Similar Content
By BrianStasC-101
Hello all. I am looking for suggestions on adapting the pto from my C series tractor to a harbor freight predator 420 13hp engine. I know the predator motors are a controversial topic however it is the route I have chosen for this particular machine. The intent was to mostly use it for plowing so no PTO required but it would be handy to have. Looking to hear from someone that has successfully done the swap that may offer any advice before I attempt to transfer it over. Just looking for any general pointers that will help me along the way to make it go as smoothly as possible.Â
By FAST41
I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
By Wendell
New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
By D_Mac
Well here I am again. In the " other brand " section of a Wheel Horse Forum. Its like my own little section down here. Picked this up today. Went to look at it last week made an offer and it was turned down. He called me today to see if I still wanted it. I always " want" I just never " need". So I went and got it. International Harvester Cub Cadet 106. Not exactly sure of the year. 1969 - 1971. It was owned by the same family since brand new. Father bought it new passed it down to his son. They each owned it roughly 25 yrs a piece. It is in some desperate need of some loving but I think it is in OK shape. All original Has a 10hp Kohler. 42 inch mowing deck, and a 42 inch snow blower. Has chains under the seat but I am not sure if they are tire chains as I have not pulled them out to see. Has original manuals. Runs and drives. It is a TANK ... very heavy. It is covered in greasy dirt. Need to clean it see where its coming from. Engine dosnt smoke when starting or running. This is my first tractor with a shaft drive and it also has disc brakes which is also a first for me. I hosed it down to clean off some old grass clippings and mud and oil and grease . After that I couldnt get it started but I am assuming its because I hosed it down good and coil wire wet. Fingers Crossed it will fire right up in the AM as it had previously done several times beforehand . I look forward to all your comments, opinions, advice....etc. May have paid a little more then I wanted too. Your opinion on its value as it sits I would like to hear as well. You know I will posting pictures of its progress as I try to fix it up some. I still need to go over it and see what I think it needs. The ratchet strap was just there to hold the deck up level. it was missing an R clip to hold it in place. I already put new clip in and its fine now.
