Similar Content
By WH1618speed
1965 Wheel Horse 855 with 42" blade and chains
Runs good
Sheet metal is very straight, great candidate for restoration.
Missing Belt guard
Will sell tractor by itself for $500 without blade and chains
Blade is straight and lots of cutting edge left... just a little rusty.
Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
I can also deliver to the big show in Arendtsville, PA... IF you prepay.
Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
By Marc M.
Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
By T-Mo-(Moderator)
Drawing for both the short lift link, and the down pressure lift link for the front snow blade.
Short lift link 105052
Long lift link 7706 most likely replaced by 7706-01
I drilled 3/8" holes in the bar and used 3/8" x 2-1/2" Gr.5 bolts. Cut the threads off.
Weld the head of one bolt to the bar and try it for alignment. I ended up installing the 2nd bolt from the other direction and welding the head only. This provided 1/4" of offset and the pins are square to their attaching parts to minimise wear.
Drill holes in the bolts perpendicular to the bar for spring pins. Use a countersink to ease the edges of the holes.
With the holes drilled like they are you now know where they are and you can instal the pins blindfolded.
With manual lift the float is built in - everything floats including the lift handle.
With hydraulic lift the float is accomplished by connecting the bottom of the link to the slotted hole. Down pressure is still available when the pin hits the bottom of the slot.
Garry
By Goldann520
Hey guys, @wheelhorseman, @WVHillbilly520H, brought this stuff home today. Big question did wh make a gooseneck trailer like this? Really hope so, paint looks right and came out of the same lot as the rest of this. Owner swears he had blade and blower on the 414-8 Which means it'll fit my 312-8. He talked me (or bribed) me into taking tractor with me. Got the weights and chains too. $440 for all of it. Tractor runs but has fuel delivery problems.
By mkueb
Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor? There are two push in bearing units (inner and outer) per wheel. I first attempted to replace with standard bearings but quickly found out these are not standard sizes. It's been a while since I check and I don't completely remember, but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing. At the time, I remember finding bearings but they wanted somthing like $100 for each bearing. I was able to located two bearings and did purchase them for a reasonible price, but am still looking for two for completing the set. The part numbe ron the two that I was able to locate is 104396. If anybody has any ideas, I would appreciate.
Thanks
Marc
