Devin
C-175 Update
Devin
It runs and drives!
  • Like 3
  • Excellent 2
953 nut
:woohoo:         so, other than a new fuel line and cleaning up the fuel pump what was needed?:  Are you going to buy the parts tractor too?
JERSEYHAWG /  Glenn
Didn't sound like to much trouble for you. That's great.
Glenn
Devin
I bought a battery and a fuel filter and cleaned the fuel pump thats all i did and it runs and drives! @953 nut and I'm hoping to buy that parts tractor soon and get the deck off it I can then mow with it and I'll paint it and replace the rear fender and I just went looking for the tractor in kissimmie and its gone😥
Edited by Devin
  • Similar Content
    • Jayzauto
      By Jayzauto
      I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint.  Engine has been replaced with an identical Kohler KT-17 Series 1.  New Carb has been installed.  Battery, solenoid and cables have been replaced, starts great.  Installed new Tires and Tie Rods.  Installed radial bearings in spindles, so it steers beautifully.  Fuel line has been changed, as well as headlights.  Bew mule drive and belt fot tiller and functions as designed.  I'm sure there is other items that have been done.  Very reliable machine. $800/BRO
      Selling all my WheelHorse items and moving South.  Have other tractors ad parts if interested.
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • D_Mac
      By D_Mac
      Well fellas I may be going to the dark side. Going to look at one tomorrow. You know the story, ran a couple years ago when parked. Now no spark. Has mower deck with new blades and belt. Tires have new tubes. Has the plastic rear fenders/ seat pan that's busted up. I have no experience with the kohler twin. I know you like pictures but don't have any. Any helpful suggestions on what I need to look at tomorrow? Any idea what a replacement metal seat pan / rear fender unit will run? Worth ? I'd like to save it but really don't have the room for another but that's never stopped me before. Like to hear all your input. Thanks
    • Foxer14
      By Foxer14
      My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
    • Josh Opitz
      By Josh Opitz
      I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
