Elkskin's mower junkyard 1,117 #1 Posted November 9, 2017 last year we bought a brand new farm and fleet battery for dads 1972 compact 8e. well went out today to start it and wont turn over battery completely dead. its sat for a month or 2 since last run. but it has a farm and fleet battery in it which i am not a fan of. i have had good luck with everstarts from walmart. and i have a feeling thats whats going back into this sears. Share this post Link to post Share on other sites
Ed Kennell 38,136 #2 Posted November 9, 2017 Will the battery take a charge? May have a small power drain in the wiring or a switch. 2 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #3 Posted November 9, 2017 7 minutes ago, Ed Kennell said: Will the battery take a charge? May have a small power drain in the wiring or a switch. its taking forever to charge how dead it was. anything is possible last battery that was in it was 5 years old when it went Share this post Link to post Share on other sites
Daddy Don 905 #4 Posted November 10, 2017 (edited) I have battery maintainers on all my batteries . It just keeps a small charge on them without over charging them. Well worth the money. Edited November 10, 2017 by Daddy Don 4 Share this post Link to post Share on other sites
ebinmaine 67,422 #5 Posted November 10, 2017 1 hour ago, Daddy Don said: I have battery maintainers on all my batteries . It just keeps a small charge on them without over charging them. Well worth the money. Me too. Agreed. 1 Share this post Link to post Share on other sites
Adams94 1,068 #6 Posted November 10, 2017 1 hour ago, Daddy Don said: I have battery maintainers on all my batteries . It just keeps a small charge on them without over charging them. Well worth the money. These work good as long as they are good, the cheaper ones I have seen them malfunction and over charge the batteries, ruining them 2 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #7 Posted November 10, 2017 I just ordered 4 Daltran battery tender jr. I had some cheep harbor freight battery trickle chargers and one cooked almost 1/2 the water out of my 4 wheeler battery. Refilled with distilled water and slow charged it and it's ok. I won't use a cheep off brand any more tractor batterys are half the cost of a 4 wheeler battery. I actually broke my own law not to use cheep unrated Chinese electronics . 2 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #8 Posted November 10, 2017 i have used a maintainer once but this tractor usually sits between uses and never has problems most its used is wintertime and once in a while during summer months and maybe once in spring or so. i do miss dad though heres a video from a couple years ago. the ticking in engine i have no clue what it is i been through it dont see any problems. i am betting its part of stater hitting flywheel Also i done the wiring on that sears. it does not have a powerful stater in it. just a small 3 amp which i may get the bigger one later on for it. 1 Share this post Link to post Share on other sites
Pullstart 62,834 #9 Posted November 10, 2017 I couldn't believe the power of distilled water in a weak battery... until I spent 98 cents a piece for 4 gallons to keep in the shop. I topped off a battery that would loose charge after a day and it's been sitting a week or two and will fire up my truck at any notice. 98 cents is better than 98 dollars in this case. 5 Share this post Link to post Share on other sites
BaySide1 138 #10 Posted November 12, 2017 If a dead/depleted battery freezes you will end up replacing it most of the time. In your case, put a load tester on it and see if you have a dead cell Share this post Link to post Share on other sites
ClassicTractorProfessor 5,314 #11 Posted November 13, 2017 I feel your pain...this has been a bad year for batteries around here...had to replace the truck battery in the RV the start of the summer, now need to replace the house battery. Then had to replace the battery in my pickup...now need to put a new battery in the C125 and the 2n Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #12 Posted November 14, 2017 well today i went to start my 1972 sears ss15 and well battery was almost dead. had to charge it up. so far though the compact 8e is holding charge. i did pickup a new everstart just incase. i will have the farm and fleet battery tested thurseday or friday at local shop Share this post Link to post Share on other sites
