By
Texas Todd
So I get the tilt cylinders rebuilt and want to see what I can lift. So I get the D loaded to go to up to my land.
Got some sizable rocks moved.
I got this one moved and then put on the rear blade to get some ballast. I could use some more weight and I am looking for ways to do that.
After about 45 minutes, the transmission seemed to lose it's power. Where it would spin the tires trying to dig under this first rock, it didn't afterwards. Though not an emergency at this time, the lifting is the most important and it seemed to transport them fine. My question is this. I have another transmission from a D-180 (although it may have the same issue, I don't know). Should I swap the trannys like I did the engines or rebuild the transmission that is on it? Will rebuilding fix this issue?
I haven't looked to see how these are attached, but are they as straightforward as the C tractors transmissions?
Thanks for your input!
I most likely won't attempt it anytime soon, just wanted to get the wisdom of the group.
