DBlackston
Plow Identification
DBlackston
I recently purchased this plow, but have not picked it up.
Is this an authentic wheel horse Plow?
How do I determine a model or a size?
How does a coulter attach?
Pics of one all fixed up?
squonk
Looks like an 8" Horsie plow to me. :)
Plow was actually made by Brinly
rearcable008_zpsaa5253f4.thumb.jpg.8891e3c325b1a5fc591451dd40f3c0e8.jpg.b7a53efcbe4c5c3407bcb6a943fe0d28.jpg
Edited by squonk
DBlackston
Have a model number?
Ever see a coulter on them?
gwest_ca
Garry
DBlackston
Well darn!
It doesn't look like my coulter is the correct one for my plow.
Thank you for the links!
Edited by DBlackston
squonk
Coulter just gets in the way! Plow away! :banana-dreads: :banana-blonde: :banana-linedance:
Edited by squonk
  • Similar Content
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
    • ToroMan
      By ToroMan
      Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542.  I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly.  Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need!  I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know.  One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
      Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
      From Toro site:
      Model #: 79355
      48" Snow/Dozer Blade
      Model #: 95-4090
      48" Dozer Blade Retrofit Kit
      Thanks!!!
    • Marc M.
      By Marc M.
      Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
      Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
