Waynesboro VA Dan
PTO bogs down engine
Waynesboro VA Dan
I have a 520HC and have put the Deck back on, when I engage the PTO engine starts to die down. So I took the belt off to see if the deck might be dragging it down.
Even with the belt off, when I engage the PTO the engine dies down and will cut off if I let it. It runs OK  around the house without PTO engaged. I had just mowed with it in early Nov. without issue.
Any suggestions?
Ed Kennell
The seat switch may be disconnected.
  • Excellent 2
lynnmor
Probably the bearings within the PTO if not electrical.
Edited by lynnmor
  • Confused 1
Waynesboro VA Dan
Thanks, the seat switch was the problem. Ready to roll.  :)
  • Like 6
Ed Kennell
:text-welcomeconfetti: to the :rs:  Dan.
953 nut
:WRS:      Glad you were able to fix it so quickly.
SylvanLakeWH
KC9KAS
@Waynesboro VA Dan :WRS:
lynnmor
Since 953 nut was confused by my guess, I thought that perhaps the “throwout” bearing might be siezed.  The problem was described as the engine begins to slow down.
WVHillbilly520H
@Waynesboro VA Dan, you can bring that HC over to Middlebrook road Staunton VA, and I'll make sure it stays running, but on a more serious note glad to hear you got it back up and going "neighbor" and welcome to the :rs:,Jeff.
WHX??
:WRS:
Yes glad to hear it was nothing too serious.
  • Similar Content
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
    • DMB41
      By DMB41
      Hi All,
      My first post on here so apologies in advance for any rookie mistakes.
      First off, I am the proud owner of a "new to me" 312-8. I took it out for a spin yesterday and when I engaged the PTO, currently there is a 42 in side discharge mower deck on it, there were sparks flying from the disk directly below the muffler (maybe the flywheel or clutch?). Any idea what that may be and what needs to be addressed?
      Thank you !!
