lak1965
C-160 Cab install
Achto
Looking great!! Should keep you cozy while cleaning up the white stuff.
WHX??
Looks really good! :handgestures-thumbupright: Nice patina on that old girl and nice marriageof of new red and old. Any plans for (more) weight on the rear & how does that C handle the front beast?
lak1965
It steers a bit hard. I was thinking of getting a steering quickener and install it backwards to act similar to 520 steering reduction.
JERSEYHAWG /  Glenn
Excellent    :handgestures-thumbupright:
Glenn
DougC
Enjoy your new cab!!!  I know I love mine in the winter.  :)
lak1965
Here it is. Moving snow like nobodys business. Nice and cozy warm and dry in the cab!!
Edited by lak1965
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
