Denis L Goulet
help,stuck in reverse
Denis L Goulet
hi I am a newbie to wheelhorse tractor,i bought a 1994,520,20 hp,wheelhorse tractor with mower and snowblower,a few days ago I back in garage to put cab,blower and tires and chains on it to prepare for winter.started it up on first turn, considering it was sitting at sellers house about 6 months, everything was fine , backed it up in garage ,worked on it a few days. When came time to leave the garage, started it up it would go only backwards,  it would not go in neutral or forward. I put it back up on the jack, wheels turn free opposite sides front or back when stopped. Shifter stuck in reverse when stopped as well, how do I free it up and where is the shifter assembly located, please help thanks.
SylvanLakeWH
:text-welcomeconfetti:
Folks with 520 expertise will be along shortly - I have no doubt!
You are on the right forum!!!
BOB ELLISON
Welcome to Redsqure.
I'm not a expert on 520h but i did own one. but sounds like linkage is binding or loose.
Check the bolts that hold the frame to axle.
4 bolts under tractor are known to come out letting axle to bind . Other then that other experts will help you here soon.
Achto
You should be able to see where the linkage attaches to the trans by lifting the seat up. Check to see if things may be bound up under there.
Denis L Goulet
ok thanks ill check this tomorrow.
KC9KAS
@denis goulet :text-welcomeconfetti: to :rs:
953 nut
:WRS:              Did it shift all right before the cab was installed? Can't think of any interference a cab would create, but wondered.
JC 1965
Sorry I have never worked on a 520.         :WRS:
shallowwatersailor
Simple check, but you can't move the linkage with the brake on.  A few months ago a member had a 5xi that had trouble moving the linkage, It had been sitting outside and mice had made a home under the fender. You may have a similar situation. Unfortunately the cab will need to be removed to get the fender off.
I would start by checking the linkage at the dash. Take the panels off to observe. it has the notch that must be overcome to move from reverse to forward. Make sure that is not binding and work your way to the rear. If all of that is working properly, unbolt the fender to check under there.
Edited by shallowwatersailor
  • Like 4
Ed Kennell
The '88 and '89 520s had the motion control on the console where it always worked very well.  Beginning in '90, they moved it to the steering column where, in my experience, it was not as smooth and was  more difficult to use.   The lever has to be lifted before it can be moved forward  and I found  the shaft would bind preventing the up/down movement of the lever.    I only keep the hydros with the console mounted levers.  Also makes it easy to install my red neck foot control system.
  • Like 4
Denis L Goulet
yes it was, but now I realize that I lifted up the tractor by the hitch on back to put the stands under axle, maybe something happened then I don't know.
thanks I hope.
thanks very helpful, I checked it out today and it seems fine, I will continue up towards steering column. I just had a idea if I was to remove that link could I test the transmission manually by moving the gear with pliers to see in tranny works like it should.
Denis L Goulet
thanks.....
thanks, I will check this out for sure
Denis L Goulet
sir, I have the most respect for veterans and I thank you for serving if you did, my grand father was killed in Antwerp Belgium 16th of December 1944 when Germans launched a v2 rocket on the city, he was 3 months away from coming back home to Canada and reuniting with is family. I salute you.
  • Sad 1
Denis L Goulet
hi, it took a long time to reply, I have found the problem, I feel stupid, but this is what happened, I dropped a screw driver under the seat and it logged in transmission linkage blocking linkage, I removed it now every thing is fine. Thank you.
  • Excellent 3
  • Haha 1
SylvanLakeWH
Hey - Good news!
If you are going to have a transmission "problem" that is the kind to have!!!
  • Like 4
953 nut
Takes a big man to pass this tip on to us.   :party:   Glad that's all it was.
  • Like 4
Denis L Goulet
On ‎20‎/‎01‎/‎2018 at 8:04 PM, SylvanLakeWH said:
Hey - Good news!
I agree....thanks for the interest.
I agree......thanks for the interest.
thanks.
linkage was blocked by a dropped screw driver under the seat ooooops.
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • Truckedup1
      By Truckedup1
      I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
    • jleitschaft
      By jleitschaft
      Hello All,
            New to the group and looking for advice. My father was a devoted wheel horse enthusiast for many years. He only cut grass with a wheel horse tractor (rear discharge deck) pulling a Parker lawn sweeper. We have a lot of property and it took him a while but he was retired and loved being on the wheel horse. When he got sick, I had to take over all the lawn maintenance. All of our family lives close on the same road. At the time, I was responsible for maintaining 7 properties plus my fulltime job. Using the wheel horse was not an option for me so I bought a commercial zero turn mower.  Unfortunately, in 2017 my father passed away. I have all his tractors and it has been hard for me to think about what to do with them. He had 6 wheel horse tractors total. 3 tractors we used for cutting grass and 3 tractors are show pieces that have never cut a blade of grass. I have a few guys that have been asking me for years to sell them but I am not sure if I’m ready. I am turning to the group because I am lost at what I even have. Its my belief that the tractors are rare and the conditions are mint. If anyone would be willing to express their opinion and provide feedback I would be grateful.
      Wheel horse 420 LSE (shows 7.5 hr)
      Wheel horse 520 hydro (shows 92 hr)
      Wheel horse classic GT (shows 26 hr)
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
