Ed Kennell
What have you done to your Wheel Horse today?
Snoopy11
Just now, Jhook said:
Starting getting the snow plow read for the rj58. Not sure if its the proper plow, but it appears that it will work fine
DUDE... that is awesome!!! Heck of a job! :occasion-xmas:
Don
Jhook
And the finished product. Works great. Just need to fab up a quick linkage out of some flat stock that will be bolted in place of the orange strap.
  • Like 4
  • Excellent 5
Snoopy11
I wonder if you could just use steel cable or chain? :confusion-confused:
Whatchya think?
Don
Snoopy11
6 hours ago, SylvanLakeWH said:
Leaves round 10 or so… just before snow hits…
And… a fail… my pvc wear bar idea crapped on me… not unexpected, but I was hopeful… I’ll just go back to the metal and set it really lightly to protect the new concrete drives…
Hey buddy... I know that the PVC idea did not work out... but you might try polycarbonate... strongest stuff I know of... :thumbs:
Don
Jhook
Whatchya think?
Don
I would absolutely do that rather than having to cut and drill a piece of steel, but the lever on this tractor doesnt have a stop, so if i use chain the lift lever will rotate all the way down and i wont be able to reach it to lift the plow back up
  • Like 4
  • Haha 1
Snoopy11
I wonder if you could make some kind of stop for it? :scratchead:
I am thinking... :ph34r:
Don
Snoopy11
I wonder, if you put some kind of steel or bolt right where the yellow dot I made, if that would work?
Don
Handy Don
is there a piece missing? I thought I've seen a notched arc-shaped piece that interacted with the lift lever to lock it at different heights on these (extremely cute) little guys.
Snoopy11
I was thinking the same thing... :thumbs:
Don
SylvanLakeWH
Pvc fail update…
Just plowed 2” snow with wear bar flipped… worked perfect with slightly less pressure setting…
If it holds great. If not, I’ll be looking into @pfrederi, @Maxwell-8@squonk , @Snoopy11, @Handy Don Suggested approaches… appreciate the input!!!
Edited by SylvanLakeWH
  • Excellent 2
wallfish
Drill and cut a piece of steel and be done with it. You can use aluminum bar if you need it to drill and cut easier.
That plow is made for a suburban but they made a special frame adapter so it can bolt on the earlier RJs too. The problem with that frame to plow mount bracket you have is the the axle is on the front of an RJ, whereas the suburban axle was under the frame. The RJ adapter hangs down under the axle and goes out and around the the front axle. You will need to do some kind of modification to use that bracket on an RJ. The axle will hit the bracket when it swivels if it's just bolted to the frame.
A foot pedal was used with a small piece of chain to release the pin for indexing the blade and a rope tethered to the corners of the blade was used to move it from the seat. Old School !
  • Heart 1
Southern_Secret
@pfrederi go to lowes or home depot and buy a 1/8 or 1/4 polly decking bored and you should be good, that's what i use to do on our track hoes when clean cement off after a project when i worked for my uncle.
Southern_Secret
9 hours ago, Ed Kennell said:
and tilled the horse manure into the gardens.
@Ed Kennell send me your address and ill keep a endless supply headed your way! :laughing-rofl:
  • Haha 4
953 nut
Not on the RJ, that was standard on the Suburban, 1960 & 1961
Pullstart
Whatchya think?
Don
Pullstart
@ebinmaine I’m a good week behind… but WOAH!
  • Haha 1
johnnymag3
Doing this....to get rid of this !!!!   417 A Frame up resto......
This is going to be FUN !!!
  • Sad 1
Gregor
So how did you repair your broken plate that attaches to the trans? Simply weld it?
johnnymag3
Nope....got a nice frame...hanging in the tree primed.....and a new tunnel......gonna throw out the broken frame. The new one will have arms that triagulate to prevent the issues
johnnymag3
Working on the sons 418 A...
    .taking off the tins to check Stator....why doesnt the tin come off the flywheel side? seems like the flywheel has to be coming off at the same time. The tin goes behind the flywheel just enough to make it so it does not clear....UGH
I do have all of the other tin work off around it also.
Also coil says 010 air gap.....seem right to you guys???   M 18 Kohler
pfrederi
Did you separate the small top plate??  #22 from the main housing #8
Maxwell-8
Took my first horse (the Raider 10) out for a second drive. A 1 year anniversary drive to be exact.
I had a blast!:eusa-dance:
  • Excellent 5
SylvanLakeWH
Three drives down and pvc wear bar worked great!!!
:banana-linedance:
  • Like 4
  • Excellent 5
