Similar Content
By msdhomeplans@gmail.com
Hi I am trying to resurrect my fathers 1966 wheel horse lawn ranger. I have gas leaking from the carburetor and I need a replacement. I can not seem to find any accurate resources for the correct one needed.
Here are the specs for the tractor. I am also in need of a seat for it if you know which work for this model.
Thanks in advance!
Model Number L 156
Serial # 219222
Wheel Horse Lawn Ranger L-156
Tecumseh H60 gasoline 1-cylinder air-cooled Displacement: 221 cc
13.53 ci Bore/Stroke: 2.625x2.50 inches
67 x 64 mm Power: 6 hp
4.5 kW Starter volts: 12
By 67 WH 877
I have an oil leak coming from my Governor (k181 8 horse), anyone know where to get a new gasket, or part # ? Thank You
By BMW1
We added dye to the oil on a D200 to find an oil leak and discovered the leak seem to be coming from the bottom of the governor. We recently purchased this tractor so I do not know the history of it.
After removing the governor we found what looks like a casting flaw. Not sure what else it could be.
One picture shows the dye and the other the casting flaw?
Any ideas what it is and best way to fix?
By Goat 2141
How I adjusted the chain on a single stage snowblower 36".
By SimonC
Hi,
my throttle return spring is basically useless.
3 questions;
- if I remove the throttle butterfly screw that holds the shaft in there, do I need to use loctite or similar when putting it back ?
- I cannot find any reference online or anywhere to the model of carb I have; 676794 or 676704 (attached pic), are those springs normally standard (any link to a replacement would be great)
the rest of the carburetor is not in that good of a shape, I see all bunch of cheap carb around on ebay but again, none that match my part number. Other than the throttle/choke/fuel line, can I safely replace mine with another model assuming it's built for the same engine size (10hp).
my current block is a sbh-225 (hh100) installed on a raider 10 (69-70)
thanks
