andrewLL
Gear shift problem
andrewLL
Hi, hoping someone can help me.  I've just started my 1972 Raider not having touched it since July and it fired up first go, can't complain about that.  However after a few minutes use I stopped to refuel and then could not get it inlto gear.  I found that the main lever 1 2 3 + R (not high / low) was very loose.  It appears that the small bolt that holds the shift lever in place had come undone.  It was only finger tight and when I removed it, it broke into two.  Fortunately nothing went into the gear box, but I dropped the end with the reduced diameter peg that located the shifter.
As I am away from home in SW France I do not have many spares available, but I do have a nut and bolt of the correct thread but just need to know what diameter the end needs to be turned down to and what length?  Can anybody help?  I have a friend out here with a lathe so that part should be easy.
I expected to be able to select a gear just by holding the selector in place but could not, is this normal or are there bigger problems?
Any help would be appreciated, oh and just before coming over to France I bought a black hood Wheel horse on fleebay with no engine, but have a 16hp Kohler in the shed that should fit, just hope it works as I got it for next to nothing and the previous owner said it spat flames from the carb!  A project for the winter.
Thanks, Andrew
  • Sad 1
rmaynard
Many guys have used dog-point set screws from McMaster-Carr. Their 1/4"-20 set screw has a dog-point that is .156" (3.9 mm) diameter.
andrewLL
Hi Bob, thanks for your reply, I have had a bolt turned down to 3.9mm diameter and refitted the gear stick but I still have a problem and hope someone can point in the right direction.
The gear stick is fitted with the dog point screw locating it but not too tight as I assume it needs some movement but it is stuck in gear.  I think it is in second but not 100% sure.  The gear stick is back close to the seat which would correspond to 1st or reverse but will not move forward.  I assume the lever was not correctly located before fitting the locating screw.  I am not quite sure how the screw should work because unless it is very 'sloppy' it will only allow side to side movement of the lever.  Can anyone help please?
Any way I was able to cut nearly all of the grass in one gear with no neutral before another problem re-occurred and the tractor lost nearly all power (I will post a question separately under engines), I guess this is all part of the challenge of running a 45 year old tractor.
Thanks in advance for all the help I know will be forthcoming.
Andrew
953 nut
Wheel Horse shifter fix
If your shift lever comes out of the transmission or is stuck in one gear first back out the “Dog-point” screw that retained the shifter. Take a look in the hole the shifter came out of to be sure it is in neutral as shown above.
Inspect the dog-point to be sure it is in good condition and back off on the locking nut a couple of turns. Insert the shifter and run the dog-point into the dimple in the shift lever collar snugging it up with an allen wrench, don’t tighten it. Be sure the shifter works smoothly then tighten the lock nut while holding the dog-point steady with the allen wrench.
R. L. Addison
I have seen the roll pin sheared in the gear drive unit. This is the first thing I would check from what I am understanding. I disassembled a six-speed
and after head scratching, after I found the problem realized I could have fixed the problem through the shift hole. Live & learn.
Racinbob
Here's another place to get them.
https://www.fastenal.com/products/details/25393
If they don't have them in stock they will get them to the branch with no shipping charge. The price was lower than listed....I think about 95¢ :)
Oops! I didn't notice that you are in the UK but they do have several branches over there.
Skipper
This is a long shot, but I'm thinking that if the problem started right after you had the shifter arm out of it? Then perhaps it could be an option to check if it is put back in its correct place?. I'm not a genious on transmissions, but I would imagine you could put the stick in wrong, so it do not "catch" right.
Just a thought :-)
andrewLL
Thank you all for your assistance here, the picture was especially helpful.  It's all back together now and working as it should.
Andrew
PDQ
RacinBob,
Thanks for the URL. That's the exact part I'm missing from my 1970 Raider 10 transmission lever. The guy I bought it from used a 1/4 - 20 bolt which of course, doesn't hold it in place.
There's a Fastenal a few miles from me. I'll drop by there and get the part. Again, thanks for the direct URL.
And  953 Nut, thanks for the view down into the transmission for the correct alignment before inserting the lever. I spent hours studying transmission overhaul info but that single picture of yours is exactly what I didn't have and exactly what I needed.
Thanks again guys.
Paul
RDF
Hello everyone, I am facing a similar problem. In other posts I have noticed a nice picture of the shifter with with the collar attached. Should the collar be physically attached to the shifter and come out in one piece? When my shifter came out, the collar was left in the hole. I am afraid of unscrewing the set screw any further and losing the collar down the hole.
rmaynard
It should be attached to the shifter.
Mine have all been welded like in this picture.
WHX??
:WRS: RDF
Most are welded as Bob's pic shows  but there have been reports of them  attached with a roll pin. Fashion a hook of sorts and try and hook it out while slowly backing off the dog point. You do not want to drop that in the transmission or you will be splitting the cases. A strong magnet or grab it or tight with a needle nose vise grip might work to pull it up and out but I would stick with plan A. Replace the roll pin once out to locate it back on the shaft  and then have it  welded.
Edited by WHX12
953 nut
:WRS:         @RDF, Jim has answered this question very well. If you have other questions please post them.
