Similar Content
By Maxwell-8
So yesterday I picked-up a C175. She was rusting away as she was stored outside. She had a new to her Kohler K341. @squonk The previous owner indeed better had"LET AN ELECTRICIAN CHECK his SHORTS!" as bad wiring shorted the battery out, and exploded/melted. She has a Sundstrand hydro pump with a Filter, is that normal? By the pump I believe it's a 1980. But you never now for sure as it's made in Oevel. Due to the bad wiring, the engine was in no running condition. But don't think the K341 has many hours on it. The hydro I don't know if it works. She was hard to push. So i lift up one wheel, so we could roll here one one wheel and the diff prevented the trans from locking up.
So first things to do:
1) get the engine running
2) replace the steering wheel, but don't think removing it will be very hard as it's already split in two.
3) replace the axleseals, the oil leak caused a lot of sandbuild up as she was mainly used on for leveling out a horse track.
4) clean all the acid and remove all the old wiring to do a full rewiring
5) replace the plastic seat pan with a metal.
6)...
I'm looking forward on my first C.
It's also my first hydro, I don't know a lot about them and prefer actual gears. Simpler and need less maintenance (parts-shortage).
But since I couldn't find another project WH and me hearing a lot of good things about hydro's on the forum.. I finally took the shot.
By Bill D
I bought this K341 and was wondering what it came on originally. It's a 13 fin block and has been bored .020 over already. It has a Kohler carb which may not be original. Bill
By RJ Hamner
Rebuilding a C160. everything worked prior to rebuild
Engine was fairly high time so machined .020 over and rebuilt
Finished rewiring and made sure all the circuits were in order
Starter would spin the engine. Made new coil wire and installed new spark plug
Starter won't turn the engine. Tried several times with and without spark plug Same results
Starter was what I took off the tractor prior to rebuild but can't say it is orininal
So.......Am I missing something or is a new starter going to be the answer?????
Thoughts? Ideas?
All help/input appreciated
BTW: Don't know if it means anything but the gear does not retract when key is moved back to ON
Bob
By RJ Hamner
I was breaking down the engine getting it ready to go to the machine shop. Everything was pretty normal until it tried to remove the PTO race and the engine pulley. As I was setting up the "puller" I noticed the end of the crankshaft looked different but never gave it much thought. After a half a can of PB Blaster,destroying the engine pulley and turning the air in the shop blue I was able to get the crankshaft free. There was a LOT of baked on crud and grease and I thought that was the problem. Cleaned everything up and found the race would not slide on the crankshaft??? Got out the measuring tools and found the answer. The end of the crankshaft was expanded will past the 1.125".
I had another crankshaft so I looked at the PTO end. It almost looks like someone bored the end and inserted some kind of tapered shaft and/or beat the heck out of the end and swelled the last 1/2"-3/4" of the crankshaft.
Can anyone think of a reason???
By midpack
I have a K341 that gave up a rod a while back. talk about "Big Bang Theory..." anyway, I tore it down to see how bad it got inside and to my surprise other than the rod, and the very bottom of the piston skirts the inside looks great!
the crankpin looked like it might have taken some abuse but i used a white stone (lightly) and some polishing paper and it must have been debris from the rod or piston because it came right off.
i took some measurements and it does show some wear. the crankpin measures 1.498 to 1.499 (low limit is 1.499) and out of round a full .001 (spec calls for .0005 max)
the bore measures .002 out of the wear limits and is out of round about .005. going to need a new piston anyway and i can bore it at work . no problem there.
my question is, would you re-use the crank in that condition? I can't grind a crank at work... lol
