slim67 2,737 #1 Posted December 16, 2017 I needed to put a set of wheel weights on my B-80 but the 26 inch terra tires had the valve stem on the deep side of the wheel. Therefore I had to put the original turf tires back on in order to use this set pictured. These have been on several tractors in the family and were made for a friend of my dads. They were on his friends SS12 which my dad bought off of him. They are 111.5 lbs apiece and can actually separate your testicles from the scrotum if you pick them up. I have mounted and removed these several times and they keep getting heavier each time. I've got a few other sets but not like these. Curious as to how extreme you guys go with wheel weights on your machines? I've seen a few on here but wanted to see how many of you load em up. 1 Share this post Link to post Share on other sites
953 nut 56,204 #2 Posted December 16, 2017 I have filled tires and wheel weights on the GT-14 and 418-C. The 418 has six gallons of RV antifreeze and 50 pound wheel weights on each side, The GT-14 had filled tires when I got it (rolled one onto a bathroom scale and it weighed 110 pounds) and then I added a set of two piece weights that bolt inside on the hub, think they were about 35 pounds each piece so 70 pounds per wheel. The GT-14 has a loader so I also have a large box of rocks supported by the three point hitch. I haven't filled the tires on the 1055 that I plow snow with but have 40 pound wheel weights and put a basket with four concrete blocks on the rear for added traction. 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #3 Posted December 16, 2017 I don't understand why everyone puts so much weight on there snow plowers. I have filled my C 160 rear tires with 5.5 gal of RV antifreeze plus the weight of the tires chains. Maybe 50 lbs per tire and I have no trouble at all with 6 to 10 inches of snow. I haven't found it needs any more then that. 7 Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted December 16, 2017 (edited) 14 minutes ago, BOB ELLISON said: I don't understand why everyone puts so much weight on there snow plowers Yeah, I have wondered that too..When I had a 314-8 I had 50 pounds and 4 link chains on the wheels and me ( 200 ) ..never had a problem pushing or pulling whatever I wanted.. Where the highway plow had piled it up at the entrance to my drive I sometimes had to take a run at it tho... If I had a loader, I think it would be required to have a lot of weight tho... Edited December 16, 2017 by Jerry77 clarification 3 Share this post Link to post Share on other sites
953 nut 56,204 #5 Posted December 16, 2017 13 minutes ago, BOB ELLISON said: don't understand why everyone puts so much weight on there snow plowers. If you had my driveway to plow you would have a new prospective on weights. 4 1 Share this post Link to post Share on other sites
slim67 2,737 #6 Posted December 17, 2017 30 minutes ago, BOB ELLISON said: I don't understand why everyone puts so much weight on there snow plowers. I have filled my C 160 rear tires with 5.5 gal of RV antifreeze plus the weight of the tires chains. Maybe 50 lbs per tire and I have no trouble at all with 6 to 10 inches of snow. I haven't found it needs any more then that. I dont think mine is a terrible amount for a snow plow or anything else for that matter. Ive lost traction with those weights and chains on a level driveway in the past on a 12hp Sears. Id rather have it and not need it then to need it and not have it. 1 1 Share this post Link to post Share on other sites
953 nut 56,204 #7 Posted December 17, 2017 With the loader the addition of weights and weight box added a lot of stability while the bucket is loaded too. Share this post Link to post Share on other sites
BOB ELLISON 2,981 #8 Posted December 17, 2017 I also understand weights for a loader. And I say if you think you need more weight for plowing you should do what you think is best. I've not found the need for more then I have now. When i plow I don't push all the snow with the plow straight I angle it left or right for 2 or 3 runs then I push with stright blade . 4 Share this post Link to post Share on other sites
Jerry77 1,218 #9 Posted December 17, 2017 1 hour ago, 953 nut said: If you had my driveway to plow 2 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #10 Posted December 17, 2017 @953 nut I wish I had a driveway like yours. You have to be careful not to slip off and down the hill. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,161 #11 Posted December 17, 2017 I am going with no chains or added weights this year for first time. So far - three snow events on three driveways and it is working amazingly well...(all drives are 150' long and relatively flat)... Have I slipped - yes. But the ride is way smoother without chains and the asphalt and concrete driveways are not getting chewed up... Taking slightly smaller bite of snow with each pass, but it is still WAY faster than my walk behind two-stage... Chains absolutely do grip better and weight makes a difference, but I am liking the smooth ride, no added work of mounting chains and weights and no damage to drive... Experiment in progress... 3 Share this post Link to post Share on other sites
953 nut 56,204 #12 Posted December 17, 2017 1 hour ago, BOB ELLISON said: have to be careful not to slip Last Friday's snow storm came as quite a surprise and I had to trudge through six inches of snow over to the barn to get the . Part way down I felt like I was going to slip so I just sat down and did the slide for life to the bottom of the hill. It was fun. 2 2 Share this post Link to post Share on other sites
slim67 2,737 #13 Posted December 17, 2017 10 hours ago, SylvanLakeWH said: I am going with no chains or added weights this year for first time. So far - three snow events on three driveways and it is working amazingly well...(all drives are 150' long and relatively flat)... Have I slipped - yes. But the ride is way smoother without chains and the asphalt and concrete driveways are not getting chewed up... Taking slightly smaller bite of snow with each pass, but it is still WAY faster than my walk behind two-stage... Chains absolutely do grip better and weight makes a difference, but I am liking the smooth ride, no added work of mounting chains and weights and no damage to drive... Experiment in progress... That's an interesting experiment. You are a mad scientist! Or are you a nutty professor?🌡 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 26,161 #14 Posted December 17, 2017 26 minutes ago, slim67 said: That's an interesting experiment. You are a mad scientist! Or are you a nutty professor?🌡 Most would say both... And no, I have not gained that much weight from last year... 1 1 Share this post Link to post Share on other sites
slim67 2,737 #15 Posted December 17, 2017 37 minutes ago, SylvanLakeWH said: Most would say both... And no, I have not gained that much weight from last year... It's ok to think outside the box. 2 Share this post Link to post Share on other sites
over60pirate 24 #16 Posted December 18, 2017 I welded a length of barbell bar to a 1/2" x 2" flat bar, and bolted it to my wheels. Then loaded it with weight plates. 50# ones on the outside Share this post Link to post Share on other sites
slim67 2,737 #17 Posted December 18, 2017 1 hour ago, over60pirate said: I welded a length of barbell bar to a 1/2" x 2" flat bar, and bolted it to my wheels. Then loaded it with weight plates. 50# ones on the outside That's a good idea. Share this post Link to post Share on other sites
bigplow1 26 #18 Posted January 14, 2018 Yeah I Def gotta have chains and weight uphill gravel drive and it's steeper than 953 nut driveway I am still working on the 520h but the tires will be loaded 2 link chains and barbell weights and if it gets bad I have 200 lbs of weight for the rear Share this post Link to post Share on other sites
Tankman 3,520 #19 Posted January 15, 2018 On 12/16/2017 at 6:56 PM, 953 nut said: If you had my driveway to plow you would have a new prospective on weights. Driveway like that would make me think, "Heated driveway next time!" 1 Share this post Link to post Share on other sites