:text-welcomeconfetti:
RDF
Excellent! I managed to fish it out without dropping it in. Looks like mine was indeed just a roll pin with no weld. The roll pin is completely sheared. I guess that is my problem. Thanks for the great advice!
gwest_ca
933168 roll pin for the shifter donut 5/32" x 13/16"
Replaced by 32121-114 spirol pin
Garry
Horse Newbie
Just my:twocents-02cents:worth, but I've never been able to get a shifter lever anywhere near back in place unless those two forks, or whatever they are called were in the position that the picture shows.(looking in the shifter hole)Guess that is what is usually neutral, right?
Edited by Horse Newbie
Better choice of words
WHX??
Yes that is neutral as shown in the pic. It is the easiest to put the shifter back in in that position. The transmission should be in neutral when adjusting the dog point.  If its not in that position an appropriate screwdriver can used to get it there.
  • Similar Content
    • andrewLL
      By andrewLL
      Hi, hoping someone can help.  I'm over in France trying to tidy up my place before the winter so do not have all the tools I have back at home.  I have a separate problem with the gear box but have posted separately.
      Back in July when l last used the tractor it was loosing power when it got hot, and looking on the internet it appeared that the coil may be the problem.
      i have just returned to France and brought a new coil with me and replaced the old one.  This coil has a separate ballast resistor attached.  The tractor started first go and I started to cut the grass but with gearbox problems.  The grass was long and thick in places and the tractor coped well, just heading the governor apply a bit more power in places.  Them after about half an hour the engine lost power and there were some visible flames commons ftom the exhaust.
      can any one tell me what is happening here.  I assume that it is heat related because the engine started first go and then ran well.  But it must have been fully up to temperature long before this loss of power.  Seeing flames from the exhaust indicates that the fuel is not being burnt in the cylinder, is this an ignition problem? Or are the valve not shutting properly an the fuel is just being pushed straight out of the engine?
      I'm sure it would look quite cool  after dark, but with no power the grass will keep growing.  Hop some one can help.
      Thanks, Andrew
    • dstitz
      By dstitz
      need some help hooking up a tiller. I just bought a 69' model 1-6241 raider 12 and a tiller separate from another seller. I have the tiller mounted, but have trouble with the belt and Pulleys... or lack there of pulleys.
      here is where I'm currently stuck
    • KC9KAS
      By KC9KAS
      Working on a 1969 Raider 12 for a friend.
      As far as I can tell, the engine is the correct one for this tractor. It was missing the entire air cleaner, so the owner got an air cleaner housing, but I have found that it will not fit on this carb.
      The mounting holes on the air cleaner base are 1 7/8" center to center for both the horizontal and vertical holes.
      The carb has been roughed up a little and the 2 horizontal holes have been "wallowed" out and a piece of the aluminum casting has actually been broke off and some type of plastic filler was used to "hide" the damage. Can't do much to repair this as the choke shaft rotates here.
      The vertical holes on the carb are 1 5/8" center to center.
      Can anyone shed any light on this? Is the carb for older K301 engine different than the carbs for say a middle 70's K301?
      I think I will just pull this carb and install one off of another 12 hp that already has the air cleaner base on it!
    • 69-Raider-10
      By 69-Raider-10
      Followed up the Trailblazer 7 purchase with another good CL find. This one is a REALLY good one. Picked up a 68' Raider 12  That came with wheel weights, chains, 48" deck in insanely good condition, and a dump cart with hydraulics! I'm not sure if the cart is an actual Wheel horse, it could be but the tires aren't right. Obviously the hydraulics aren't original. Either way, I paid the equivalent of buying the cart and wheel weights at Fair market value. I couldn't believe it made it past 24 hours. Nice to know I don't have much competition in the area!
      Couple of questions on the setup of this beast. My buddy thinks it was a pulling tractor. It has the rear wheel hub extensions (which I don't mind at all. Looks slick if you ask me), it also has a modified throttle body which works fantastic and is a thousand times better than the twist-lock cable, it had a homemade steering tensioner at the base of the steering wheel made from a spring and half a coffee can lid to protect the paint, and the footboards have extensions off the front sides. The fella I bought it from got the tractor from his uncle who I'm guessing passed away because he didn't have much info on the tractor at all. He wasn't sure why things were setup like they were. Certainly explains why the deck is pretty much mint. I swear those blades are original. Overall, the thing runs like a top and purs like a kitten with the modified muffler.
      Will the 48" deck mount up on my attachomatic setup on my 69' Raider? That's the other thing, take a look at this rear. There are no latches.
      Thanks in advance for any info!
    • mmmmmdonuts
      By mmmmmdonuts
      Got my transmission fixed last year in time for winter and have been mowing all spring/summer no problem until tonight. I got a Raider 12 with a 5060 transmission and when I was mowing the lawn today I went to shift the tractor from 1st to 2nd gear and nothing happened. I didn't hear a grind or anything, but put the tractor back in neutral, shut off the mowing deck and tried going into to gear. The tractor wouldn't move at all. I can still roll the tractor in neutral but shifting the transmission in gear with the tractor off does not have the tractor brake.
      I already think I know what the answer is, but is there anyway I did not strip a gear in the transmission and not have to drop the transmission to find and replace the gear that probably stripped?
      Thanks for help.
