Red144runner
Diamond plate foot pads
Red144runner
The sand paper foot pads worked fine on my 3/12. I did like the look of the later style rubber pads that partially went up the rear fender.
We picked up a bunch of 4'x8' sheets of 1/8" diamond plate in the mill clean out last month. Most will be used on my GMCs flatbed. There were some smaller pieces and I had wanted to make diamond plate pads for a while.
I didn't think the steel was any thougher than the 3/16" I had just used but I was wrong. Was harder to cut and drill.
I cut 2 pieces for each side. A 12"x6" foot pad and 4"x6" rear piece that I welded on at the same degree as the fender. Next I filed the holes square to take the 5/16" carrige bolts. They will be held on with 3 per side. Finally I primed and 2 coats of gloss black rustoleum followed by a coat of truck bed liner. I could put them on now but I've slowly been replacing all the hardware with stainless and don't have the bolts yet. Should look cool
  • Like 6
  • Excellent 3
WHX??
Like the idea of SS hardware. Might be a good idea for one of us to to with AL diamond plate too. If your gonna do bed liner what's your theory behind the coats of gloss and not just a primer? Must have took a bit of filing to get those squares for the carriage bolts?
Edited by WHX12
Red144runner
The bed liner was an afterthought. The original plan was just the black paint. Then after I painted it I found 2 cans of bedliner in our cabinet. So it's extra protected. I did the underside too to protect the tractors finish.
I just did the same thing making my plows cutting edge. I found it harder to file the thinner diamond plate than the 3/16" I made the cutting edge with.
WHX??
Extra non-skid too ! :handgestures-thumbupright:
Tankman
Don't forget Never-Seez on all bolt threads.
Red144runner
Bolted up, ss hardware (neverseized). I tried it out and the bedliner offers great grip!
