Wheel weights
By
Horse's ass, in Implements and Attachments
Similar Content
By 2drxploder
looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
located in charlotte nc area
By t_furl43
A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
By Ifixoldjunk
so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
By Ifixoldjunk
So I finally got around to finishing my custom bagger mount weight bracket conversion. It seems to hold weight really well.
all that really went into it was a few pieces of steel tubing and a hunk of bar steel. The long bolts I used came with the weight off amazon. A Briggs and Stratton 50 pounder. I’d like to eventually find a nice cast weight, but for now this works great!
By Ifixoldjunk
I had a bit of an idea for my 310-8. I’m thinking about making a weight bracket that kinda slides onto the factory wheel horse bagger mounts. Anyone ever do anything like this before? How much weight do you think the bagger mounts could hold? I probably wouldn’t put anything past 50lbs on it.
Kinda like the modern craftsman weights they mount to the rears of the tractor. I’d figure it’ll help counter balance the blower in winter
