WHX??
4411 to PAR LED Headlight Swap Out.
Skipper
Thanks guys:-)
WHX??
Andy also did this conversion with excellent results. Read about it here...
AndyK149
The rears are a fairly standard surface mount trailer light.  I have a link to a set in my thread but you can get these anywhere.
I see some talk about longevity of LEDs being a concern.  I can't really opine on that yet.  If one does burn out, I'll just buy a new one.  They are not very expensive.
It would be nice to try different versions of the bulbs: spot, flood, blue vs. warm white.  I don't have the time, resources or need to do that and can just reiterate that I am really happy with the fronts and rears that i purchased.
WHX??
Agreed
timo4352
  On 1/9/2018 at 2:25 AM, WHX20 said:
Did a nite test tonite and were just as illuminating as the OEMs if not a tad more. The 3k color is much like the 4411's. Unfortunately the tall chute blocks quite a bit of the light and the fact that the bezels block abit of light as well, leds and originals alike. Like putting a round peg in a square hole! Going to swap them out to the short chute tractor for more tests. I don't need lighting on the main sno chucker (short chute till the deuce ship comes in) as the cab lights will land an airplane but for after dusk tub rides in the summer for the kids & love rides with the Missus  might be just the ticket. I believe I have seen these offered up to 70 watt equivalent. Some more research is in order.
Lately,I have been contemplating getting rid of those rectangular headlight bezels, cutting and welding in some round tubing in to the hood instead.
For a different look and more light.
Lane Ranger
 WHX21
Jim:  I still want to see the heated steering wheel !
  • Haha 4
WHX??
Whatever you guys do DON'T  buy the the replacements  I had originally posted they are obviously junk and had both go out. Forget about the warranty.
Trying something different now and will keep you posted on results.
A tractor I had scored from @dclarke has got some nice ones in it but somewhat blocked by the tall chute. Top of cab lights to install as well. Perhaps Denny will chime in on his sorcery of where he got them.
Since it seems like most of my snow moving gets done after the salt mine and nite plowing and good lights are a priority.
Will do a product review.
ebinmaine
For what? You like to see stuff?
Just go forward til it sounds expensive and back off. Then start a new path.
Trina and I were out clearing the yard last evening. I'm running the snowblower which has its own light.
She's tooling around on Pigpen happy as a little girl.
I realized it was getting dark....
We're so used to plowing at night she didn't even turn on the lights I put in a few weeks ago...
I flipped the switch and she uhhh... Lit up. :scared-shocked:
dclarke
Jim, I can't remember where I got those lights. I'm hoping the receipt for them is in all the paperwork I gave to you.
WHX??
Nope....I looked... twice now and I have them all neatly unorganized in a binder.....:lol:
  • Haha 2
dclarke
I got them on the Internet, Jim. That’s about as much as I remember. Lol
  • Haha 1
WHX??
 good  POOR quality.
Edit & update: 2/4/21
They did not last long and what warranty!?!? :(
Edited by WHX24
WHX??
I had to pull the deuce, the one eyed bandit,  in for a quick skid adjust and threw one of new PAR 36's in the one that was blown. I got tired of the missus saying hey...you got a headlight out... even tho ther are aircraft landing lights on it.
Heck of a difference, a much more brighter 5k light.  Pic no good but will get some more when I do the garage door & road test.  These are real close to what you used Denny... maybe even brighter. Specs, amp draw and more pics forthcoming.
BTW  @dclarke I worked the snot out of your tractor tonight .... a good 8" here and performed flawless..... I even had to ditch the deuce in favor of yours visibility problems in the deuce as it got dark out and the plastic windshield.
 Wet stuff but as it cooled off turned to powder. I finally got the bugs worked out of Matt's pedal..... binding on top of the cam plate & pedal hitting the cab support.
Edited by WHX24
seuadr
I know this is an old thread, but i wanted to bump it to say that i replaced the headlamps and it is WAYY better. while i was on the superbrightled website, i also bought replacement rears and a flashing module for them.
Lights
Flasher
one flasher is sufficient for both lights so i have a total of about 15 dollars into this. the LED tail lights are also sealed, so i anticipate no moisture problems with them.
  • Excellent 5
DennisThornton
Lights
Flasher
There's some junk out there but overall LEDs are the way to go!  And the prices have come down enough to make that path far less painful than not long ago.
seuadr
i've had good luck with superbright's stuff. no DOAs and when i did have a problem with a power supply (i've used then a LOT of aquarium lighting) they were very good about getting me a replacement.
I figure, for 5 bucks, it was a cheap gamble. :)
WVHillbilly520H
What tire chains do you have there? A this seems to be a hot topic as well lately.
