Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
19 minutes ago, WHX?? said:
food
Jim Budd. It's... Food.
  • Haha 1
ebinmaine
The Paint Department is at it again.
I have 4 of these 25ish lb weights and 4 of the 65 lb bolens weights to be made WH red.
First weight, first coat.
  • Like 6
  • Excellent 2
WHX??
Yep ... And I can hear you canaries in a restaurant .... I'll take the eggfoo Yung with a side of 80/90 drain oil...:lol:
  • Haha 6
ebinmaine
@JCM
You in?
I'm in...
  • Haha 1
WHX??
15 minutes ago, ebinmaine said:
to be made WH red.
Nice to see you got yer color blindness issue fixed ... told you a good optometrist could fix you up! :ychain:
The 25 lb weights ain't much but I think you might be able to stack them on the inside? Never tried it. Them Bolens weights do fit a :wh: nice.
  • Like 4
ebinmaine
Definitely agree on the Bolens weights. I've used them on the outside of our Wheels before. Good fit.
The holes in the middle of these 25-pound weights are large enough to put a hub through so they will bolt to the inside of a wheel okay. What I'm not sure about yet is whether they will clear the 2 inch thick aluminum spacers I have to use on my heavy weight rims and tires.
AMC RULES
:rolleyes:  Looks great!
What color red Lane?
Lane Ranger
Regal Red  but a professional job with painthardner applied over grey primer.
  • Like 4
AHS
12 hours ago, JCM said:
Looks like hot mustard at the Chinese restaurant  @AHS   Goes good with the pork fried rice.
Ok, that is stamped in my mind right now!! Yuck! However I do like Chinese food!
  • Haha 1
WHX??
They should ... all my spacers are real close to the diameter of a hub... maybe just a hair bigger.
Edited by WHX??
  • Like 6
ebinmaine
Excellent. Seems to me that's about what mine look like too.
pfrederi
23 minutes ago, rjg854 said:
Today was pretty much the same as yesterday this time I got the 16 auto out, which is my dedicated snow blowing tractor. Changed the transmission oil and filter and engine oil, greased everything and she's ready for the inevitable.
Like the wheels  Most of your blowing on gravel/dirt???
Are the adjustable for height
Edited by pfrederi
peter lena
@AMC RULES that honda set up looks awesome !  think its the way to go , for a repower , solid performance, did a total clear vinyl fuel rated hose change out today ,  on a 91 ,c12 . hose was getting hard , ran it thru a spiral wrap , wire protector , with hanger mounts , for a no chafing fit.  have an ignition switch wire harness coming in , to cover erratic charging. found a split and somewhat fried connector . just staying after what ever , that honda looks like it was made or it , pete
adsm08
I fed mine some peanut butter Sunday.
Worked out pretty well.
  • Haha 1
wallfish
29 minutes ago, ebinmaine said:
Yeah buddy we're still using that!
:thumbs:
ebinmaine
Yours burn peanut 🥜🥜 butter ????
AMC RULES
:blink:  If that thing was picking two railroad ties at once, that's pretty impressive in and of itself.  :greetings-clapyellow:
  • Like 4
ebinmaine
Agreed. I can't even do that....
  • Haha 4
JoeM
@Lane Ranger Front tire mfg? Front wheel color?
looks good!
