AlexR 1,270 #101 Posted March 10 28 minutes ago, ebinmaine said: Them're neat. Thanks I pulled them off the Raider 10 I grew up with, when I was there last spring. I still kinda regret not taking the whole tractor even though it was next to a shop fire so one side of it was all burned up, I remember the manual transmission was having issues it had already had a repair in it. The engine was on its last leg the steering wheel and hood were destroyed from a branch falling on it from the same fire. It was in rough rough shape. You can tell the two weights that are very rusty were on the fire side. 1 Share this post Link to post Share on other sites
AlexR 1,270 #102 Posted March 16 (edited) Got the rebuild kit for the carb. And got stainless steel screws for the throttle plate. Waiting on some split lock washers to come in to finish that up, also going to use loctite as well. And next I have a question for you guys so I am going to flatten the head when I replace the head gasket, so I have this piece of 1/4" thick glass, or I have a delta table saw. Which should I use as the flat surface for the sandpaper? Edited March 16 by AlexR 1 Share this post Link to post Share on other sites
Ed Kennell 40,453 #103 Posted March 16 I would use the glass. 5 1 Share this post Link to post Share on other sites
kpinnc 13,703 #104 Posted March 17 3 hours ago, AlexR said: And got stainless steel screws for the throttle plate. Waiting on some split lock washers to come in to finish that up, also going to use loctite as well. Red loctite, and plenty of it. I had a Magnum ingest a brass butterfly screw. Mashed it flat as a pancake. Stainless will likely break the head and piston. 2 Share this post Link to post Share on other sites
ebinmaine 70,657 #105 Posted March 17 3 hours ago, Ed Kennell said: I would use the glass. Seconded. Lay a towel on whatever surface the glass will be on. Lay the glass flat and even. Tape the sand paper to the glass. I use several grits. Sand away..... BE SURE TO ROTATE THE CYLINDER HEAD OFTEN. 1 Share this post Link to post Share on other sites
AlexR 1,270 #106 Posted March 17 34 minutes ago, kpinnc said: Red loctite, and plenty of it. I had a Magnum ingest a brass butterfly screw. Mashed it flat as a pancake. Stainless will likely break the head and piston. Definitely I am not planning on those screws coming back out, until those bushings wear out so not for a long long time. Share this post Link to post Share on other sites
AlexR 1,270 #107 Posted March 17 23 minutes ago, ebinmaine said: Lay a towel on whatever surface the glass will be on. Lay the glass flat and even. Tape the sand paper to the glass. I use several grits. Sand away..... BE SURE TO ROTATE THE CYLINDER HEAD OFTEN. Yes I was thinking about that, a towel would provide some cushion for a not perfectly flat surface under the glass. I have read a figure 8 sanding pattern is good to do. 2 Share this post Link to post Share on other sites
ebinmaine 70,657 #108 Posted March 17 9 minutes ago, AlexR said: figure 8 sanding pattern That's true...but... A Kohler cylinder head on a standard 8.5 x 11 piece of sand paper won't leave much room for the figure 8 motion. BBT and I have found that a straight motion going the longer direction is easier. I spin the head about 20 to 30 strokes to maintain an even cut. Plan on a solid hour of sanding off n on over a couple days and you'll get good results. 1 Share this post Link to post Share on other sites
AlexR 1,270 #109 Posted March 17 37 minutes ago, ebinmaine said: A Kohler cylinder head on a standard 8.5 x 11 piece of sand paper won't leave much room for the figure 8 motion. Didn't even think of that, thank you very much for the advise! Very helpful. 1 1 Share this post Link to post Share on other sites
Handy Don 13,340 #110 Posted March 17 15 hours ago, AlexR said: And next I have a question for you guys so I am going to flatten the head when I replace the head gasket, so I have this piece of 1/4" thick glass, or I have a delta table saw. Which should I use as the flat surface for the sandpaper? ¼” glass can flex. Use the glass on the table saw on a thin cloth just to anchor the glass. 2 Share this post Link to post Share on other sites
peter lena 9,085 #111 Posted March 17 @AlexR like running in any recent engine on a seperate gallon of heavily treated fresh fuel , also drop carb bowl , fresh fuel filter , typically the rubber flue hoses break down , with ethanol , clogging anything , personally add STA BIL fuel treatment to all my stuff , eliminated debris , pete 1 Share this post Link to post Share on other sites