DennisThornton
Yes, I think SuperBright is first rate!  I bought elsewhere at first and that's how I found the junk!  Found some good stuff elsewhere too, but did by stuff that burned out in no time or wasn't much better than filaments.  Prices have come down in recent years!
seuadr
well, i have a drive that ends at the bottom of a hill and tends to freeze in place after the plow trucks have graciously shared the road's snow with me.. so i went full out and got an "H" pattern V bar with twisted links:
like this:
although i haven't had any luck finding the website i bought them from a couple years ago (didn't blow snow at ALL last year!) they have been AWESOME this year. I put oversized ag tires on, filled those 80% with RV antifreeze and then also put cement wheel weights in. has been a huge change for me trying to get traction in that crud at the end of my driveway
  • Excellent 5
ebinmaine
Lights
Flasher
So the lights are awesome.
The tire chains are awesome.
But the music...... Halestorm....?
seuadr
i didn't even realize that it recorded audio - glad i didn't say anything stupid :D
  • Haha 3
ebinmaine
If that's Lizzie Hale blasting away in the background I commend you!
WHX??
I can see Pullstart taught someone the finer points of taking a thread  :text-offtopic: :lol:
Gotta like the chains tho seuadr :handgestures-thumbupright:... I didn't have an asphalt drive I would have me a set of those ice eating monsters. Do me some burnouts and have some cubes for a :occasion-xmas: :D
They are not quite like diamond chains but close. Here might be a place to score those... Tire Chains-Best Snow Chains-TireChains.com
Ok back to lights.... I put some cab lights on Denny, 520H # 4, Didn't quite like the way @dclarke had it wired, was worried about too much draw. So made some improvements.
Made a custom switch panel and mounted it up in the cab corner like 520 # 1. Three switches for front, rear & flasher.  Don't ask me why I used lighted guarded switches ... cool factor I guess and easier to operate with gloved hands? Nawww... cool factor! Did I mention I'm an idiot for idiot lights!?!?
:) They was really cheap on fleabay 15 clams for five or so. Chinese made I'm sure but was surprised by the quality.
Edited by WHX24
speeling
OldWorkHorse
4in LEDs for the head lights in 314-8
  • Like 5
  • Excellent 2
WHX??
Here's the proof of the pudding .... @lynnmor obviously did some number crunching with Mr. Ohm and advised at 420 watts for the fronts and 60w a piece for the rears it would exceed the 20 amps of a 520 charging system. DMM told the truth. With all cab lights running. The flasher was hard to measure because of the intermittent draw of the flashing but was well under an amp. The first pic is just the lights of the switches. 2nd pic every thing on at full power. A paltry  8.5 amps.
You eagle eyes might notice something odd about pics 3 and 4 my last post ... double dog ya to see what's going on.
Don't mind the cracked DMM..... Squonk dropped it off a 10 ft. ladder when he was sticking his head somewhere where it didn't belong...:lol:
  • Similar Content
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our headlight bezel and lens are available with customized 3d logo, and feature a replaceable plexiglass lens, that can be ordered frosted or clear. You can even replace the lens with a different color such as yellow for blowing snow.
      The logo can be customized to match our ornaments with 3 different heads and 3 different wheels, and can be sent out unfiinished or custom painted. Can be ordered here:Wheel Horse Headlight lens, C series stylehttps://greystone-3d.square.site/product/wheelhorse-c-series-headlight-bezel-7075-replacement/6 leave us a note under"personalization" as to your lens type and any custom paint requirements.
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our "Caballo Diablo" ornaments add some extra flair to your customized ornament with the addition of a 12v led and light guiding filament to make the eyes glow or even flash! Available with solid red or flashig red LED, in unfinished, primed, or silver or multi-color painted finish, and in the same horse and head styles as our other custom ornaments. If ordered less than fully finished, the filaments are left long to simplify finishing, and can then be cut off leaving a clean end.They include mounting hardware and a bottom spacer for a clean finished look. Can be ordered  here:Wheel Horse "Caballo Diablo" hood ornament
    • Hoppy Rabbit
      By Hoppy Rabbit
      I went to a wheel horse show in PA and picked up a B-100 Automatic. I restored and cleaned it up after I brought it home. It had everything except the Headlights. I got a lense and looked online for the housing and cable. I found one on ebay except it was $67 plus shipping. It didn't even have all the parts. https://www.ebay.com/itm/265133794229?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=dhBhG47STyW&sssrc=2349624&ssuid=&widget_ver=artemis&media=COPY.I was just wondering if there is anywhere to get a cheaper one with all the parts so I can finish it.
    • Bill Murray
      By Bill Murray
      Looking for a replacement headlight assembly. I just bought a 520XI with a snowblower and I’m looking to fix the broken headlight before winter. Not sure if anybody knows of anybody selling one. I’ve been looking for a few months now. Thanks for any help.
    • r1jakecfd
      By r1jakecfd
      Hi Guys,
      I’m looking for a good quality LED lightbar lightbar to put on the snowcab on my 520. I’m just wondering which ones are good for their price and which ones to stay away from?
      Thanks,
      John
