drewd
Front Wheel Bearings
drewd
The 416-8 I picked up a few months ago takes the larger diameter wheel bearings in the front wheels. The parts list show two bearing options depending on the rims you have.  Mine unfortunately take the 107124 bearing that I can only find as new/old stock for $55.00+ each or $230 for 4 with shipping.  Has anyone found other bearings that can be used in these rims?
Thanks!
rmaynard
If the O.D. is 1-3/8" and the I.D. is 3/4", and you are not planning on installing a front end loader, I don't see any reason why you can't use the light duty bearings 110513. :think:
Edited by rmaynard
pacer
Get the dimensions off your bearings like maynard sez, and shop for it using the dims - Toro parts are notoriously expensive. If it is indeed the 1 3/8x3/4" then the bearing he shows is a good quality bearing
drewd
My hubs take a larger diameter bearing. Here are pictures of the 110513 that you mention and 107124 bearing in my rim.  Both bearings are listed on the Wheel Horse parts lists so I thought another Red Square member must have the same issue. Thanks!
rmaynard
Send a PM off to @wheelhorseman Give him the dimensions and see what he can do for you.
953 nut
If you go to a good mechanical/industrial supply house they should be able to fix you up with steel bushings to reduce it to 1 3/8 and then use these inexpensive sealed bearings.
http://www.ebay.com/itm/4-WHEEL-BEARINGS-TORO-WHEEL-HORSE-11-0513-25-1210-110513-and-251-3-4-x-1-3-8/281473149545?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m14
drewd
Thanks Guys!  There is a machine shop next to where I work and I brought one of the bearings over and they set me right up.  I ordered four new ones and they should be in tomorrow.  Thanks again.
  • Excellent 2
drewd
Well I have been out of action due to rotator cuff surgery in February.  Doc said 4 months to recover...it took 4 months to do anything!  Finally able to get back to this tractor! Wire wheeled the rims then primed and painted. Mounted new tires with tubes and pressed in the new bearings.  Now that I can finally work on the project again I'll start on the rest.
  • Excellent 2
midpack
Fun, huh? I've had work done on both shoulders. full repair on one, cleanup on the other (to try and prevent a full repair)
At this point in time i''m glad I had it done but it's definitely not for the faint of heart!
drewd
No it is not for the faint of heart!  Glad I did it though as it was over 90% torn and the pictures looked like an old beat up paint brush.  Feeling better and stronger a bit more every day.
  • Similar Content
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • morePEdal
      By morePEdal
      416-8 with Onan P216 Engine
      The good:
      *576 hours
      *Nice, clean deck (42”)
      *Nice Plow
      *Wheel Weights
      *Chains
      *2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
      *Original receipts and paperwork and manuals.
      *Receipt showing tune-up and changing from the deck to the plow in November 2021
      The bad:
      *The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
      *Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
      *I didn’t get a chance to test drive it because of this.
      *One front tire goes flat fast, one rear tire has a slow leak.
      *He is going to buy a battery before I look at it again on Friday so I can test drive it.
      What do you think is the issue? Is it the battery or fuel system?
      Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
      *He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
      He’s asking $500.
    • Boyd
      By Boyd
      wheel horse garden tractor mower, rear discharge mowing deck & snow blower both in good condition and runs well. all the parts for the snow blower are with it.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
