71 Bronco 14 - differential click / ratchet
By
sfjohnson722, in Transmissions and transaxles
Similar Content
By tomabrown77
my 1067 stopped moving; limited slip had worn out long ago; now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance. Enough to tell me shift lever is actually changing gears.
I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt transaxle if someone has one they would part with. And any advice on opening up the transaxle and looking inside . Or where i can find parts to rebuild it myself...
ps i was on forum about 5 years ago, forgot my username so i joined again
By AndyZ
Operator manual #A-5274
Wiring
6 pages 7.31MB
Illustrated parts list link
Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
For 1970 electric clutch use Electro 12 model 1-7255
2 pages 282KB
We also have the 1971 tractor parts manual that followed
1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
By Kyle G Cantrell
Trying to restore a 1971 Wheel horse Workhorse 800 model 0100, It has a tecumseh HH80-110112D.
I cannot find any parts at all for this one, I’ve checked everywhere I can think online. This is my first restore, looking for some help to find parts or what I can use (swap) to keep it close to original but also functional.
Also the fly wheel has two **** that stick up off it that the coil passes and one is broke off. Is that a problem, I’m a mechanic but this thing is old and with no info it’s a guessing game.
Parts needed so far:
right side running bored/footrest
Left side engine cover
right side pulley cover
Ignition coil
Main drive pulley bearings
Hitch pin (goes through trans case)
*NEW TO SITE, WILL CHANGE IF POST INCORRECT*
By drewd
I need to buy tubes or new rear tires for my 1971 Workhorse 800. It has the original 22.5x7.50-12 Wheelhorse branded tires but sidewalls are leaking and one no longer holds air for more that two days. Searching websites brings up various sizes but not the original. Would a 23x9.50-12 fit this tractor? I have a 36" RD deck on it. Any other sizes work on this rim and tractor?
Thanks!
By Mikey j
Hi everyone, I have a 1969 raider12 6speed trans, Thant I’m going to change the oil in. But I don’t have a dipstick how do I get the two quarts in there? i tried filling from the side port only got about 700mils in. Thanks in advance!
