JoeM
Paint removal to match old finish
JoeM
I recently acquired a C160A and the PO repainted over the factory finish on the hood. The rest of the machine looks to be pretty much original and I like the used look.
My question, has anyone taking off a coat of paint to machine the old finish?
Tips welcome.
Joe
PaintonC160pic2.jpg.892e342c92522a330aca14c7c5b91aa7.jpgPaintonC160pic3.jpg.93bf6537894427e19c8ac463c816f75e.jpg+
AMC RULES
:confusion-shrug: Believe it, or not...
I've have great results just using carb cleaner...applied generously to a clean cotton t-shirt.
Trick is to not get it too hot(long exposure)...use quick wipes, and moderate pressure...
turn the rag after each pass to a clean area, reapply carb cleaner...make another wipe.
Best to try a small test.. first, in an inconspicuous area, before moving onto the entire hood surface.
  • Like 5
SylvanLakeWH
:text-yeahthat:
I have not tried this on a WH but have used it numerous times to get overspray off of stuff that I was not intending to spray...
oliver2-44
Lacquer thinner works similar to carb cleaner at a lower cost
  • Excellent 1
rmaynard
The previous owner painted the hood for some reason, most likely because the original finish was either faded, damaged, or rusted. You might find that taking off the top coat may reveal a finish worse than what you are starting with. Having said that, I have used citrus based stripper on a rag, doing small patches at a time and neutralizing with clean water as the top coat comes off. Doesn't work with all paints, but most cheap spray can finishes are pretty easy to cut.
JoeM
thanks,
I'm going to give that thinner a try. I will post some results in a few days.
JoeM
Tried Carb cleaner, didn't touch it. I was out of lacquer thinner. I took my sander with 180 grit and started to work on it. It seem like they primed over the original paint. I am going for old patina, I may just sand and clear over unless I come up with a matching hood.
  • Like 3
  • Similar Content
    • Tinman1962
      By Tinman1962
      What color is this called n where can one buy some
    • ToroMan
      By ToroMan
      Evening,
      Looking for a known aftermarket paint brand and color number match for my Toro 520xi model #73542. Normally I would have the local auto paint store match a tractor part, but due to Covid, that's not an option right now. Was hoping someone can recommend a color they have used for the same tractor, as I've heard paint with the Toro label is a bad match.
      Thanks!
    • Blackhood Bill
      By Blackhood Bill
      I'm located in central Indiana. It's now on the colder side here and I'm in the middle of a project. Project now slowed down due to cold and no heated area to paint in. Just wondering what everyone else was doing in a similar situation. Would like to see pictures and maybe an explanation of how and what you have to paint inside to control overspray and paint odor.
    • ohiofarmer
      By ohiofarmer
      So  So  we have 16 wheels to do.lets get started.
    • JHorseman
      By JHorseman
      Hey all,
      i recently picked up a Raider 8 and and Charger 12 to add to my small but growing collection. Both need restored including paint and I have never had much painting experience when it comes to auto paint. Can someone give me some helpful tips on prep , like if i need to strip it to bare metal or not and what colors to use? As well as how to mix the paint with hardener and clear coat.
      Thank you in advance!
