bwcollins
Transmission leak at brake disc
bwcollins
My B-80 has a leak behind the brake band, appears it’s a slow leak behind the brake drum where it exits the transmission... Anyone know if there is a seal here? And is this leak common/easy to fix? Haven’t taken it apart and was curious, my transmission works fine, but gear oil will slowly leak out, it’s an 8 speed B-80 transmission
gwest_ca
There is a replaceable seal behind the drum. Here is the parts list
Pinned at the very top of the Transmission forum are crossovers for the seal numbers to available replacements.
Garry
