"Manic-Mechanic"
1990 312-8 "Classic"-Drive Belt
"Manic-Mechanic"
Hello,
     I mentioned changing the drive belt on this 312-8. The break down for this machine shows part 108501 which is 5/8 x 81. I removed the existing belt and discovered a strange thing, but not too uncommon, a belt 1/2 x 82! I believe this was done to cut corners or something? Now I am going to go with the part 7473 which is 5/8 x 82. This 1/2 x 82 belt, is full of cracks, and would help to explain the rattling while in neutral and the serious squeal engaging the clutch! Man, this machine has peeling paint like crazy and serious rust too. I will be slating this one for refurb in the spring, should look and drive, beautiful once complete.......(temporary hood from older 312-8).
Edited by Oldman
  • Excellent 1
WHX??
:wwp:
gwest_ca
7473 is the correct belt
Garry
  • Excellent 1
"Manic-Mechanic"
17 hours ago, WHX14 said:
:wwp:
I have this one for you. Also, what pictures would you like to see while the tractor is apart?
Oldman
  • Thanks 1
