PAguy
Front bar on frame for 314-8
PAguy
This weekend I had an issue where my pivot pins retaining ring came off without my noticing and placed pressure on the front bar that's welded to the frame and bolts the hood and front hitch down.
I can easily replace the pivot pin but am wondering about how difficult it is to weld this bar back on. The farmer down the road from me is able to weld it but was hoping maybe someone could share how they accomplished this given the tight space. This afternoon once its warmed up I intend to clean up the area well and take the front axel off to prep for the welding so that won't be an issue.
Photo attached
Jerry77
Maybe I don't have a good grasp on what the situation is, but if it just welding on the rear side, I would take out the battery, empty the gas tank and drain the oil from the engine....then tip the tractor on it's side to get a good vertical angle to weld....I wouldn't try an overhead weld in that tight of a space. The old weld will need to be ground down first.  On the other hand, if it wouldn't interfere with anything, you could grind a bevel on both pieces and weld it just as it is with the weldment on the outside..:twocents-02cents:
PAguy
Thank you that's a help. An outside weld would not interfere since your just bolting to the front of it. I was just not sure if a front weld would be sufficient or not.
Ed Kennell
                                                 :text-yeahthat:
Forget about welding on the inside or you will have the same or worse weld that just broke.
Grind a 30 Degree bevel 2/3 of the thickness on the ends of the frame angles and a matching bevel on the face plate.
Disconnect the battery.
Attach the ground to clean shiny metal surface on the frame rail.
Strike the first arc on the ground clamp sliding it off to the frame...in effect tack welding the ground clamp to the frame rail.
Weld the groove full with multiple passes.
This will be 10X stronger than the factory fillet weld
Edited by Ed Kennell
PAguy
Thank you this is very helpful I'll provide and update once we have finished. The farmer that is going to help with the weld is free next weekend so we will do it then.
Ed Kennell
Oh, pardon my manners.
              :text-welcomeconfetti: to the :rs:     Always good to have another Pee Aaa  horse lover.
857 horse
Well,,,,,i just learned a new word,,,,,,and what ever ED just said,,,,,,sounded pretty  bad  Azz........Thanks Ed,,,,!!!!!
Weldment........<======= Id like to use that someday,,,,,If its OK,,,,with all concerned !!!!!!!!
thanks much,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Howard 857,,,,,down under in VA
Ed Kennell
I
I think Jerry would probably be OK with that Howard.  Just make sure you can do it all.
Sarge
Howard , you have some of the finest Pipeliners in the nation in your neck of the woods - show it to one of those guys (most should be off for the winter) and let them fix it . You'll never break that joint again...
7018 is your choice of rod .
Sarge
Pollack Pete
Hmmmmm.....I've seen a lot of used,abused,re-used and mis-treated Wheel Horse tractors,but I have never seen one break there.Like Sarge just said,have a pipe welder stick it back together.You'll never have a problem there again.
Ed Kennell
Look closely at the weld on the left frame rail. (right side on the first picture)      The factory weld never penetrated the face plate.  The right side was all that held it together.
Howard could fix this after he perfects his technique to make a  full penetration butt weldment.
  • Similar Content
    • Brockport Bill
      By Brockport Bill
      Wheel Horse Classic Toro Hood - Excellent original factory paint condition - Cash pick up near Poughkeepsie, NY. No Shipping. As is - no returns. Buyer should confirm match to their tractor model. Please send p.m. message.
    • Team70R
      By Team70R
      Thinking about putting a K301 in a short frame such as a 606. Curious if anyone has tried this! Will it fit?
    • Team70R
      By Team70R
      Finally got fed up messing with the old HH60 and pulled it off my 606. Slapped the Honda G300 on, which I have $0 in, and got everything working! Just have to set up one of the old Tecumseh gas tanks and modify the exhaust so the hood will fit WITHOUT cutting it. Should be a work horse now!
    • Team70R
      By Team70R
      Made a 4 hour round trip on Sunday to pick up a 48" blade w/rear bracket for $150.. Needless to say, it was well worth the trip and the money!! Can't wait for snow more snow!!
    • HorseHead1089
      By HorseHead1089
      OK......I'm aware of the few front end loader threads recently and through searches here and through Google i just thought id make a place here for my own hopeful plethora of info. Well through my friends father i will be acquiring a 603 or 633 some such series round hood for Free.99!! Anyways my parents LOVE to mulch the flower beds and i happen to hate it unless i can play with my tractors. I guess you can see where this is going. I have searched far and wide on hydraulics vs electric actuators, and have noticed for such porpoises of moving mulch, and maintenance each seem to be good candidates. as far as a front end loader i have found a REAR end loader. Now will this benefit over a FEL by reasoning of less wear of front components since its a smaller tractor, and i thinks from the way it looks could be smaller/easier to move off and on. As far as getting it into the trailer, i could see the FEL prevailing in this category. ow would a rear end loader be able to ascend to a height? it doesn't look good from these pictures but there are ramps i could just back it up onto the trailer. and dont worry about it tipping as we have a silverado or '48 Farmall Super A to keep it held down. I have these pictures to get the conversation started. (yes I know ones a Sears and ones a Cubby)
