Bushradical 21 #1 Posted November 24, 2017 Hey everybody, first post , love the forum. I just bought a 310-8 tractor ( my second Wheel Horse) ( my other is a B-80)...........When checking fluids, I found there was no gear lube on the trend dipstick. BUT, when I took out the square plug on the left side of the tranny lube came right up out of the hole. Is there another place you fill these trannies from to get the level up the dipstick OR do you fill until its level with the angled fill hole on the left? Share this post Link to post Share on other sites
Ed Kennell 38,687 #2 Posted November 24, 2017 Make sure the dip stick tube has not pulled up out of the tranny. I don't have a 310-8, but others should be here soon to offer advice. to the 1 Share this post Link to post Share on other sites
Bushradical 21 #3 Posted November 24, 2017 Thanks Ed. I'll check to make sure the tube is seated. Share this post Link to post Share on other sites
stevasaurus 22,872 #4 Posted November 24, 2017 If you have oil coming out the fill hole, you have enough oil in the trans. The top of the fill marks on the dip stick should be relatively even with that plug. 1 Share this post Link to post Share on other sites
953 nut 55,837 #6 Posted November 25, 2017 310-8 is a great machine. Was the oil in good condition? Some times a little water will get in there and give a milky appearance. 1 Share this post Link to post Share on other sites
Bushradical 21 #7 Posted November 26, 2017 I think I found the answer in another post. They said to go by the dip stick, that the casting of the uni-drive was made for 3/4 speed and with the 8 speed tranny the oil is above the fill hole before it gets to the dipstick. I have a b-80 with the same tranny and the two dipsticks are the same. The b-80 has lube on the stick inside the marks and when you loosen the square fill plug oil runs right out. So It seems obvious that there needs to be more oil in the trans that the original film hole will allow. I also read they didn't add the dipstick until the 6/8 speed tranny came out and the oil level ended to be higher than the hole. 1 Share this post Link to post Share on other sites
Lee1977 6,804 #8 Posted December 3, 2017 (edited) There is about a half quart difference between the plug on the side and the 2 quarts required for the 8 speed transmission. I found that after having the 312-8 apart and refilling it. Edited December 3, 2017 by Lee1977 Share this post Link to post Share on other sites
