!) :(
  • Like 6
davem1111
Yesterday: Mulched the wife's rose garden before it got hot out. Sharpened the blades on both decks, then got some mowing done. Unfortunately, the GT-1848 decided to stop running so I had to tow it back in with the 312-A. Finished up with the 312-A, then did some weedwacking.  I'll probably post some questions about the Honda engine's misbehavior, but I haven't done any troubleshooting yet. May be another case of failed fuel pump (I have aftermarket electric pumps on both the 312-A and the 416-8, and they work great), but there seems to be at least some gas moving through the filter. Might be a carb teardown/clean, but it dies when I increase the throttle. It's been running a bit rough at lower throttle levels. Haven't done anything to the "new" B-100 yet, in the background to the right.
  • Like 7
ebinmaine
I was told two or three decades ago that you have to do ALL the maintenance before you can do ANY of the troubleshooting.
I agree that you need to do a carb rebuild and I would add to that, replace every inch of fuel line and a new fuel filter.
Definitely a possibility that your fuel lines or gunk in the tank is sending stuff into the carburetor.
  • Like 5
davem1111
Great advice. :techie-idea:  However, I didn't mention that while I had the seat, fender and side guard off to replace the ruined drive belt idler and belt, I had found that the fuel cut-off (screw-type) valve didn't work anymore, so I replaced it with a used one that worked because I didn't have another new one on hand, and replaced the whole fuel line up to the filter on the engine side. (I had the foresight to buy a long spool of good fuel line a while back).  I had already replaced the filter between the engine and battery area, and the shorter line between that and the fuel pump, right after I got the tractor. I was wondering about the fact that after the fuel line comes through the body near the steering column, it has to travel uphill to the filter and pump, so the pump is sucking gas upward, and the filter never seems to have more than 3/8" - 1/2" of fuel in it even when running. Should this be arranged so the fuel line comes through and goes up, then down through the filter?  It would seem odd because it ran fine with this same arrangement before.  I also know it's been recommended to put a filter back near the tank and cut-off valve and then another up near the engine, which I'm not opposed to. But I suppose the first thing I should do is confirm that I get a good solid gravity flow of fuel out of the tank when the valve is fully open. I also noticed a mention of an air vent in the fuel cap... this cap is not in great shape and such a vent could be plugged up.
I should also mention that this Honda GX630 engine seems to require 2 additional on/off toggle switches on the dash (at least, the way they wired it) - who ever replaced the engine installed these but didn't label them. I've been looking for a wiring diagram for this engine but haven't found anything yet that mentions these. Engine won't shut off when you turn off the key, have to toggle at least one of these off to kill the engine, and at least at one point it didn't seem to run or run right with one on and one off - I've been filcking them both on and off every time. But again, it had been running fine (if a bit rough at lower throttle, but fine at full throttle) before the recent work. Seat switch and clutch/brake switch have been disabled by someone previously, so the engine can start and PTO can be engaged while standing next to the tractor, which I know is a safety issue, but also that some faulty wiring could be causing issues.
My guess at this poing is poor fuel flow and/or carb. Going on another trip later this week so I may not have much time to mess with it until the first weekend of July... :unsure:
ebinmaine
If you haven't already done so it would be a great idea to start a separate thread on this tractor so the work you do doesn't get lost in this giant thread quite so easily.
I would have near zero concern about the actual level of the fuel in the fuel filter itself as long as gas is flowing through it freely and happily.
I'm not familiar with the fuel filter or fuel pump setup on those engines. I'm wondering if the fuel pump could be disassembled and cleaned out like it can on an old Kohler engine?
I think you'll find that once you assure good flow from the tank, clean gas going forward, and rebuild the carb... That may eliminate whatever issues you're having.
As to the electrical wiring...
Perhaps there is a dealer Network that could help with how that thing SHOULD HAVE been wired?
My own inclination would be to make a very carefully drawn out schematic diagram of the existing circuits as they are in the tractor right now.
