tpuppo3
how do I attach my snow thrower?
tpuppo3
I have a C-161 8 speed manual.  We recently got some snow here in CT (about 8-9" for me) and because of the 2 inches of existing snow on my driveway from Christmas, I had almost zero traction.  (For what it's worth, went out about half way through the storm, when the wheels did hook up to the ground she plowed like an animal.)
A friend of mine gave me a snow thrower a few months back.  To my recollection, he said it worked on his C-161 hydro.  I mention this because I don't know if there's a difference in attachment sizes.  Just looking at it, it seems as though the "arm" portion of the snow thrower is too long.  Even so, how the hell do I hook this up?  I'm usually decent figuring crap like this out, but this one has me stumped.
Thanks for the help.  All the manuals I downloaded were vague and only listed parts and part numbers.  No "install" instructions, best I can find.
gwest_ca
See if this much later operator manual helps
or later again
Garry
tpuppo3
That was helpful.  I had a feeling it linked together in that fashion, but it's still not right.
When I lowered the thrower unit, it wasn't sitting on the ground 100%.  I lifted it up just fine, when it did, I just assumed it was uneven basement floor.  However I couldn't for the life of me lower it back down.  Is this the result of not having the lift assist spring? Or am I missing something still?
And if that's the case with the spring, what kind of tension are we requiring?  Can i ghetto-rig it with home cheapo springs and an eye-bolt with washers & nuts?
Edited by tpuppo3
WVHillbilly520H
Since you have the manual lift you may have to adjust your dial-a-height knob next to your lift handle for letting it down completely, as for getting it back down you may need to pull back on lift handle before pushing thumb button down to release the lock pin/latch in the height gate, and as far as the helper spring it's to help lift the blower up not down and yes you could get by with TSC or box store springs and an eye bolt, Jeff.
tpuppo3
GOT IT!  I had slid some wood blocks under the thrower to align everything a little easier...forgot to pull em out.  Total dumbass.
Gonna put on the flood lights and blow some snow.
Thanks for the help fellas!
  • Haha 1
WVHillbilly520H
When your in a hurry and busting butt, things seem to go awry, don't sweat it we all do things like that, Jeff.
Marv
Yes we do!!
Marv
tpuppo3
Thanks for the tip on the adjustment knob.  I actually was wondering what the hell it was for, but always tinkered with it when the plow was lowered.
The blower now sits with both wheels on the floor.  I'm lovin' it.
  • Similar Content
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • PWL216
      By PWL216
      Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
    • BobandJamie Raay
      By BobandJamie Raay
      400 Series WheelHorse Garden Tractor w 42" deck in good condition. Has a frame issue under the seat (needs welding) but runs well. 17-horse Kohler engine on tractor.
      Extra rear discharge mulching deck (42"), extra set of blades for mulching deck and side discharge deck,  snow thrower (42" with 20" chute) and trac vac with 5.5 horse Honda engine in good, working condition as well. All 4 hubcaps are included (rear not in tractor picture but see additional pic). Original paperwork, including owner's manual on all. Includes chains for snow traction and weight attachments for each wheel. All have been used at the same property since purchase and have been stored indoors throughout. Thanks for looking!
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
