Devin
C-175
Devin
Bought a C-175 a month ago Havent been able to get it running yet but when I do I would like to be able to use it I bought it without a deck and I want to know if there are any compatible decks or if I have to buy a original one because from what I have seen those are rare and expensive
Edited by Devin
953 nut
3 minutes ago, Devin said:
any compatible decorations or if I have to buy a original one
If you are talking about decal sets you can get hold of Redo Your Horse, Terry makes great decals for :wh:.
http://www.redoyourhorse.com/c-105-c-125-c-145-c-165-c-175-c-195-blackhoods/
953 nut
Wondered about that.  This list has all :wh: attachments and what they fit.
WH Interchange 1955-2000.pdf
  • Thanks 1
Devin
Thank you! But now I'm stuck because I am not sure what size deck it would need
oldredrider
Your yard size usually determines what size deck you need. 48" for larger yard, 42" for a smaller yard or one with a lot of obstacles.
Devin
Ok so whatever one I want?
Wishin4a416
Decks are really pretty plentiful. Some junk and some very nice ones. Craigs list should be very helpful.
Devin
Arent only certain ones interchangeable with these tho? Because ive seen soke deck on Craigslist nearby in decent shape for 50-100$ but I didnt think they would work
Skipper
Do not know what you mean with soke deck, but all 42 to 48 WH decks from that era will fit.
 42's are plentiful and rather cheap, 48's a bit harder to find, and more costly.
42RD if you do not want side spray of clippings in your flower beds
Post a pic of it, and we can tell you if it will fit.
Edited by Skipper
Devin
It was supposed to say seen I'm on my phone sorry small buttons, but ive never seen a wheel horse deck on Craigslist I just saw one on eBay about 2 hours away for 200$ it has small stress cracks where the bolts go and needs a idler pulley is 200$ to much? I dont even have that much to spend on fixing the tractor at the moment
Skipper
Do not worry. We all have spelling mishaps ;-)
Well I am not sure of prices in florida, or what deck you are looking at, so really cant say. Up north you get a lot of deck for 200, and also some decent ones for way less.
There are people who think they are made of gold, but also some realistic people out there too ;-)
I have often seen what appears to be OK 42" decks advertised at around the 75-100$ marker
If you have a big lawn, you could consider a swept front axle and a 60" light duty deck. I have heard that is doable, and your 175 can pull it off I think, but that would set you back even more $$
What you are looking for, is a deck with a mounting system like this:
1
I assume you have the mule drive to drive it?
Just checked CL for your area. There is a complete tractor in kissimmee advertised at 150. Looks like a parts tractor, and it appears to have a deck. Cant comment on condition. :-)
Heck, you can even part it out and have a free deck and a few 100$ in the pocket I would guess.
Edited by Skipper
953 nut
Great point @Skipper, Best to get a deck that has a mule drive with it unless the tractor has one already.
I have a personal preference for a 42" Rear Discharge deck. The clippings go out the back so the fly wheel screen won't be picking up clippings interfering with  cooling the engine.
Devin
1
Mine does have the mule drive thinf on the front and I'll have to check out the mower in kissimmie
953 nut
The only other caution that comes to mind is to be sure it came from a garden tractor with a horizontal engine crank shaft rather than a lawn tractor with a vertical crank.
Devin
Alright the tractor in kissimmee looks good and I need a couple other parts like the rear fender and the rims so that might be a good buy
  • Thanks 1
953 nut
If this is the one you are looking at be aware that the rear fender is plastic and they tend to crack, but for the price if the deck is good you get the C-145 for free.
Devin
Yeah i know they crack thats why i need it mine is really badly cracked
  • Thanks 1
953 nut
Lots of people have used the later rear fenders from 300 and 400 series to replace the plastic ones.
  • Like 3
  • Thanks 1
Devin
  • Sad 1
SylvanLakeWH
What 953Nut says...Thats what PO did with mine...Much better I think...
The cocktail on the hood is my Black Hood toasting a welcome to your Black Hood!!!T
Edited by SylvanLakeWH
  • Excellent 2
Devin
I got to hear the m18 on my tractor roar for the first time since I got her a month ago i poured some gas in the carb and kept pouring it so it ran for a little bit and now I have officialy ruled it that i need a new fuel pump! After I get one it should run amazing I dont even know if the transmission works yet so that's the scary part as of right now
Edited by Devin
  • Excellent 1
JERSEYHAWG /  Glenn
Devin, my advice. Dont buy anything till you get your machine running. That should be your first order of business. Just a comment.  Seems foolish to me is all.
Glenn
oliver2-44
Since your in Florida search the classifieds on here. Several months ago someone was selling a lot of WH and other tractors stuf helping to slowly liquidate an estate
Devin
Glenn
What about that parts tractor though
i looked through about 4 pages of the classifieds earlier and didnt find much a couple decks for 200-300$ actually there was one for 20$ and it was apparently in decent shape but its all the wsy up in michigan and it said local pickup only
  • Similar Content
    • Jayzauto
      By Jayzauto
      I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint.  Engine has been replaced with an identical Kohler KT-17 Series 1.  New Carb has been installed.  Battery, solenoid and cables have been replaced, starts great.  Installed new Tires and Tie Rods.  Installed radial bearings in spindles, so it steers beautifully.  Fuel line has been changed, as well as headlights.  Bew mule drive and belt fot tiller and functions as designed.  I'm sure there is other items that have been done.  Very reliable machine. $800/BRO
      Selling all my WheelHorse items and moving South.  Have other tractors ad parts if interested.
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • D_Mac
      By D_Mac
      Well fellas I may be going to the dark side. Going to look at one tomorrow. You know the story, ran a couple years ago when parked. Now no spark. Has mower deck with new blades and belt. Tires have new tubes. Has the plastic rear fenders/ seat pan that's busted up. I have no experience with the kohler twin. I know you like pictures but don't have any. Any helpful suggestions on what I need to look at tomorrow? Any idea what a replacement metal seat pan / rear fender unit will run? Worth ? I'd like to save it but really don't have the room for another but that's never stopped me before. Like to hear all your input. Thanks
    • Foxer14
      By Foxer14
      My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
    • Josh Opitz
      By Josh Opitz
      I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
