Countdown To Christmas!
Dg1970
Tractor won’t move
Dg1970
Hello new member here .  This fall I picked up a 1970 raider10 model 6051. Came with snow plow and mower deck . So we just had our first snow and gave the tractor a shot and it worked great until it stoped moving no matter what gear I was in . The transmission is the high/low 3 forward and reverse. I’ve gone through the forums and seen other people with the same problem. I checked all the keys(both wheel hubs and the pully) brake drum doesn’t have one . All were good. Pulled on the shifter that was solid . Checked the diff by spinning the wheels , all seemed good . I pulled the transmission and double checked everything . That’s when I noticed kinda like a dead spot in the diff kinda like the gears were slipping. I split the trans and pulled the diff but couldn’t find anything wrong. No stripped gears . Now I’m baffled. Please help this tractor is great. P.S. it’s a uni drive
Skipper
if you spin the input shaft on the trans, does the wheels/axles then turn? If yes, you look to see why the input shaft is not connected to the engine via belt drive. if no, you have a problem with/in the trans.
Edited by Skipper
  • Like 4
SylvanLakeWH
:text-welcomeconfetti:
You are in the right place for good info!
gwest_ca
Are you sure the high/low shifter is fully engaged? They will act like a neutral if not fully engaged.
Garry
  • Like 4
  • Excellent 1
Racinbob
:text-yeahthat: It's very easy for that to happen. :)
Dg1970
Thanks for the fast responses I’ll check when I get home tonight and let everyone know what I come up with
Jerry77
Welcome to................:rs:Glad you are here.....:)
Dg1970
Do they offer a gasket/seal kit for this trans ?
Dg1970
Thank you
Dg1970
Sorry guys it’s been a couple days but it looks like it was the high/low stuck in between just waiting on some new seals and gaskets . Should be good to go . Thanks again for your help 😊
  • Like 3
