Similar Content
By msdhomeplans@gmail.com
Hi I am trying to resurrect my fathers 1966 wheel horse lawn ranger. I have gas leaking from the carburetor and I need a replacement. I can not seem to find any accurate resources for the correct one needed.
Here are the specs for the tractor. I am also in need of a seat for it if you know which work for this model.
Thanks in advance!
Model Number L 156
Serial # 219222
Wheel Horse Lawn Ranger L-156
Tecumseh H60 gasoline 1-cylinder air-cooled Displacement: 221 cc
13.53 ci Bore/Stroke: 2.625x2.50 inches
67 x 64 mm Power: 6 hp
4.5 kW Starter volts: 12
By hotajax
Morning - Looking for a carb. There are plenty of carbs on the 'net, but 99% do not fit because of the choke configuration.
Background info: Engine - K321S, 14 Horse Kohler.
Choke control cable is routed to come from BELOW the carb. To close the choke, pull on the choke knob, the choke shaft rotates counter clockwise, and the finger tab sits at the 10 o'clock position.
To open the choke, push on the choke knob, the choke shaft rotates clockwise, and the tab sits at the 1 o'clock position.
Where can I get his carb? Thanks in advance.
By 67 WH 877
When I purchased my WH (67 T877) it had the incorrect oil bath filter on it (it bent the front of the grill out) I took it off and placed a regular filter using just the oil bath cover. My question is...is it ok to run these Kohlers without the oil bath filters? I know they are better filters, but Im curious if the modern filters are sufficient.
By SimonC
Hi,
my throttle return spring is basically useless.
3 questions;
- if I remove the throttle butterfly screw that holds the shaft in there, do I need to use loctite or similar when putting it back ?
- I cannot find any reference online or anywhere to the model of carb I have; 676794 or 676704 (attached pic), are those springs normally standard (any link to a replacement would be great)
the rest of the carburetor is not in that good of a shape, I see all bunch of cheap carb around on ebay but again, none that match my part number. Other than the throttle/choke/fuel line, can I safely replace mine with another model assuming it's built for the same engine size (10hp).
my current block is a sbh-225 (hh100) installed on a raider 10 (69-70)
thanks
By Mike-Casella
This is a video I did to explain how to rebuild one of these 4 screw fuel pumps. It's not very long, but it may help someone that is a little reluctant to do the job at home. If you have any questions, please don't hesitate to ask. I noticed something that I left out, and that has to do with the pumps that use a 6 screw top cover. If your pump has that, when you order a kit, make sure to mention that fact.
