Ed Kennell
What have you done to your Wheel Horse today?
kpinnc
2 hours ago, SylvanLakeWH said:
Gives “NOS” a new standard…
Never Once Started.... :lol:
  • Haha 4
ebinmaine
I like the line....
But!
It HAS been started.
Hehehehehe.
  • Excellent 4
ebinmaine
6 hours ago, JoeM said:
being way to picky
No such thing.
I'm impressed you got em lined up!
sjoemie himself
12 hours ago, OutdoorEnvy said:
There was no "ducking tomatos" emoji so just pretend there's one there :dunno:
I'm no expert either but I believe those fittings are cast iron which is a p.i.t.a to weld.
Considering you have little experience I would say this turned out great.
Might not be 'instagram-worthy' welding but you 'got er dun' that all that matters.
  • Like 6
ebinmaine
@OutdoorEnvy
That welding job is just fine.
You got the job done and held the pipe in place which is exactly the reasoning for using a welder in your case. That's called a win.
What did you use for a welder? Stick or wire feed?
WHX??
Ok stupid ? here Envy. Why didn't you just pull the nipple out of the block and replace it? Or did I miss something?
WHX??
14 hours ago, JoeM said:
I got 20 in each now, took it for a ride, oh my rough. You said 10 inside 4 ish outside, that’s my next move!
looks cool a heck!
20 pounds you are a glutton for punishment! That's gonna make them stiffer than a wedding ..... you know. :D
The 6 plys I got here I run flat!
Well... only cause the beads won't seat and won't hold air!
Looks cool ???? :banana-gotpics:
  • Haha 4
kpinnc
3 hours ago, ebinmaine said:
like the line....
But!
Forgive me Eb. I had to join in on the poking fun at ya!
I got plenty of unfinished projects myself!
  • Haha 2
kpinnc
Since we don't weld submarine or nuclear reactor parts, I think it's plenty good enough.
I'm not a welder. But I can melt two peices of steel together so they won't come apart. :thumbs:
  • Like 4
lynnmor
Correct, they were never intended to be welded.  If you really want a welded elbow, higher priced steel elbows are available.
WheelHorse520H
4 hours ago, ebinmaine said:
I like the line....
But!
Hehehehehe.
I love the peanuts tub for the gas. However I tend to lean towards the pretzel tub myself.:lol:
  • Haha 2
ebinmaine
3 minutes ago, WheelHorse520H said:
pretzel tub
Those work fine as well but I didn't have one handy.........
  • Haha 2
ebinmaine
@JoeM
Them duallies make all the difference. Love it.
cafoose
48 minutes ago, JoeM said:
Yep :wacko:
Before
After
Just got an idea for a future project :banana-wrench: I have an extended Suburban frame. With the engine closer to the rear axle, maybe I can make a pickup myself :banana-linedance:
  • Excellent 2
OutdoorEnvy
5 hours ago, ebinmaine said:
@OutdoorEnvy
Wire feed, this is just a flux welder for small patch jobs.
I put a pipe wrench on it after letting it soak over night with penetrating oil and this seemed like quite the fight would be in order.  It seemed like the rust had seized it together pretty good over almost 50 years.  I didn't want to risk damaging the block with heat and quench cycles and going Hercules on the pipe wrench.  So just decided welding on the elbow joint would be the safer course of action.
WHX??
I dunno Envy I had a 161 that it needed to come out. Plan A was to heat it....Plan B was saw it off close, cut the threads and collapse it.
Put a pipe wrench on it just for grins,  proclaimed a bit of french, and came right out. Now if hubs & hitch pins came out like that! :lol:
Saw Joe's cool rig at the BS last year. Said it should be a two seater....I think he said she rides in the back! :D
  • Haha 4
peter lena
@Maxwell-8  have a black hood myself , bought it new in 82  , MODEL C-85 , coming on  40 years !  did a magnum 12 swap a few years ago , been very good , still my favorite . loads of experiments on it , to correct cronoc problems, been very solid and reliable . think ill keep it  pete
  • Excellent 3
OutdoorEnvy
Pre Engine rebuild I might of given it all I had just to see what happens.  But the rebuild is complete at this point so I chickened out :dunno:
peter lena
@Ed Kennell nice job on that ed !  axel hub and trans burp , good tips , that size to size hub bore is the perfect slide hammer , pete
peter lena
@dmoore  thats a very sweet looking  101 !  detail care and love of the unit is very obvious , make it live on , good job , pete
