Similar Content
By rustytractornut
I am restoring a 953 Wheel horse can anyone tell witch end of the engine the oil drain plug should be. i removed the oil pan did not note where the drain plug was located.THANK YOU. also looking for a replacement for the front wheel bearing seals.
By Jparkes43
Hello on my kawasaki 227-5 17 hp single cylinder i was thinking about putting a straight through pipe on it and people time and time again were mentioning burnt or warped exhaust valves and i have no idea how bad this is or how common it is so i just want to know if i should or shouldn't straight pipe the engine
thank you
James
see my other thread about tachometer gauges
By Eric857
Hi RedSquare,
I am in the process of restoring a wheel horse 857 and i have just received decals to put on the machine but in not to sure how to put them on and protect them from getting scraped off. any suggestions?
Thanks
By zanepetty
Hey everyone. As you know I'm hot and heavy into wheel horses now and many of you have answered many of my questions and helped me TREMENDOUSLY. But I've finally decided to give my horse a paint job and I thought I'd post pictures along the way. Here's the engine cleaned,sanded, prepped and primed. This is the first thing I've done. :)
By zanepetty
I'm thinking of mounting farmall cub headlights (the thin looking ones) to my 753. I know they're not original wheel horse obviously and I'm usually a stickler with that type of deal but I think they would look good. Is this a bad idea in you're guys' opinion?
