69-Raider-10
69' / 70' Bolens 1254-01 - PTO Coupler
69-Raider-10
Hello all. I have a Bolens 1254-01 that Im taking out of retirement and putting back to work as my snow throwing machine. I got it in a trade and it came with a good deck, snow thrower, wheel weights, and chains. I love the spline shaft accessory hookup as I think it will churn up snow better than a belt driven pto. Not to mention the Wisconsin 12hp is in its final stages of life and recently started sending out smoke signals when first started until it warms up. Might as well run it until she quits and rebuild.
That being said, I am missing the coupler that attaches the PTO Shaft to the gear box of the attachments. Its a female spline to univeral joint attachment and looks like this.
Here is the tractor. I recently gave it a sand/prime/paint but no decals yet until I decide on the modded hood staying or going. I took the pic from the Sam Bolens website. Im looking for a cheaper alternative. Thanks for any help!
mmmmmdonuts
Unfortunately these drive shafts are expensive. You could get what you need (15 tooth 1" shaft) here: http://www.paulbparts.com/product/weasler-pto-implement-yoke-domestic-6-series-clamp-yoke-1-15-spline/#attach-implement-yoke-before-shipping. I priced it around $110 or so. They will build the other half as well with a cross member. I think you will save a little bit with it if you order carefully. The other option is to place a wanted ad for it or go on ebay and search. Most of the bolens family uses very similar shafts. Good luck.
Edited by mmmmmdonuts
  • Thanks 1
69-Raider-10
Great information! Thank you!
69-Raider-10
So I order the 1"-15 spline yoke, I assume the Tube Assembly 48" Driveline, and the standard cross and bearing kit? Would you recommend the pre-shipping assembly? What does that mean exactly?
Edited by 69-Raider-10
Misspelling
mmmmmdonuts
Yes. I believe that is correct. I have a Troy Bilt GTX (Bolens Duratrac, just different paint) and that is the type of shaft and driveline it uses for the attachments. The one thing with mine is some have the tube and others have the actual square driveline for attachments. I believe the 1254 uses the same thing. Do you have pictures of the gearbox?
I believe the shipped assembly puts the cross in the shaft to connect the two yoke and driveline together. I would get it pre-assembled for the $20 because I believe you need a press to press the cross and bearings in. You could call and double check what assembled means. I have not bought from them.
  • Similar Content
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
    • DMB41
      By DMB41
      Hi All,
      My first post on here so apologies in advance for any rookie mistakes.
      First off, I am the proud owner of a "new to me" 312-8. I took it out for a spin yesterday and when I engaged the PTO, currently there is a 42 in side discharge mower deck on it, there were sparks flying from the disk directly below the muffler (maybe the flywheel or clutch?). Any idea what that may be and what needs to be addressed?
      Thank you !!