peter lena 9,085 #112 Posted March 18 @AlexR anything I suggest is what I have tried , experimented with , rarely have a one and done , elimination of an issue , that fuel issue , was easy , a repetitive problem , like fuel hose break down , has to be eliminated first , every visible point , has to stay clean / clear , STA BIL fuel storage additive , has done it for me , no debris any ware , my stuff starts right up after long sitting , related clear fuel filter is clean , realise this is an area of contention , I DO NOT HAVE TO WIN , have also eliminated long runs of rubber hose , with steel brake line , leaving only the tank / carb areas , with hose and filter . my stuff starts up with zero smoke or hesitation , had 4 small engines , tractors / generator , that were changed over , no fuel issues at all . also my views of mechanical repair are different , millwrighting does that to you , swiss lewa gear pumps , pete 3 Share this post Link to post Share on other sites
AlexR 1,270 #113 Posted March 19 @peter lena I do already use only non-ethanol gas in all my small engine stuff and don't have any issues with clogging or starting after they sit a while. I only use stabil for stuff that sits a lot especially during winter like the generator and the z-turn That is a good idea about running some steel line, I used rubber the whole way. 1 1 Share this post Link to post Share on other sites
AlexR 1,270 #114 Posted March 23 Getting the weights painted, And got the lock washers for the throttle plate screws, so got those in with red thread locker. Not sure those screws are coming back out 1 1 Share this post Link to post Share on other sites
kpinnc 13,703 #115 Posted March 23 3 hours ago, AlexR said: Not sure those screws are coming back out Probably for the best. 2 Share this post Link to post Share on other sites
AlexR 1,270 #116 Posted March 26 Got the front rims painted. And got weights mounted on the landside of the tractor for plowing, the tires are already fluid filled. 7 Share this post Link to post Share on other sites
rjg854 11,877 #117 Posted March 27 15 hours ago, AlexR said: And got weights mounted on the landside of the tractor for plowing, the tires are already fluid filled May I suggest putting caps on those protruding bolts or cutting them a bit shorter, your shims just might thank you. 3 2 Share this post Link to post Share on other sites
squonk 42,502 #118 Posted March 27 1 hour ago, rjg854 said: May I suggest putting caps on those protruding bolts or cutting them a bit shorter, your shims just might thank you. Acorn nuts work and look good. 3 Share this post Link to post Share on other sites
WHX?? 50,686 #119 Posted March 27 Pike nuts... for chariots of fire... 1 6 Share this post Link to post Share on other sites
AlexR 1,270 #120 Posted March 27 Got the front weights on. And then I removed the battery to put it on the charger. And as I was doing that gas just starting pouring out of the bottom of the tank of course I had just filled it all the way up lol. It was the rubber grommet that split. Fortunately I had a new spare one just had to get it on, so it was a bit of a mess 3 1 1 Share this post Link to post Share on other sites
953 nut 57,833 #121 Posted March 27 10 hours ago, rjg854 said: May I suggest putting caps on those protruding bolts or cutting them a bit shorter, your shims just might thank you. I would suggest removing them one at a time and running the bolts into the wheel rather than the weight. 2 Share this post Link to post Share on other sites
WHX?? 50,686 #122 Posted March 27 That is a nice tractor ... dandy plow mule fer sure. 1 Share this post Link to post Share on other sites
AlexR 1,270 #123 Posted March 28 7 minutes ago, 953 nut said: I would suggest removing them one at a time and running the bolts into the wheel rather than the weight. They are carriage bolts so I can't really do that with them as it needs a washer on the weight side and the square of the carriage bolt fits in the wheel. I will probably just cut them a bit shorter. 2 1 Share this post Link to post Share on other sites
AlexR 1,270 #124 Posted March 28 5 minutes ago, WHX?? said: That is a nice tractor ... dandy plow mule fer sure. Thanks! I have used it to plow the garden, but that isn't much of a comparison to a plow day. Just really glad the rubber grommet split now when I was working on it. And not when everything was hot during the plow day. 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,494 #125 Posted March 28 9 hours ago, WHX?? said: Pike nuts... for chariots of fire... Worked well in Ben Hur... 4 Share this post Link to post Share on other sites