I don't have much of any concern for safety switches because Trina and I are the only two that drive our tractors except on very rare and supervised conditions. No inexperienced drivers and no children are EVER around them.
That said, when I got my 1975 Automatic I left the safety switches in place because I'm not used to driving that tractor.
peter lena
@ebinmaine , always re doing something , you can either screw mount them , or on clean paint that peel and stick is also solid . soon as I  see a tight wire issue usually do a reroute . pete
Lane Ranger
magnets. They stay on 98% of the time!
Edited by Lane Ranger
davem1111
Started putting the transaxle back on my 416-8 (had water in it so I took it off to drain and clean it, since I couldn't get the drain plug to budge). Used the "make a stud by grinding the head off a bolt" method to align it with the frame that I've seen mentioned here - that worked really well.  Got it snugged up then realized I'd have to loosen it again to re-attach the hi-lo shifter :unsure:.  Will do some more repainting later on the rest. Going away for a few days so I'll finish this next week.  Hoping to sell this tractor but should probably put a deck on it. That will entail repairing one of the other decks (42" or 48") and they both need parts I don't have...
  • Like 5
davem1111
Okay, does anyone know which manual shows how to re-assemble all the brackets, springs, etc. for the 8-speed Uni-Drive?  I didn't think I'd have this apart as long as I have, and should have taken pictures. I've been looking through all the manuals available here and most of them are either high level owner's manuals or the IPL parts lists with exploded views but no assembled views.  The manuals specific to servicing this trans show you how to rebuild it but not how to install it. :eusa-think:
Snoopy11
Me thinks the most help you are going to get is looking at pictures such as this...
151088989_Clutchspring2.jpg.13d464ec5e40eeff98380d37c9e3dc6c(1).jpg.1cfc031631f2ac908f7cbd5c473fbe5a.jpg
Don
davem1111
Don
Thanks Don!
There should be a spring on the drive idler also, but I am having trouble finding where it goes. And I do have 2 springs in the parts pile. Looks like the smaller of the 2 should go over there.  Have any pics of that?  (You can PM me if you want, so we don't clutter up this thread...)
Desko
Picked up this nice 60" deck at the big show! It needs some love with belts and bushings but it'll go great on the 520-8. Lots of great people, vendors, and equipment  at the show and even more stuff I wish I could've brought home with me lol
Edited by Desko
  • Like 8
adsm08
Drove around the Show for a few hours this morning. After getting home...
Old steering shaft:
New steering shaft, courtesy of @RJ854
Oops, got the wrong tie rods:
Even with the old worn out tie rods the steering is tons better, because most of the play was in the fan gear. Still going to get the right ones.
  • Like 5
  • Excellent 3
Blasterdad
Replaced center spindle bearings on the 1969 re-purposed deck, put back on the No Name 12 auto & gave it a test mow, hums like new!
Deck will be torn down & painted this winter.
Brought in the C-120 in prep for a new fuel pump then opened up the new to me 520 H to clean her out, dirty ol' girl...
 IMG_0181.JPG.aa808deb3a0264b3b33cd48a6f1ca82d.JPGIMG_0182.JPG.1ded9ec2a9fc3d38701770f3c53cabd6.JPGIMG_0185.JPG.ce57333408dd0538d29086eedcf17dfc.JPGIMG_0188.JPG.4db1dce03a28dc2af01753efebca7237.JPGIMG_0189.JPG.d3263507aabe58f9fbaa90d0f243a2de.JPGIMG_0192.JPG.cd5f023f765e48595bd4a93c2a13601d.JPGIMG_0193.JPG.d6fd1013b9ac55463ff496bc1dc612f5.JPG
This should look familiar to you 520 guys
Edited by Blasterdad
  • Like 8
lynnmor
This should loo familiar to you 520 guys
I pull my 520s apart every year to clean and then lubricate all the moving parts.  You will find plenty of debris under the gas tank causing rust if it gets wet.
Your electrical issues are 10% Wheel Horse and 90% caused by someone that should buy a disposable tractor.
  • Excellent 2
